Get a Gladiator guys
Discussion in 'General 4Runner Talk' started by Yotaholic, Dec 3, 2024.
  1. Dec 12, 2024 at 8:14 PM
    #121
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    My neighbor had a yellow one when I was a kid. He'd let me borrow it to move furniture or get firewood way back in the day. I thought it was a tough truck back then.
  2. Dec 13, 2024 at 2:16 AM
    #122
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    Fun, but that looks like pretty high maintenance
  3. Dec 13, 2024 at 5:21 AM
    #123
    broken-giver
    broken-giver BFD
    Why is it that I always see these parked as I am getting my Starbucks in the morning.
    (the irony is not lost to me, that I get the coffee in my 4runner).
  4. Dec 13, 2024 at 7:30 AM
    #124
    Just because they have big tires doesn’t mean they can drive right through the restaurant to pick up their coffee at the counter. They need to use the parking lot too. :D
    broken-giver[QUOTED] likes this.
  5. Dec 13, 2024 at 7:36 AM
    #125
    broken-giver
    broken-giver BFD
    :p
  6. Dec 13, 2024 at 8:03 AM
    #126
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    As a DIE HARD Jeep fan....sadly Jeep quality has gone way down!
    Spare Parts likes this.
  7. Dec 13, 2024 at 9:36 AM
    #127
    Are those all yours?
  8. Dec 13, 2024 at 12:03 PM
    #128
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
    They were.
    Turd Ferguson likes this.
  9. Dec 15, 2024 at 6:42 PM
    #129
    Bald Michelins
    Bald Michelins New Member
    21' SR5P
    Jeep is in trouble. The local lot is packed deep. Two GW's put out for sacrifice.....
    2ndGen22re[QUOTED] likes this.
  10. Dec 15, 2024 at 6:51 PM
    #130
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Bald Michelins - love the user name
    22k off, yikes.
    My brother in law who lives near me has a new GW, quite expensive vehicles here, also quite comfortable I gotta say
  11. Dec 15, 2024 at 7:00 PM
    #131
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I had a Cherokee sport that I bought with salvage title. Straight 6, standard transmission, it was great, except when it rained. Water got in through the back and it was nasty smelling. Once we had kids, I needed to get something better for them to be in, after looking for a hike, I ended up with my first Toyota truck.
  12. Dec 15, 2024 at 7:13 PM
    #132
    They're still about $40k OVER priced - even with the 22k discount. I hope Stellantis feels serious financial pain. Plus the interior quality materials are total crap. You can find better material in Kia's & Hyundai's.
    MEski4x4 and Maximumdarkside like this.
