First experience needing 4L
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve40th, Oct 26, 2023.
  1. Oct 28, 2023 at 8:37 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    It does, but the limiting factor isn’t the suspension when it comes to tires, which is what he’s getting at.
    You could cram huge tires with only a lift, but the minute the tire has to move as a a result of hitting a bump, you have issues.
    Now, if you aren’t worried about bigger tires and only the bumper, it might be more effective to find an aftermarket bumper.
    I say this because it’s not the center that looks to be the issue on the limited, but the corners…and even the corners on the non-limited bumper can be an issue if you wheel it hard enough.
    But…I’m not sure how many options are there for the Limited.
  2. Oct 28, 2023 at 9:00 AM
    Steve40th
    Steve40th [OP] New Member
    sTEVE
    Limited's are limited, pun intended. I think a spacer lift is fine, but OEM sized tires with a better off road capabilities would have helped significantly. It was a minor hole, but it showed its face real quick how deceiving even a little puddle can be.
    When I was cleaning the undercarriage, I noticed that it was packed deep into frame holes and such. So, I hit the bottom, or high centered it.
    But, it was fun, interesting.
  3. Oct 28, 2023 at 9:15 AM
    Spacers only if you want to keep XREAS. Otherwise, you can use anything that fits the other trims.
    Steve40th[OP] likes this.
  4. Oct 28, 2023 at 9:17 AM
    Steve40th
    sTEVE
    Going to keep XRAES till it starts leaking. It rides nice..
  5. Oct 28, 2023 at 9:18 AM
    Tires make a huge difference. Some AT's have pretty aggressive sidewall tread that would be beneficial in mud. But, if you really want to play in the mud, nothing will work like a real MT.
    OTOH, once you're sitting on the frame, it doesn't matter what tires you have. :D
  6. Oct 28, 2023 at 9:19 AM
    There's plenty of options for spacers. That's what I'd do in your situation.
    Steve40th[QUOTED][OP] likes this.
  7. Oct 28, 2023 at 10:26 AM
    bassist
    bassist New Member
    Oh, some BFG KO2s will take you places that you have no business going, even in the stock size. Trust me!
  8. Oct 29, 2023 at 2:20 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
  9. Oct 29, 2023 at 9:21 PM
    Steve40th
    sTEVE
