Gearbox Overheating & Clearance Issues with T4R 21 TRD Off-Road in Desert Conditions
Discussion in '5th Gen 4Runners (2010-2024)' started by Khusaibi, Nov 9, 2024.
  1. Nov 10, 2024 at 2:15 PM
    Khusaibi
    Khusaibi [OP] New Member
    Thanks for the advice! Honestly, I didn’t have the suspension set up by a specialist, but I’m considering going to one to get it properly tuned for the terrain here. I’m also thinking about adding some hydraulic bump stops.
    Appreciate the tips—sounds like it’ll be worth the investment to get it set up right!
  2. Nov 10, 2024 at 3:02 PM
    TrailSpecial22 New Member
    PA
    6” in the front? That sounds massive and not feasible
  3. Nov 10, 2024 at 4:53 PM
    The kings have internal bypass and internal bump stops
    I suspect the valving or springs are not quite set up right, otherwise you wouldnt be bottoming out harshly.
    The Camburg bump stops are an easy way to soften up that last bit of bump travel to keep things from bottoming out.
