Front bumper issue
Discussion in '5th Gen 4Runners (2010-2024)' started by lyodbraun, May 22, 2019.
  1. Jun 30, 2022 at 9:39 AM
    #61
    lyodbraun
    lyodbraun [OP] New Member
    Northwest Ohio
    2018 4RUNNER
    Maybe try some epoxy putty, I used some on mine to hold, it’s not 100% flush like it should be but way better than always walking by and pushing it into place just for it to pop out again.. I even tried new pieces that it clips to and still didn’t help ..
  2. Jun 30, 2022 at 12:09 PM
    #62
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    TLCA #25089
    Yes
    Steve40th[QUOTED] likes this.
  3. Jun 30, 2022 at 12:23 PM
    #63
    I think she is asking for the Viper Cut. Problem solved.
  4. Jun 30, 2022 at 1:30 PM
    #64
    MeefZah
    Lexington, Ohio
    GX460
    TLCA #25089
    That sounds hot, like a landing strip but more dangerous
  5. Jun 30, 2022 at 2:46 PM
    #65
    aRabidLunatic
    aRabidLunatic New Member
    2014 4Runner Limited
    Where did you put the epoxy? right below the tabs?
  6. Jul 1, 2022 at 3:22 AM
    #66
    lyodbraun
    Northwest Ohio
    2018 4RUNNER
    yup filled the area up and then held it in place while it set, I often wondered if that power grab caulk would have worked ?
  7. Jul 1, 2022 at 4:32 AM
    #67
    Steve40th
    Steve40th New Member
    sTEVE
    Thnx. I can see it would make a difference. Its a precise bend though. Trial and error for sure.
    MeefZah[QUOTED] likes this.
  8. Jul 2, 2022 at 12:55 PM
    #68
    Steve40th
    sTEVE
    Well, I didnt even get down the street after my bumper sat for 3 weeks while on travel, with velcro holding it on. Passenger side just popped off.. POS> What a worthless design.
    I guess I need a new bumper or time to sell it. I am not going to drive a 40+ thouand dollar vehicle where panels are falling off of it and Toyota says Velcro it. BS>
  9. Jul 2, 2022 at 6:33 PM
    #69
    Steve40th
    sTEVE
    Well, went a little redneck on it and fixed it, well made it stay till I can honestly evaluate the fix. Probably a new bumper and such.
    I went and put a temporary zip tie into a bracket near the windshield washer fluid. Its a metal one. And, the other end of the zip tie went into the bumper, chrome section of the limited, that attached to the cover. I took its clip out and ran the zip tie through it. Then, lightly pushed on bumper cover and sinched the zip tie.
    Then went on a very bumpy ride for 20 plus miles. Bumper stayed..
    Its a temp fix, but it is holding so far.
    I am fairly certain the passenger side fender front needs to be bent out a little after it was hit and it will allow the bumper to hold in place.
  10. Sep 5, 2022 at 6:59 PM
    #70
    Nino
    Nino New Member
    2020 4Runner Limited Nightshade
    Same here folks. This actually drove me to seek guidance from the forum. I have a 2020 Limited Nightshade with this issue. Took it to the dealership and was told its not covered by the 3 year warranty. And Body issues are only covered under the 1 year warranty. Didn’t know that was a thing?! I was told to seek help from an independent body shop. Service rep said “we’ve never seen this before?”
    Yeah right, get out of here! I think my next move is to contact Toyota directly to start a claim? Thoughts anyone?
  11. Sep 5, 2022 at 9:29 PM
    #71
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    I had the same issue on at 2015 LE and it was annoying to say the least. Unfortunately I didn't notice it until after the warranty period. Chase the dealers down while you have a chance! I blew it and my time passed. Hold their feet to the fire, or replace it with an after market bumper like some others (including myself) have done. For me, the C4 Overland bumper has fixed it. Don't ask me why, because the part that popped out is still there!o_O
  12. Sep 6, 2022 at 3:24 AM
    #72
    Steve40th
    sTEVE
    Ever since I did my band aid zip tie fix, I have druven from Norfolk VA to Pensacola Fl and back to Charleston SC. Still in same spots. Is it the right thing to do, nope. But, its visually working on the LE I have.
    Harringbr99 and aRabidLunatic like this.
