First Oil Change
Discussion in '5th Gen 4Runners (2010-2024)' started by WGS, Nov 13, 2022.
  1. May 23, 2023 at 4:54 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Most people get rid of vehicles before the extra maintenance changing fluids early or with synthetic products matter. Most anything will last 100k. Keeping it for 20 years or several hundred thousand miles is a different goal than replacing every 5 years.
    TEQLC likes this.
  2. May 23, 2023 at 4:58 PM
    TEQLC
    TEQLC New Member
    2023 Solar Octane Pro 4R, 2016 MGM Trail Prem 4R
    Rocko9999[QUOTED] likes this.
  3. May 23, 2023 at 5:03 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    'Lifetime' fluid is lifetime of warranty.
  4. May 23, 2023 at 5:07 PM
    2021venture
    Todd
    2021 Venture
    I think the service schedules are designed to keep maintenance costs low. This is more important to the masses than what's the best for vehicle longevity. I do not believe in lifetime fluids. Everything degrades with use over time. Fresh fluids give me piece of mind knowing I am not running them all the way to end of life. But I am the guy that is happy changing the synthetic oil at 5k knowing it can go to 10k.
    Rocko9999 likes this.
  5. May 24, 2023 at 10:58 AM
    2016Pro
    Mobil one doesn't do anything different than any other oil. Don't fall for all of the commercials
  6. May 24, 2023 at 11:06 AM
    What do you choose for oil?
  7. May 24, 2023 at 6:55 PM
    2016Pro
    Whatever is on sale, supertech from Walmart is a good one
  8. May 24, 2023 at 8:01 PM
    Just because it has Super in the name doesnt mean it great. Don't fall for all of the commercials.:muscleflexing:
    2016Pro[QUOTED] likes this.
  9. May 25, 2023 at 3:56 AM
    2016Pro
    Lol, good one.
  10. May 25, 2023 at 4:29 AM
    Thx! All kidding aside, imo if you’re using any brand of synthetic in the engine, you’re good. Same for front and rear diffs. Transfer case is a different story, thats is type specific: Toyota Genuine Transfer gear oil LF or equivalent SAE 75w. I personally use Redline MT-LV (after much research) in my transfer cases and drove thousand of miles in my 4Rnrs without any negative side effects. But again, to each his own.
    2021venture likes this.
  11. May 25, 2023 at 5:08 AM
    2021venture
    Todd
    2021 Venture
    2016Pro likes this.
  12. May 25, 2023 at 12:26 PM
    2016Pro
    Redline won't do any Magic either
  13. May 25, 2023 at 1:38 PM
    True but I won’t spend $40-$60 a quart for the Toyota brand stuff
  14. May 26, 2023 at 4:21 PM
    Philpilsner
    Philpilsner New Member
    First oil change should be at 500-1,000..
    And then every 5k
  15. May 26, 2023 at 9:26 PM
    achtung6
    achtung6 New Member
    Exactly!
  16. May 26, 2023 at 9:27 PM
    achtung6
    achtung6 New Member
    This is exactly what I did. I plan to have this vehicle a very long time and I've chosen to to change the oil at 1k miles and every 5k miles thereafter.
