From 5W-30 to 0W-20
Discussion in '5th Gen 4Runners (2010-2024)' started by T92, Apr 20, 2025 at 2:23 PM.
  1. Apr 21, 2025 at 1:24 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Idk man I've damn near overheated twice.
    I think when Toyota says "extreme load conditions" it includes bolting on some 34" tires and wheeling for 8 hours straight in 120 degree weather. Seeing coolant temps of 235+... nearly boiling over.
    The other time was in the California desert. Going 80+ mph on the highway, hauling a few hundred lbs of gear. 115F degrees outside... on a slight uphill for a couple hours. Coolant temp was over 230.
    I consider these to be extreme load conditions.
  2. Apr 21, 2025 at 3:33 PM
    JohnD
    JohnD New Member
    Been running 5/30 for six years and 50k and it’s still going.
  3. Apr 21, 2025 at 6:59 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    5/30 sure makes the engine sound quieter
  4. Apr 22, 2025 at 6:17 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    230F is hot- imagine tranny temp! Perhaps new engine oil and new tranny ATF after a hot extreme load trip would be a good idea.
  5. Apr 22, 2025 at 6:21 AM
    1SilverRunner
    Tejas
    Tranny temp was over 245 at the converter when wheeling in palo duro canyon that time. Did a flush when I got home.
    I'll be adding some additional cooling soon.
    Toy4X4 likes this.
  6. Apr 22, 2025 at 8:57 AM
    I’d agree, especially since when toyota uses the word “severe” to define service intervals, it’s what most people do normally.
    So when they use the word “extreme load conditions”, I would definitely interpret it to mean anything that is not a stock, empty 4runner driving on flat ground at 55mph.
    While I run 0w30, I’ll admit I do change to 0w20 in winter, just because of how damn cold winters can get here.
  7. Apr 22, 2025 at 7:32 PM
    Hungryhawk
    Southern CA
    2017 SR5
    Here is an interesting list of temperature and life of fluid that seems relevant here.IMG_7424.png
    Toy4X4 likes this.
  8. Apr 22, 2025 at 10:24 PM
    icebear New Member
    I’m pretty sure those numbers are from a very out-of-date infographic but don’t come after me if I turn out to be completely wrong.
    3JOH22A likes this.
  9. Apr 23, 2025 at 5:20 AM
    1SilverRunner
    Tejas
    :threadjacked:
    Alright here's the thing guys. Do we need another oil debate thread?! We've already veered off topic (sorry)
    I propose we all just shift the conversation to transmission fluid because that will fail before the 1GR-FE does... Especially if you stay on top of oil changes.
    So, with this proposition out there... I was thinking about adding a Hayden 678 transmission cooler. Only problem is I'm not sure if it's quite big enough.
    A few companies making brackets for it as well. Looks like a very easy install.
    https://goliathoffroad.com/products/4-runner-transmission-cooler-bracket?variant=49409409646839
    Anyone with experience of running a cooler that does not require AN lines?
    2021venture likes this.
  10. Apr 23, 2025 at 6:08 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    AN lines?
  11. Apr 23, 2025 at 6:13 AM
    1SilverRunner
    Tejas
    Some coolers use AN (ARMY/NAVY) fittings and lines.
    While this would be cool it adds some additional cost and complexity. The factory system uses hard lines and rubber hose. I'd prefer just using some rubber hose and hose clamps. Just me being lazy really.
    Note to the mods: If this topic change annoys you please delete. :laugh:
    It would be better suited here anyways
    https://www.4runners.com/threads/5th-gen-trans-cooler.11238/page-2
  12. Apr 23, 2025 at 6:41 AM
  13. Apr 23, 2025 at 8:15 AM
    1SilverRunner
    Tejas
    Sure enough, looks about the same.
    I’ve decided to get buy a Derale 13504 cooler. It’s quite a bit bigger and should provide some serious cooling.
    Should be prepared for the Texas heat real soon.
