H9 in H11 headlight sockets?
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runningMan, Feb 18, 2019.
  1. Sep 7, 2020 at 10:41 AM
    #91
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    No advantage or disadvantage at all. You don’t need to do them at the same time.
    In fact, I don’t find the 9011 swap to be necessary. I’m sure it’s a nice upgrade, but I’m satisfied with the stock high beams. I don’t like it when my high beam reflections are blinding coming off of road signs. As long as I have good distance viewing, I’m happy.
    7385 and glwood54[QUOTED] like this.
  2. Sep 7, 2020 at 10:49 AM
    #92
    Perfect, thanks. I have the H9 on order, and will assess the lighting need once those are done. I tend to agree with you that the high beams are fine. The oem low beams suck.
    7385, A&P and 4runningMan[QUOTED][OP] like this.
  3. Sep 7, 2020 at 4:29 PM
    #93
    Starr
    Jonathan
    SouthEast Maui
    The H9 is a nice, noticeable upgrade in my Tacoma. I'll do it in the 4Runner soon, as well.
    I have a Foredom flex shaft setup in my shop, and that made clean, quick work of the bulb modification.
  4. Sep 8, 2020 at 7:14 AM
    #94
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    A&P[QUOTED] likes this.
  5. Sep 9, 2020 at 9:47 AM
    #95
    Sheesh. I ordered a different part from Ebay, it arrived in 2 days from Dubai, UAR. These 2 bulbs from this Ebay seller will take a week from Indianapolis...first world problems, I guess. ;)
    #95
  6. Sep 14, 2020 at 9:07 AM
    #96
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    Just ordered a set, but does anyone of a picture of what needs to be cut/trimmed? Thanks
  7. Sep 14, 2020 at 10:33 AM
    #97
    Raijinbu
    Raijinbu New Member
    George
    2014 Silver Trail Premium
    Bilstein 6112 front, 5160 rear, Dobinsons 1.5" rear coils, raptor lights, H9 mod, led inside lights.
    I did not want to add a link here because I'm not sure of it's allowed, but google "h9 conversion to h11" and change the search result to images, you will see exactly what needs to be done. There are 2 parts you need to trim, one trim in the tab that fits in the housing and another in the power socket. I'm using the modified H9 in my 4R and for the $, it works better than anything else I have tried.
  8. Sep 14, 2020 at 1:22 PM
    #98
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  9. Sep 14, 2020 at 1:28 PM
    #99
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Also this, post 38 forward.
  10. Jun 13, 2021 at 12:43 PM
    #100
    4Oregon
    4Oregon New Member
    TRD Off Road Premium
    This thread was super helpful, so thought I'd add a tip that might help someone.
    Just finished swapping the H9's for H11's on a 2018 TRD OR P. The most difficult part was removing the dust caps. The dust cap's dry o-rings made them very tight. I used these slip-jaw pliers to gain mechanical advantage and use both hands to unscrew the dust caps. (I use the same tactic for removing plastic access hatches on a boat)
    Using the micro nippers it was easier than I expected to remove the plastic tab and trim the metal base.
    I did the passenger side first since it was easier to work on. For the driver's side, I took a couple minutes and removed the battery to give me room to work....so much easier.
    When I re-assembled, using silicone spray on a rag, I applied a very light coating of silicone to each dust cap.
    Can't wait for nightfall to try out the H9's!
    JaSC, nimby, jmkulbeth and 1 other person like this.
  11. Jan 2, 2022 at 3:49 PM
    #101
    JaSC
    JaSC New Member
    Anderson, SC
    Black 2018 4Runner TRD Off Road Premium, crawl control and MTS
    ToyTec Lift, Dual Batt Redarc. Rear safe drawer, console safe, Aux 2004 JGC fuse box, Warn bumper, 12,000lb winch
    I have the TRD ORP as well 2018. I'm going to do same as the current low beams suck for my old eyes. I'm just trying to get an handle on terms such as HID, reflector vs projector, and what my vehicle came stock with. Didn't want to get into the weeds with this mod but here I go..
  12. Jul 24, 2022 at 7:53 PM
    #102
    abakja1
    abakja1 New Member
    2015 toyota 4runner sr5
    KN Air intake,, eibach 3" lift
    I put in Phillips h9 I. My 2015 sr5 and the beam seems to face downwards and not project out. How is this possible?
  13. Sep 21, 2022 at 7:30 PM
    #103
    GJ4R
    GJ4R New Member
    Eyeballed and snipped the h9 bulbs, worked great, kind of shocked how much brighter they are!
    Singleminded and nimby like this.
  14. Nov 4, 2022 at 7:08 AM
    #104
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    Drivers side went out, so I replaced both sides...week later brand new passenger side is out hmmmm. Annoying!
