Good Info About Fluid Maintenance & More
Discussion in '5th Gen 4Runners (2010-2024)' started by whippersnapper02, Jan 18, 2023.
  1. Jan 19, 2023 at 2:34 PM
    Daddykool
    Actually, chains wear. They get looser and longer as a result, but they don't technically stretch.
    Getuponit, 5thToy and Nano909 like this.
  2. Jan 19, 2023 at 2:35 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    What happens is when the guides wear/disintegrate the chain gets loose and eventually saws a slot into the water jacket/timing chain cover……water and oil don’t mix. I did mine at 150K and there were ‘saw’ marks in the cover. Pieces of the plastic chain guides have been in the oil pan for about 20years now.
    Heat cycles make the plastic guides weak and brittle.
    There are aftermarket guides made similar in construction to drum brake shoes that last.
    I replaced the chain even though I could not tell the difference between the new and old……same length and side-side play.
    Daddykool[QUOTED] likes this.
  3. Jan 19, 2023 at 2:37 PM
    Daddykool
    I suppose I should count myself fortunate that none of that happened to me for so many miles.
  4. Jan 19, 2023 at 2:43 PM
    Daddykool
    Sorry, wasn't trying to be a jerk. Some folks think they do really stretch.
  5. Jan 19, 2023 at 3:05 PM
    Not at all. I'm saying that at 100K, it's not likely to be stretched enough to make a difference. Maybe after 200-300K It would become necessary. I'm just going by the fact that some people are putting 200-300K on these without any issues. The tensioner should be able to compensate for a small about of stretch (wear).
    Daddykool likes this.
  6. Jan 19, 2023 at 3:44 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    This is a great post and a great rebuttal to the asinine "some schmuck with a high school education" post.
    I've seen probably the same amount of lazy idiots with college degrees as lazy idiots without college degrees, but it's the lazy idiots with college degrees that make the big uh-ohs since they're the ones in the position to make the big uh-ohs. I've also seen lazy idiots with college degrees in charge of other lazy idiots with college degrees, and if the cycle of uh-ohs could be adapted into a perpetual motion machine some lazy idiot with a college degree would get a Nobel Prize.
  7. Jan 19, 2023 at 6:57 PM
    UncleShorty
    UncleShorty New Member
    People think engineers are making all the design decisions.
    That's mis-guided.
    The bright young MBAs up on Mahogany Row have a HUGE say in the design process. They hold the purse strings.
    It's called "cost engineering" when it comes down from on-high. What that means is that engineers have to work within budget and schedule parameters not set by technical people who understand what they are building, but by bean counters who don't worry about you needing a universal joint in your left elbow to change your oil.
    I carried the tools for many years as a high voltage technician before I earned my EE. So yeah, I gripe about maintenance and repair problems due to poor design. But more times than not I see "if we save a nickel on each unit..." as a big source of problems...
    2Toys, totmacher, mainerunr and 3 others like this.
  8. Jan 19, 2023 at 8:29 PM
    2ndGen22re
    CR
    Carson Valley, NV
    The noise you heard was the chain slapping the timing cover.
    It is about the only problem(common) with the engine.
  9. Jan 19, 2023 at 10:36 PM
    I would agree with this. Fortunately, at least from my perspective, Toyota has more safeguards in place to ensure that quality and reliability isn’t completely abandoned as with possibly other OEM’s.
  10. Jan 20, 2023 at 6:36 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    This is what I was trying to say. As a mechanical engineer (in a completely different world than automobile design), I am constantly being asked to compromise from the best design approach to something that is passable but will cost less money...(my favorite is when they ask me to do something that would violate code and I get to tell them no...)
    totmacher likes this.
  11. Jan 20, 2023 at 6:47 AM
    2ndGen22re
    CR
    Carson Valley, NV
    Don’t leave out politicians.
    They mandated the illustrious 5mph bumpers in the 80’s.
  12. Jan 20, 2023 at 10:10 AM
    wolfman
    wolfman New Member
    the biggest thing for me is the trans oil. I read all the posts you all make about doing it, but its definitely out of my wheelhouse. Not comfortable doing it myself, and the dealerships... one says lifetime and won't touch it and the other can't do an oil change without overfilling it so, I legitimately have no place to get it done. I read a ton of posts on it here and other places online and there are some people with large post counts with many helpful accounts stating changing the oil after 100k or so isn't worth it and leads to trans issues. Some of those guys (albeit few) don't do the trans fluid and have had no issues going into 200k miles. I am torn with taking a gamble on someone who thinks they can do it at a premium that I don't trust, and just rolling the dice. I don't know if I will have the 4Runner that long but the idea of taking care of it like I will own it til it dies is appealing. random thought. Thanks.
  13. Jan 20, 2023 at 10:36 AM
    whippersnapper02 [OP] New Member
    I was weary of doing it myself but it's so easy using the pump in the trans and a bucket.
    wolfman[QUOTED] likes this.
  14. Jan 20, 2023 at 12:02 PM
    Can you sum up what the issue was. I'm trying to skip to the conclusion but now I'm just annoyed that I gave that guy another view.
  15. Jan 20, 2023 at 12:15 PM
    Good videos. First one basically says toyota timing chains dont have a service interval. If he does vvti work, he always inspects the chain, because vvti failures can ruin chains. When he replaces chain, guides and tensioner are replace too.
    The second vid is basically a “buyer beware” on lazy workmanship.
  16. Jan 20, 2023 at 12:17 PM
    Thank you! :hattip:
    I seem to have an issue with YouTube guys. :anonymous:
  17. Jan 20, 2023 at 1:00 PM
    I generally do to. But some like Car Care Nut and Tinkerer are pure gold.
  18. Feb 22, 2023 at 8:04 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    The engineers with advanced degrees trained (and paid...) by Toyota certainly know more about the inner workings. But are they motivated to give a damn about us simps who drive the things....that's the question.
    2ndGen22re likes this.
  19. Feb 22, 2023 at 8:47 PM
    #49
    Said engineers designed hydraulic tensioners to take up chain slack as it stretches but they have limitations. Although I have never seen a chain failure in the 13 years I’ve owned a 1GR, the chains do stretch.
  20. Feb 23, 2023 at 10:05 AM
    #50
    2ndGen22re
    CR
    Carson Valley, NV
    ….up until the warranty expires anyway.
  21. Feb 23, 2023 at 10:15 AM
    #51
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    I had the transmission, transfer case, front/rear diff fluids changed, and a front brake job done this past Monday/Tuesday. Had to remove the aftermarket skid plates. (the mechanic was not pleased). Cost was a tic over $1,000. Work was performed at an independent shop I have been going to for 30ish years. $229 seems about right. The shop rate here is $135/hr.
    EDIT: Work was done at 53,000 miles. Owner told me the transfer case and diff fluids were inky black, with very few "sparkles." Sparkles are bad. Transmission fluid looked O.K.