    If I keep experiencing engine heat trouble I may consider a CSF radiator as well. But for now I’m more concerned with the transmission temps.
  14. Apr 23, 2025 at 10:50 AM
    Schlappesepple
    2020 ORP
    Is it very dusty where you wheel? And have you ever cleaned the radiator? Maybe think about the fan clutch too, I think that's an easy test.
    I'm sure it's hot as fuck down there, and that's probably the main problem, but it wouldn't hurt to make sure every part of the cooling system is working at its best.
  15. Apr 23, 2025 at 10:52 AM
    Schlappesepple
    2020 ORP
    And I don't know what speeds you're running at, and you've probably already done this, but I'd try dropping into low range / limiting the trans to a lower gear to let the engine rev higher. My 4R will drop temps significantly when dropping a gear, even when speed seems "fine" for the current gear.
  16. Apr 23, 2025 at 11:11 AM
    1SilverRunner
    Tejas
    I should definitely clean it although I doubt that's the problem since during normal driving on the street it has no trouble staying cool. Over 110 degrees outside and slow wheeling I see temps start going up. There's just no airflow at this speed.
    I will say, it wasn't just me. Everyone with some sort of scan gauge or monitoring system was watching coolant and trans temp climb.
    For wheeling I'm in 4lo S1 or S2.
    For gear hauling I leave it in 2hi. If I start gear hunting I'll keep it in S4 which helps tame transmission temp.
    Honestly I think its normal operation. I'll add a trans cooler cause it's cheap and easy to do.
    On the road (even in tx summer heat) it's not often I see coolant temps climb like that. But... Death valley is named appropriately.
  17. Apr 23, 2025 at 11:29 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    The reason the oil keeps getting thinner is it reduces pumping loss because a syrup oil is harder to pump than a watery oil and that affects fuel economy. When in doubt, follow the owners manual (unless they claim it's a lifetime fluid).
    If I owned a car where the manufacture suggested a heavier oil for the same engine when they didn't have fuel economy standards to meet I'd go with the heavier oil because why would they suggest a heavier oil if it had no advantage? Everyone wants better fuel economy, they wouldn't forgo it if there was 0 drawback to using lighter oils. In very cold climates, I'd use the lighter oil if instructed.
    Air cooled engines also use heavier oils because they're normally operating at higher temperatures because air cooling is less effective. My Honda XR used 10W40, and when I'd check the oil after hard use it was not a 40 weight oil, it was more like 20 or 10 weight. So if you start off with an oil that's already light, you'd have no protection once you got up to temperature because the heat is so great.
  18. Apr 24, 2025 at 5:53 AM
    1SilverRunner
    Tejas
    Another consideration is fuel contamination.
    Some fuel and carbon will always leach past your piston rings and get into you oiling system. This is why oil turns black. And too much fuel mixed with the oil is problematic because 1. It displaces oil. and 2. it changes the viscosity of the oil.
    This is why I'm an advocate of frequent oil changes. Regardless of oil type.
    Now, if you're in an area that doesn't get very cold but the summers are very hot, I'd consider moving toward a heavier weight. Especially if you operator the vehicle under what you'd consider "extreme load or high speeds"... Although these are Toyota's words directly from the manual I believe they are purposefully ambiguous.
    Granted, most engine wear will occur during a cold start, so that's the trade off. 0w-20 will arguably be a better oil for this. So if you're the type of person to make short trips and never really get the system very hot 0W-20 and frequent oil changes will probably be the best bet.
    On the other hand, if you are the type of person to "cold start" your rig when it's 90F outside, then proceed to drive through a desert or go wheeling for hours straight, I really do think a heavier weight is a good option for you.
    Regardless, the heart of your post is correct... heat is a real killer. Oil contamination will happen so frequent oil changes help a ton. But any fluid exposed to heat will start to break down. This is why I choose 5w-30 for my summer climate, and 0w-20 for winter. Change the oil every 5k miles, and transmission flush every 50k (or every time it goes over 230F)
    Hungryhawk likes this.
