First 6th gen BUILD: 35's & Level Lift Kit on TRD Off-Road (Everest)
Discussion in '6th Gen 4Runners (2025+)' started by jwocky, Jan 23, 2025.
  1. Jan 27, 2025 at 7:42 PM
    cuse93
    cuse93 Ice Station Zebra
    35's will void the powertrain warranty?
  2. Jan 27, 2025 at 7:59 PM
    If it’s getting 15mpg mixed like he said, that’s impressive (I get around the same on 33s). But if it’s on full boost all the time, that cant be good. Piston aviation power plants spend a lot time at full power, but once they’re turbocharged, they often arent designed to go full boost all the time.
    35s are gonna need a regear for sure.
  3. Jan 27, 2025 at 8:20 PM
    Absolutely! Bigger tires changes the final gearing ratio which make the transmission work harder. It’s noticeable with 33s on a 5th gen, the make the transmission run hotter, it takes more power to go the same speed, and taxes the power steering in off-road situations. The bigger you go, the more likely you’ll break CV axles as well. 35s will make it so you can snap axles on command once you learn the trick. And the new tacomas/4runners don’t seem to have significantly stronger drivetrain components, so 35s will probably stress it just the same as current 5th gens.
    djwantke likes this.
  4. Jan 27, 2025 at 11:11 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
  5. Jan 27, 2025 at 11:16 PM
    Yotaholic
    Olympia, WA
    37s don't void Jeep warranty. It would suck if Toyota puts the blame on 35s if things go south. I guess regear to 4.88 and hope for the best. And of course 35s will kill your suspension and steering warranty.
  6. Jan 28, 2025 at 8:55 AM
    *as a butter knife
  7. Jan 28, 2025 at 12:18 PM
    Or you could be reasonable and just put 33's on it.
    Toy4X4 likes this.
  8. Jan 28, 2025 at 12:26 PM
    jwocky
    jwocky [OP] New Member
    Tucson
    Where's the fun in living reasonably?!
    Yotaholic and nimby[QUOTED] like this.
  9. Jan 29, 2025 at 3:55 AM
    NoDak
    NoDak New Member
    JR
    North Dakota
    depends, i have these for butter knives :)
  10. Jan 29, 2025 at 4:37 AM
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    LLOD is running 37s on his 24 Tacoma and has been for a while.
  11. Jan 29, 2025 at 7:05 AM
    I took mine in for the needle bearing noise on the front diff. They heard the noise, blamed my “off-road” tires, and charged me 140 bucks diagnostic time.
    I have 285-70-17 K02. They didn’t blame the size, they blamed it on them being “off-road” tires. They didn’t even blame my lift lol.
    They were incorrect in their diagnosis, but there are multiple ways for toyota to “deny”’coverage for any alteration from bone stock. That’s just how toyota is. Will some dealers play fair? Sure. Will most of them? Probably not.
    It’s up to the customer and their willingness to challenge denied warranty claims. But when it comes right down to it, larger tires can be the actual cause of drivetrain and steering problems, so it will be a hard fight to fight if toyota decided to deny warranty based on tire size.
  12. Feb 15, 2025 at 7:14 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Can’t help but notice nobody ever does this to the 5/6 gens!
    yo @Yotaholic what you think this dudes running under there :laugh:
    ChessGuy likes this.
  13. Feb 15, 2025 at 9:58 PM
    ThomasL
    ThomasL New Member
    Florida
    24 TRD Off Road Prem
    Looks good!!! These new body style is sharp
  14. Feb 15, 2025 at 10:58 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Even if power will be there, I am skeptical as to whether reliability and longevity will be there.
  15. Feb 15, 2025 at 11:01 PM
    Rick G.
    Define driveway components?
  16. Feb 16, 2025 at 8:20 AM
    DougNuts
    DougNuts New Member
    It's math - 15lbs of boost effectively doubles the engine's displacement. I can't speak to the Toyota yet, but I've had two 3.5TT Ecoboosts and they don't spend much time in boost, even when hauling. The 1st gen were more fuel hungry, which is where the sizeable hit stereotype comes from. The good thing about modern engine controls, is that turbo engines run MUCH closer to stoich than they did in the past. Gone are the days of 10:1 fuel ratios under boost.
    The battery won't "deplete", it acts like a capacitor and the logic won't let it go to zero.
  17. Feb 16, 2025 at 11:32 AM
    Deplete all the way to zero wasn’t what I was wondering…it was whether or not the car will draw from the battery more than it can charge the battery.
    For example, since the hybrid was primarily designed to give extra power (not effeciency), it may be set up to give electric power in any circumstance where power is requested. If additional electric power is constantly demanded on 35” tires (for example), it will never have an opportunity to replenish the battery.
    Sure, the logic will probably dial back the electric power to preserve a minimal state of charge, but then it’s not giving electric boost. If that occurs, the hybrid system essentially becomes completely useless.
  18. Feb 16, 2025 at 2:16 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I ve wondered this as well. My wife’s Elantra hybrid has plenty of “power” from her tiny engine going uphill only when the hybrid system has enough juice from the battery to supplement the engine. If going uphill for too long and the battery is depleted, it is seriously underpowered.
    Going from phoenix to flagstaff, towards the end, there is a steep grade and its high elevation. Her car struggles to stay at 65 mph when the battery has depleted although it had no problem doing 90mph when there was still juice in the battery.
    Doing the same route with the 4R, I can still easily go 80-85mph on that stretch.
    Granted, the 6th gen will have turbos to help but I wonder how much weaker it is without the battery helping out. Ideally I would like having a button that forces the car to use gas only, that way I could preserve the battery when I need it the most if I know the route
  19. Feb 16, 2025 at 3:25 PM
    #49
    DougNuts
    DougNuts New Member
    Guys, the iForce Max Tacoma has been out for a while, go check those out if you're curious how things will work out in the 4Runner. The LC250 and, to a lesser extent, the Tundra/Sequoia also can be used for data points.
  20. Feb 16, 2025 at 4:13 PM
    #50
    The turbo engine by itself is more powerful than the 5th gen. Which is why I think if you’re going to 35+ tires, it may not be worth going to hybrid (if the battery becomes depleted quickly).
    I haven’t run into anybody sharing observations regarding hybrid electric battery state-of-charge when running on 35 plus tires yet. For example, after being on the interstate a few hours, or out on the trails all day. Besides significantly reduced economy, which is expected. If people on upsized tired are finding that the electric power only last a short while, the hybrid option may not be worth it for those folks. Or for people carrying a lot of extra weight.
  21. Feb 16, 2025 at 4:19 PM
    #51
    Meant to say drivetrain. Any part that is responsible for getting power from the engine all the way to the wheels.
  22. Feb 16, 2025 at 4:30 PM
    #52
    semprenissart
    semprenissart Mèfi
    Yes i was only comparing the Elantra hybrid vs the 5th gen even though they’re very different. But from my personal experience, the Elantra w/ the battery performs better going uphill despite having a much smaller engine. Once it’s running on the engine only (without the battery) it’s much weaker than my 4R.
    So I wonder how 6th gen hybrid compares to 6th gen non hybrid since they have the exact same engine.
    How much power does the hybrid actually provides in real life scenarios, mainly when adding bigger tires like you said.
    are the hybrid 6th gen out already or not yet?
