Fog lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Overland WT, Nov 13, 2022.
  1. Nov 28, 2022 at 10:13 PM
    #121
    The oem fog lights don't have a separate bracket that can be reused - it's part of the light housing. So yes, just the screws are reused.
  2. Nov 29, 2022 at 3:44 AM
    #122
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    ^^^^ This.
    4runningMan likes this.
  3. Nov 29, 2022 at 2:27 PM
    #123
    4runningMan
    4runningMan New Member
    New Mexico
    Anyone have a close up shot of the DD Pro after proper aiming? I’m wondering what the angle looks like so I have a good starting spot at time of install.
  4. Nov 29, 2022 at 4:17 PM
    #124
    romad86
    romad86 New Member
    I wasn't able to do the 25' thing, so I used painters to tape to mark on the wall where the top of the beam pattern was on my outgoing lights.
  5. Nov 29, 2022 at 4:27 PM
    #125
    4runningMan
    New Mexico
    I can’t find the thread now. But someone mentioned the positioning of the light in the bracket. Too far forward or backward and you couldn’t adjust it down (or something like that). Anyone remember their positioning in the bracket?
  6. Nov 30, 2022 at 4:07 AM
    #126
    Metalsaber
    Metalsaber New Member
    Mine should be out for delivery today. Hopefully get them installed tonight as well.
  7. Nov 30, 2022 at 4:12 AM
    #127
    Too Stroked
    Tom
    2021 SR5 Premium
    If the pod is positioned too far forward in the bracket, you will limit the amount of aiming possible.
  8. Nov 30, 2022 at 11:40 AM
    #128
    Metalsaber
    Got my fog lights installed. Just used the tape method for now. Man even with stock size tires, it's a PITA getting your hands in there and tightening stuff done. Will get it out tonight and see how they look. even in the garage, they had a nice cutoff at the top and had a much wider beam.
  9. Nov 30, 2022 at 11:55 AM
    #129
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    Installed some 4Bangers for fog lights and I can't get it down far enough =(
    @Metalsaber Yeah it's a pain to get it to. Out of frustration, I just remove the bumper.
  10. Nov 30, 2022 at 12:07 PM
    #130
    Too Stroked
    Tom
    2021 SR5 Premium
    Truth be told, by the time you get all of the 10mm fasteners out of the inner fender well / liners, it's only another 5 minutes of work (and no tools) to remove the whole bumper cover.
  11. Nov 30, 2022 at 4:25 PM
    #131
    4runningMan
    New Mexico
    I installed my Pro’s. Initial impression… beyond satisfied. The glare is insane, but I knew that going in. They light up the tree tops. Even when aimed very low, it’s unavoidable.
    I actually wanted something that would double as an off-road light, as I only use fogs on the road in the most extreme low-visibility conditions.
    Install was a breeze, but yeah it’s tight going in through the fender well. I’d recommend getting an “L” shaped allen wrench for aim adjustment instead of the “all in one” type wrench that I had on hand. There’s room to adjust the inner bolts from underneath the truck. But the outter bolts aren’t visible from under the truck and they’re hard to get to from the fender. It’s just an odd spot to reach and see. Especially with a chunky allen wrench set.
    jvinhj240 likes this.
  12. Nov 30, 2022 at 4:40 PM
    #132
    jvinhj240
    jvinhj240 New Member
    Ben
    wow, you guys really having a hard time reaching in unscrew? tơok me less than 5 mins to take them out.
  13. Nov 30, 2022 at 5:23 PM
    #133
    4runningMan
    New Mexico
    I only had trouble working with the allen wrench on the outer adjustment screws. Everything else was easy.
    jvinhj240[QUOTED] likes this.
  14. Dec 2, 2022 at 4:35 AM
    #134
    Metalsaber
    So I'm still working through adjusting the fogs to get them proper. It's harder finding a place that has nice flat ground and has a distance of 25' away to get them properly aimed. I've adjusted them higher than originally installed so they throw further out than before. They have a definite cutoff. So if you were an owner of the Pros, I would highly suggest you think about what this means. Someone posted in a youtube video about them being over priced in comparison to the Pros with less output. That's not true. What they are seeing is that there is less spill in comparison to the Pros which makes it appear as if they have less output. The Pros lend themselves to poor road etiquette imo as they are likely offensive to oncoming traffic if adjusted to a point that appears good to the driver. The max allows you to adjust for further out but without the spill. So again, just a caution as people considering upgrading might consider it a downgrade.
    donnermel likes this.
