Freedom UCAs
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Apr 2, 2024.
  1. May 5, 2024 at 7:00 PM
    I think the OP has stock UCAs, which means factory rubber bushings.
  2. May 6, 2024 at 5:28 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Yes. I don't think factory quality is as good as it was. My bushings are better than some newer models I have seen for steering rack. I have never worn out any rubber ones in anything in 45 years driving. I read all the reviews, some using for last 3 years, and they were highly rated. I don't abuse mine off road and don't expect any problems. I can destroy anything not trying and I have never replaced much of anything on a 4runner under 300k. I know I wanted polyurethane control arm bushings for durability, but I read about the squeaking. I synthetic grease all mine poly bushings and greasable sway bar brackets. I saw a guy with Chevy at alignment shop who paid $7k for suspension install and he was looking for squeak while driving also.
  3. May 6, 2024 at 9:35 AM
    When I did my dobinsons lift, I kept my factory UCAs. I didn’t know it then, but the factory rubber bushings and ball joints are much quieter and less of a maintenance headache than a lot of aftermarket options. I don’t have great caster numbers, but they are good enough for me. I got something like 0.1 degrees outside of minumum spec on caster. It just makes it a little lively. It doesn’t wander, but needs little micro-corrections on normal interstate roads. On farm roads that pitch and roll, you have to stayon top of it though, as the 4runner will easy follow gravity. On regular roads, big bumps will cause the wheel to move in response, but I’d categorize that as feedback, not actual bump steer forces.
  4. May 6, 2024 at 9:42 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    They do wander naturally with big tires or without. I usually drive far left or right out of traveled way if I can. I'm used to driving 4wds and I don't think about it. Mine is sensitive like that to. That little out of spec shouldn't matter. Sometimes it's crown of road and condition.
