Fog lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Overland WT, Nov 13, 2022.
  1. Nov 14, 2022 at 7:35 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Just figured it would be wicked cool to see some Picts, but yes, I could just search the net.
    4runGirl88 and Thatbassguy like this.
  2. Nov 14, 2022 at 9:23 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Pics from members are always more fun than google image searches!
  3. Nov 15, 2022 at 5:08 AM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    You can only see one, but I liked how they looked.
  4. Nov 15, 2022 at 6:15 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Diode Dynamics SS3 Max fogs - plug and play replacements for OEM LED fogs. DD SS5 Spot beams behind the grill.
  5. Nov 15, 2022 at 8:26 AM
    4runningMan
    New Mexico
    I was disappointed to learn the DD 6” stage series light bar kit doesn’t fit 2019 and up. Maybe your set up is better?
  6. Nov 15, 2022 at 9:20 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    I had a 30" DD Stage (all driving pattern) LED bar in the lower grill on my Tacoma before trading it in on the 4Runner. I believe the SS5's are actually better.
  7. Nov 15, 2022 at 9:28 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    If you want use on road, I like OEM LED fog lights. Best cutoff for street use and really wide spread.
    I have some BD Squadron Sport amber as forward facing aux offroad lights.
    Have DD SS3 Pro fogs on my other truck and they are kinda too bright for street use even when properly aimed. I mostly treat them same as high beams.
    4runningMan likes this.
  8. Nov 15, 2022 at 9:53 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
    DD SS3 Sport
  9. Nov 15, 2022 at 3:38 PM
    Too Stroked
    Tom
    2021 SR5 Premium
    I'm normally a huge fan of OEM parts. (Working in a Toyota Parts department will do that to you.) That said, there are a number of much better performing aftermarket fogs out there. In fact, Diode Dynamics latest Elite series LED fogs put a pretty good hurting on the OEM LEDs as do their Sport model.
    The LED SAE J583 Fog Pod & Fog Light Review | Tacoma World
    As for the Pro model being "too bright" for the street, having run a set in my T4R, I would propose that it's more of a beam pattern problem than a power problem. The Sport has a nice, tight horizontal pattern. (The Elite has an even tighter pattern.) The Pro uses a more powerful diodes that causes the beam patten to have much more "bleed" above and below the center of the pattern. Even when properly aimed, that bleed bothers oncoming drivers.
    The Max has even higher-powered diodes, but better beam discipline. Properly aimed, these actually work better than the pros. In fact, I would only recommend the Pros for off-road use. Truth be told, I swapped clear driving beam lenses into my Pros and run them on one of my other vehicles now. Set up this way, they make a great auxiliary high beam.
  10. Nov 15, 2022 at 7:11 PM
    4runningMan
    New Mexico
    Anyone have night time output shots of the Sports?
  11. Nov 16, 2022 at 2:19 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Low beam not super bright. Very sharp cutoff. Cant see far.
    End up driving with auto high beam most times.
    Don't understand the rationale behind bi low/high beam.
    Cheers
  12. Nov 16, 2022 at 6:59 AM
    Metalsaber
    Metalsaber New Member
    Nice. I'm planning on ordering the DD SS3 Max Fogs if they have a black friday sale. Want to get them before winter comes through.
    kolter45 and Thatbassguy like this.
  13. Nov 16, 2022 at 9:05 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    The absolute only place I order all of my lighting from:
    Hotshot Offroad
    The best customer service on the planet!
  14. Nov 16, 2022 at 9:09 AM
    Metalsaber
    Thanks for the tip. Still waiting for a sale though.
  15. Nov 16, 2022 at 9:13 AM
    I'll second the recommendation for Hotshot Off-road. Maybe @memario1214 can give us a hint of what they're going to do for Black Friday. :notsure:
  16. Nov 16, 2022 at 3:17 PM
    Overland WT
    Overland WT [OP] Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    That's the point. They are intended to increase visibility at ground level to better see the lines and debris in low light situations. They are not intended to throw light a long way out, hence the cut off.
    Not sure what you mean...?
  17. Nov 16, 2022 at 4:48 PM
    romad86
    romad86 New Member
    How did you end up mounting the SS5s? Did you build a bracket, or do the DD brackets for their light bars happen to work?
  18. Nov 16, 2022 at 4:51 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    This is true. My pros are BRIGHT. Almost to bright. The sports are probably perfect. I can't imagine the maxx.
  19. Nov 16, 2022 at 5:27 PM
    #49
    totmacher
    Daniel
    West TN
    The DD Elite kit looks good. Wasnt an option last time i bought lights.
  20. Nov 16, 2022 at 5:28 PM
    #50
    Too Stroked
    Tom
    2021 SR5 Premium
    I used a Rago Fabrications bracket and cross bar kit.
    Gharddog03, kolter45 and 4runningMan like this.
  21. Nov 16, 2022 at 10:28 PM
    #51
    4runningMan
    New Mexico
    Does having the lights behind the grille result in any weird beam pattern blemishes?
  22. Nov 16, 2022 at 10:29 PM
    #52
    4runningMan
    New Mexico
    I’m torn between getting the sport vs pro for this reason.
  23. Nov 17, 2022 at 1:15 AM
    #53
    romad86
    romad86 New Member
    Ah, nice. I’ll check that out. Thanks.
  24. Nov 17, 2022 at 1:20 AM
    #54
    romad86
    romad86 New Member
    I’d look at the Max too. It has a defined cutoff and has better output than the Pros. I have the Pros and have never had an issue when passing oncoming drivers in the situations I’ve had them on.
  25. Nov 17, 2022 at 6:30 AM
    #55
    This is the only one I have at the moment-
    After some adjustment of aim:
  26. Nov 17, 2022 at 8:44 AM
    #56
    4runningMan
    New Mexico
    The high temperature on the max’s kinda freaks me out lol. I know it’s probably fine but it still freaks me out.
  27. Nov 17, 2022 at 9:15 AM
    #57
    romad86
    romad86 New Member
    Haha, yea it’s insane. In that fog light thread that was linked for Tacoma World, it’s explained in there as completely normal and that the heat won’t damage anything on your vehicle. At least, I’m pretty positive that’s what I remember reading.
  28. Nov 17, 2022 at 9:24 AM
    #58
    romad86
    romad86 New Member
    I thought I had a decent output shot of the Pros at night, but I guess I don’t. This is the only one I could find for reference.
  29. Nov 17, 2022 at 10:53 AM
    #59
    Overland WT
    Bryan
    West Texas
    2017 TRD Off Road
    Heat is not a bad problem in cold/snow weather climates. Lots of LED's suffer from lack of heat and lack of melting ice and snow on contact.
  30. Nov 17, 2022 at 11:10 AM
    #60
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Diode Dynamics should be having a black friday sale soon.