  15. Dec 2, 2022 at 6:21 AM
    #135
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    25 feet not yards.
  16. Dec 2, 2022 at 6:48 AM
    #136
    Metalsaber
    Yeah 25'. My typo.
  17. Dec 2, 2022 at 6:56 AM
    #137
    romad86
    romad86 New Member
    I had the same problem, so that's why I just did the tape in my garage since the previous ones were aimed at 25'.
  18. Dec 2, 2022 at 7:09 AM
    #138
    Metalsaber
    I did the tape initially with my factory fogs but they were pointed so low the new fogs were of no actual benefit.
  19. Dec 2, 2022 at 7:44 AM
    #139
    Too Stroked
    Tom
    2021 SR5 Premium
    That's pretty much my experience in going from the Pro to the Max.
  20. Dec 2, 2022 at 8:27 AM
    #140
    4runningMan
    New Mexico
    I installed my Pros and pushed them all the way forward in the bracket so they contacted the surround on the truck. Then I pushed the bottom of the Pro back so there’s about a 1/4” gap (or slightly less). I left the top of the fog light in contact with the surround.
    Seems to result in a pretty good aim.
    Stoney Ranger likes this.
  21. Dec 2, 2022 at 4:07 PM
    #141
    romad86
    romad86 New Member
    That sucks. Definitely makes it more difficult for you to get good aim.
  22. Dec 2, 2022 at 4:58 PM
    #142
    Hans Moleman
    Hans Moleman New Member
    SF Bay
    I bought the SS3 Pro white fog light. I’m going to aim them like a headlight because the stock headlights with Morimoto 2Strokes LED bulbs are pretty poor.
  23. Dec 2, 2022 at 5:08 PM
    #143
    Too Stroked
    Tom
    2021 SR5 Premium
    Based on personal experience, I think you're going to find that oncoming drivers won't like that aiming. Remember, the Pros are significantly more powerful than a low beam headlight.
  24. Dec 2, 2022 at 5:27 PM
    #144
    Hans Moleman
    SF Bay
    I would say 50% here drive with their high beams on so I don’t mind blinding them back.
  25. Dec 3, 2022 at 12:03 PM
    #145
    bigwood
    bigwood New Member
    Kirk
    22 4Runner sr5
    I have the Baja designs, I am sure that there are probably equal quality loghts available from brands for less money.
  26. Dec 21, 2022 at 9:09 PM
    #146
    Hans Moleman
    SF Bay
    I just installed SS3 Pro white fog lights. The width, throw, and brightness are insane. It was hard to aim because there is no sharp cutoff. I tried to aim them a tad lower than the the low beams. They also have more throw than Morimoto 2Stroke low beams. Now I must do something about my terrible low beams.
    I always notice Teslas usually light up the road to the extreme and over power the lights of most cars around them. Now driving next to a Tesla my SS3 Pro fog lights over power their lights.
  27. Dec 21, 2022 at 10:38 PM
    #147
    4runningMan
    New Mexico
    I got the Pro yellows. They’re insane, I agree lol. I love them. But the glare for oncoming drivers is also insane, so I’m cautious when/where I use them. I just kinda treat them like I would a high beam. Do I really need to be using them while driving around town? Absolutely not, although I’d like to.
    Fortunately, you can aim them super low and still get huge benefit. It’s tempting to aim higher, but it’s simply not necessary in my experience with them.
    Too Stroked likes this.
  28. Dec 22, 2022 at 4:12 AM
    #148
    Metalsaber
    I was looking at some of the youtube videos of people saying how great their fogs were and showing them off and they are aimed the same height as their low beams. The fogs should never throw as far as your low beams otherwise you haven't aimed them properly and are blinding oncoming traffic.
    glwood54 and Too Stroked like this.
  29. Dec 22, 2022 at 12:28 PM
    #149
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Good on you for judicious use of your fogs. A low beam angle on wet, or really any shiny road surface, can create severe reflected glare to oncoming cars.
    I use my fogs a lot when turning into dark streets or parking lots to light up the dark corners better.
    4runGirl88 likes this.
  30. Dec 22, 2022 at 2:01 PM
    #150
    4runningMan
    New Mexico
    Yep I tap mine on quick for wide cornering light too.
    You saying that if fogs are aimed too low, they can cause road glare to other drivers?