  15. Nov 4, 2022 at 7:18 AM
    #105
    ValK83
    ValK83 New Member
    Andrew
    2018 TRD Off Road
    did you wear gloves? Any oil from your fingers on the glass of the bulbs can cause premature failure. Cheers.
    GJ4R, 7385 and PrettyGoodSam[QUOTED] like this.
  16. Nov 4, 2022 at 11:35 AM
    #106
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    I didn't, and I knew better. Maybe that's it.
    ValK83[QUOTED] likes this.
  17. Nov 4, 2022 at 6:00 PM
    #107
    ValK83
    ValK83 New Member
    Andrew
    2018 TRD Off Road
    I bet that’s it. Good thing the Phillips are fairly cheap at 10 bucks a pop.
    PrettyGoodSam[QUOTED] likes this.
  18. Nov 5, 2022 at 12:44 PM
    #108
    GJ4R
    GJ4R New Member
    For now lol. I recommend ordering a few extras at this price point.
    PrettyGoodSam likes this.
  19. Nov 5, 2022 at 8:02 PM
    #109
    4runningMan
    New Mexico
    I clean my bulbs with isopropyl alcohol on a little swab of a cut up t-shirt before install. Can’t hurt.
  20. Nov 6, 2022 at 9:24 AM
    #110
    I installed Phillips H9's when I bought the thing new in 2018.
    They are still going strong.
    Singleminded likes this.
  21. Nov 7, 2022 at 9:32 AM
    #111
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    Gonna check it out after work and see what's up.
    Thanks for the advice!
  22. Nov 7, 2022 at 10:22 AM
    #112
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    I installed mine in summer of 2020 soon after getting my truck, still going about 19k miles later. Though that would be substantially more miles in daylight than at night.
    H9s make a BIG difference. I’d say the headlight performance from the stock H11s deserved an F grade. These standard $10 Philips H9s bring it up to a B+/A-. Seriously.
    nimby[QUOTED] and PrettyGoodSam like this.
  23. Nov 7, 2022 at 12:01 PM
    #113
    2019-NiteShade
    2019-NiteShade New Member
    George
    Wait, am I reading this correctly?! We are putting in high beam bulbs in place of the Low beams. Is this safe? (Or rather is this safe for the incoming traffic?)
  24. Nov 7, 2022 at 12:10 PM
    #114
    2019-NiteShade
    George
    Isn't it easier to just turn on your high beams and drive with it (and turn it off as needed).
  25. Nov 8, 2022 at 9:12 AM
    #115
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    No the high beams are 9011s. The H9s are 65 watts which boost the light output by 50% IIRC.
    I had a hunch about my light being out and I was right. I hadn't chipped off enough of the inner tab and the harness wiggled loose. I chipped the rest off, wiped off the bulb and plugged it back in... worked!
  26. Dec 28, 2022 at 11:21 PM
    #116
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Just did this mod today and there is a noticeable difference from the H11 bulbs. They seem to give off a whiter light than the factory bulbs. This is good for those not completely sold on LED equivalents, like me, but want a slight upgrade. Glad I did it!
    himileage and PrettyGoodSam like this.
  27. Jan 7, 2023 at 3:39 PM
    #117
    MountainMan
    MountainMan New Member
    Pacific Northwest
    Did this mod a month ago and the difference is substantial. I work swing shift and drive home at night through rural farm country with deer, moose, coyotes, raccoons, porcupines, and the occasional elk. I am loving the extra vision when there is traffic and I can't have my hi-beams, light bar, and ditch lights on.
    I used a chisel-blade X-acto knife for the plastic tabs and a dremel tool for the metal ones...
    PrettyGoodSam and Henry J like this.
  28. May 3, 2023 at 8:45 AM
    #118
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Which bulb is which?
    TheSponge likes this.
  29. Jun 15, 2024 at 12:34 PM
    #119
    Traintech86
    Traintech86 New Member
    I made an account just so I can quote and thank this guy who allegedly stole this tool idea from someone else.
    I own a 2016 Trail and had the same, insanely terrible headlights and I came across many of these threads. I didn't want to spend $1350 for lights when there are so many other things to use that money for so I figured I would try the Phillips people recommend. After an Amazon return because someone got that wrong, I went to modify them to fit. I tried pliers that wouldn't fit, a multi-tool, a dremel that didn't have small enough discs, dog nail clippers... I even tried a possibly dull razor blade and heated it up when it didn't work... no luck. I was an hour in and I barely managed to get the metal tab to work. I remembered this thread and decided to go to harbor freight. I was able to find these cutters and they seemed pretty close to what was recommended. They effortlessly and instantly snapped the plastic rib off and then the worst part became putting the bulbs in without gloves...which wasn't to hard.
    Thanks for saving me hours of work on something so simple! Get the cutters and save time people! One thing to note: My 2016 Trail had different sockets so sadly, I wasn't able to remove the plastic insert. If I do like the setup, I might just dremel out the key that prevents the bulbs from going in.
