Fj cruiser shift knob mod
Discussion in '5th Gen 4Runners (2010-2024)' started by Pavo, Aug 29, 2022.
  1. Oct 2, 2022 at 10:19 PM
    The best thing about the FJ shift knob is you can tighten it down snugly without having to line up any letters. I tried a new black oem TRD Pro knob, and I could not get it to stay lined up or tight. It may have been defective - I returned it for a refund.
  2. Oct 3, 2022 at 8:42 AM
    Pavo
    Pavo [OP] New Member
    It is not loose, try doing it again at another position
  3. Oct 3, 2022 at 8:44 AM
    Pavo
    It's black, feel is subjective both the stock and this one are fine but I did it because I think it looks cooler
  4. Oct 3, 2022 at 4:55 PM
    wolfman
    wolfman New Member
    Hmm weird. I tried removing and reinstalling and I get the same issue. When tight the graphic is completely off by a good 90 degrees or so. Damn it.
  5. Oct 4, 2022 at 4:35 AM
    jsucraig
    jsucraig New Member
    Craig
    Lynchburg, VA
    2022 4Runner TRD OR/Premium - Nautical Blue
    Garmin Dashcam Mini2, FJ Shift Knob, Meso Customs Map Lights, LED Int/Ext Lights, Salex Organizers, Mudflap Delete, Uni Filter Mod, Amp Research Power Steps, Ceramic Tint
    There is only one set of threads, it will always 'start' at the same point no matter where you start to turn the knob. One way to index the knob in the propper direction is to wrap the treads with PTFE (Thread Tape) like what is used in piping https://www.lowes.com/pd/Oatey-0-6-in-x-43-ft-Plumber-s-Tape/4751313
    wolfman[QUOTED] likes this.
  6. Oct 4, 2022 at 3:48 PM
    wolfman
    wolfman New Member
    Plumbers tape! Awesome idea! I didn't know if it was "safe" for something like that. Good idea. I am going to give it a go. Thank you!
  7. Oct 5, 2022 at 4:27 PM
    wolfman
    wolfman New Member
    Just did it. Great suggestion, thank you. Worked perfectly. 7 revolutions of plumbers tape and it aligns perfectly. Thanks again!
    jsucraig[QUOTED] likes this.
  8. Oct 5, 2022 at 6:18 PM
    jsucraig
    jsucraig New Member
    Craig
    Lynchburg, VA
    You're welcome
  9. Oct 16, 2022 at 9:53 AM
    jsucraig
    jsucraig New Member
    Craig
    Lynchburg, VA
    I just replaced the TRD Shift Knob in our 2022 TRD ORP and didn't need to modify anything. I didn't crank down the FJ Knob, just enough for it to feel tight.IMG_2884.jpg IMG_2885.jpg
    rickystl likes this.
  10. Oct 16, 2022 at 1:57 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    This is a great mod. (I did the cutting of center section option). Now the transmission shifter matches the transfer case knob. As long as I was at it I got a bottle of black acrylic paint from the hobby store and filled in the recessed indications. Brush it on then wipe it level with a damp paper towel like a squeegee.
    MeefZah, 4runningMan and rickystl like this.
  11. Oct 21, 2022 at 6:04 PM
    jsucraig
    jsucraig New Member
    Craig
    Lynchburg, VA
    I went with red
    MeefZah, hvac guy and rickystl like this.
  12. Feb 25, 2023 at 5:31 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Does the top of the FJ knob sit higher or lower than the original position of the TRD knob?
  13. Feb 25, 2023 at 9:02 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If I’m remembering it correctly the FJ knob sits a little lower. In any case it’s really comfortable for me.
