Front bumper issue
Discussion in '5th Gen 4Runners (2010-2024)' started by lyodbraun, May 22, 2019.
  1. Nov 29, 2023 at 9:50 PM
    #91
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @glwood54
    Cheerio, ol' chap
    Passenger side ↓
  2. Nov 30, 2023 at 5:53 AM
    #92
    Thank you! Now to figure out how to attach some wire to that corner of the bumper cover just under the headlight...
    I'm not seeing any recovery brackets in those photos...!
    djwantke[QUOTED] likes this.
  3. Nov 30, 2023 at 6:01 AM
    #93
    As you can see in the photos above, there doesn't seem to be any metal on the back of the OR bumper cover...
  4. Nov 30, 2023 at 10:04 AM
    #94
    Recovery's were soft installed and always planned to come back off to drill two holes each side. I was saying somewhere else on here that the sway bar + cylinder are in the way need a good 27/64 impact bit to throw onto my extension bit in order to hit it straight on
  5. Nov 30, 2023 at 10:06 AM
    #95
    Drilling time in the garage is being ruined by two kids under 2-1/2 and mom and I work full-time lol
  6. Nov 30, 2023 at 4:24 PM
    #96
    Let's goooo
  7. Dec 1, 2023 at 7:10 AM
    #97
    EC15
    EC15 ...
    Are you referring to my fix in the other thread?
    I used wire cause that's the first thing I found laying around.
    You can use double sided tape and stick something off similar thickness in the "yellow" area.
    If I had to do it again, I would get some small stick-on rubber feet, cut it to size and stick it into the bracket.
  8. Dec 1, 2023 at 12:47 PM
    #98
    I think I get what you're saying now...it took a while to figure out where that "yellow" area was. I'm thinking you're talking about just below the point in the bumper cover that's below the passenger side headlight, circled in yellow below:
    I would just have to get the nerve to pull it all off to see exactly what your solution involves...thanks.
  9. Dec 1, 2023 at 2:46 PM
    #99
    EC15
    EC15 ...
    Yea, just refer to my pictures in the other thread for the "yellow" area.
    Once you pull off the bumper, it'll all make sense.
  10. Dec 3, 2023 at 5:18 PM
    #100
    kuato
    kuato New Member
    Dave
    Sunnyvale, CA
    '15 TRDP
    For what it's worth, my front bumper cover had these gaps on both sides. Attributed it to taking off the cover too many times for lighting mods. Came across the following link and ordered the replacement brackets (a bit pricey to buy when not covered under warranty). Installed this myself about a month ago and it's holding up well so far and looks great.
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10183270-9999.pdf
  11. Dec 3, 2023 at 9:08 PM
    #101
    My passenger side needs help, and isn’t too bad, so maybe this might work for me…
