Gas Mileage issues
Discussion in '5th Gen 4Runners (2010-2024)' started by DirtRider, Mar 1, 2022.
  1. Mar 5, 2022 at 4:55 PM
    #61
    Chucklehead
    Chucklehead Enjoy the ride! You only get one trip
    Fort Wayne, IN
    2021 4Runner Black TRD ORP
    Stock AF, with subtle personality tweaks
    Today’s fill up and associated pics i said previously Id post.
    Love this rig and it does better than i expected.
  2. Mar 5, 2022 at 5:11 PM
    #62
    Clearly, all of your routes are downhill both ways.
    A&P and Thatbassguy like this.
  3. Mar 5, 2022 at 5:22 PM
    #63
    Chucklehead
    Fort Wayne, IN
    LOL
    Favorable daily route and optimizing coasting technique.
    Also bone stock so weight not up…
    McSpazatron likes this.
  4. Mar 17, 2022 at 12:44 AM
    #64
    deaone123
    deaone123 4 runner 4 fishing
    19 4 runner lE nightshade
    I was getting about 14 mpg until after 50k i noticed i dropped down to almost 12 mpg, i changed the air filter, cleaned the throttle body, started filling up using only top tier gas and been using marvs mystery oil on my fills up and mpg improved by 1 mpg. I also did change my battery after 3 years cause i noticed it was taking a bit longer to crank on start. Could be any of those but regular maintenance def improves mpg
    POWERPLANTHOMER likes this.
  5. Mar 17, 2022 at 2:11 PM
    #65
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I use top tier gas 87 .shell..I had the MPG in winter 17MPG...but I used SN PLUS engine oil..now the air temps driving in the afternoon I reset the MPG dash panel and I drove it 65 f air temp and then the MPG is around 20 MPG.. in the summer it will be 21 MPG.. but I inspect and clean the air filter also..I put a air blocker to cover the radiator in the winter temps zero to 40F..engine runs very good and increases the heater air temp ...
    now I will remove the air blocker in march last week...
  6. Mar 17, 2022 at 7:21 PM
    #66
    JohnD
    JohnD New Member
    I’ve put about 2000 miles on my 2018 since adding a Gobi rack. I have 265 KO2. The dashboard tells me 18.2 mpg average. I’ve calculated just over 19.2 mpg on couple of those tanks. 80% of that driving at 65-70 on highway with rolling hills. I think the wind on the rack and those heavy tires cut at least 2 mpg.
  7. Mar 17, 2022 at 8:31 PM
    #67
    lunar_t4r
    lunar_t4r New Member
    2022 Lunar Rock ORP
    I've been trying to set a PB for how efficiently I can drive the 4R. May as well try this since I don't plan on going fast with this truck anyway. The efficiency definitely takes a hit once you go past 70mph.
    Photo from tonight. Mostly flat highway, never went past 65mph. Traffic was mostly clear. Stayed on the right lane. Stock ORP. currently averaging 19.1mpgs for the lifetime of the vehicle (~3100 miles on the odo)
    AZ40CAL likes this.
  8. Mar 19, 2022 at 1:03 AM
    #68
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    Just a thought, I run only non ethanol. It’s either 87 or 91 depending on how I feel. Since I run non ethanol I know the fuel is consistent. I know regular 87 has 10 percent ethanol. I have also heard it can run as high as 15 percent? That might be some of the reason for the vast variation. I like non ethanol.
    j cat likes this.