  13. Jan 25, 2023 at 5:03 AM
    #73
    Steve40th
    sTEVE
    Just an update, after 6 months , bumper has not moved. Zip ties seem to be working for my limited, to keep bumper in position it came from the factory.
    Harringbr99 and Curlystooge like this.
  14. Jan 25, 2023 at 4:07 PM
    #74
    BitterUte
    BitterUte New Member
    2014 4Runner SR5
    Yeah I did this repair per the linked Toyota Service Bulletin. There was improvement, but it did not completely go away. I could not see any difference in the brackets. The big change was adding a patch of double hook Velcro to the bumper and the bracket, so really you can save yourself the bracket cost and just do the velcro portion. Basically the bumpers wear out an lose their hold where they snap together. We’ve got the same issue on the driver’s side of the rear bumper but that was due to my wife backing into something.
    Steve40th likes this.
  15. Jan 25, 2023 at 4:25 PM
    #75
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Yep same here on the drivers side of my 2018 Limited as well. Drives me nuts looking at it. It’s one of those I’ll get to it projects.
  16. Nov 28, 2023 at 10:52 AM
    #76
    Thread revival. Do you suppose there is any way to attach a piece of wire to the bumper cover right at or near the area circled in yellow below, and run that wire through the plastic brackets on the vehicle to pull that section of the bumper cover in tighter (similar solution to the zip tie procedure previously mentioned)?
    I ask because I've never had my bumper cover off; I'm thinking removing it will simply make the problem worse. If I knew I could do what I'm asking, I'd go for it.
    Mine is not as bad as some I've seen, but it bugs me every time I look at it.
    (Photo 'borrowed' from @djwantke in another thread :cool:)
    djwantke likes this.
  17. Nov 28, 2023 at 11:00 AM
    #77
    Steve40th
    sTEVE
    I would recommend attaching it to metal. Plastic will get over stressed and break. On the Limited I did just that, ran it through metal , with metal zip ties.. I am pretty sure my pics show it.
    Look and see if there is metal on the bumper you can use to pull bumper in.. Good Luck.
  18. Nov 28, 2023 at 12:43 PM
    #78
    @djwantke - when you had the bumper cover off for the aftermarket tiedown installation in the photo above, would you have noticed if there might be any metal in that bumper cover to attach a piece of wire to? Trying to find a solution to that area just not seating all the way in...thanks!
  19. Nov 29, 2023 at 12:20 AM
    #79
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @glwood54 hey my friend, I actually still have my front bumper off (life is busy it's taking me a minute to finish recovery points, at least that's what I keep telling my wife).
    So I took some photos for ya'll. I think I follow what your asking, but not 100%. Take a look and see. I can take more photos tomorrow night and then the bumpers going on.
    Funny thing is, I HAVE THIS SAME ISSUE TOO haha
    I'll be watching thanks guys
  20. Nov 29, 2023 at 12:22 AM
    #80
    But I think my bumper clip issue is from creating a new path through 100 yards of prickle bushes n saplings
  21. Nov 29, 2023 at 6:29 AM
    #81
    Thanks for all those! What would be great are photos of the back side of the bumper cover, specifically right at the corner that is under the passenger side headlight (location circled in post #76. Is that what is pictured in your 5th photo in this post?
    That is where my bumper cover isn't flush.
  22. Nov 29, 2023 at 6:42 AM
    #82
    I'm also curious at what the corresponding clips or tabs on the back side of the bumper cover look like that hold the cover on to the body in this area...
  23. Nov 29, 2023 at 7:51 AM
    #83
    Ahhh, Yes!
  24. Nov 29, 2023 at 8:45 AM
    #84
    EC15
    EC15 ...
  25. Nov 29, 2023 at 11:49 AM
    #85
    Thank you.
    One last question - are these two photos of the driver's side of the bumper cover?
  26. Nov 29, 2023 at 11:51 AM
    #86
    Yes sir
  27. Nov 29, 2023 at 11:53 AM
    #87
    [I bought a passenger side fog light back cover from the stealership and jerry rigged it on drivers side, after stage 2 high clearance cut]
  28. Nov 29, 2023 at 11:59 AM
    #88
    It's my passenger side that is giving me fits, so I'm still on the hunt for photos of the back side of the PS of the bumper cover...
  29. Nov 29, 2023 at 12:13 PM
    #89
    I'll post you a photo of passenger side tonight brother
  30. Nov 29, 2023 at 12:15 PM
    #90
    Great, thank you.
