Fumoto Oil Drain Plug
Discussion in '5th Gen 4Runners (2010-2024)' started by Havanabama, Apr 22, 2021.
  1. Nov 28, 2021 at 11:16 PM
    Had Fumoto on my Tacoma and never had issues with it. Currently have Stahlbus on the Runner and Goat without issues.
  2. Nov 29, 2021 at 5:25 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘22 ORP LR
    Love the fumoto on my tundra. If our 4R ever comes, a fumoto will go on at the first oil change.
    Toy4X4 and Bear76 like this.
  3. Nov 29, 2021 at 5:50 AM
    rrb1981
    rrb1981 New Member
    2021 Silver Metallic Toyota 4Runner ORP
    The only concern I have is some freak accident where the valve opens during operation (if you have a skid plate, this is virtually impossible). Would it be wise to also put a threaded plug on the downstream side (belt and suspenders approach)?
  4. Nov 29, 2021 at 11:22 AM
    slixx1320
    slixx1320 New Member
    Sort of off topic but for those who's got the fumoto and still have toyota care. Will the toyota tech remove the fumoto and replace it with a factory drain plug or will they use the fumoto since it's on there? I just bought my 22 ORP and looking to put this on when I do my 1k mile break in oil change.
  5. Nov 29, 2021 at 11:38 AM
    Bear76
    Bear76 New Member
    2022 Runner SR5 Premium+
    Still sitting on a cargo ship
    Have one in my Tundra. It’s perfect. I used to use a hose to direct the flow, but it comes out fairly slow and controlled on it own. No hose. Very little mess. No need to re-torque a pan bolt. I’m a fan
  6. Nov 29, 2021 at 12:19 PM
    spyder918[QUOTED] and rrb1981 like this.
  7. Dec 2, 2021 at 10:15 AM
    Marchy
    Marchy New Member
    Sean
    Seattle
    2021 4 Runner Venture
    I had one on my BRZ that was lowered on coilovers, wasn't a concern, I was more likely to high center or scrape the resonator on my mid pipe than I was to hit my drain plug.
    assuming you closed the valve correctly this cannot happen. The lever is held in a groove by spring tension and you have to pull the lever out of the groove and then twist. Unless someone goes under your truck and pulls the skid plate to get access to your drain valve, you have nothing to worry about. :)
    nimby, Toy4X4 and 7385 like this.
