Fire Extinguisher Spot
Discussion in 'General 4Runner Talk' started by Ratmosphere, Aug 8, 2023.
  1. Jan 24, 2024 at 5:37 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I have a 2 1/2 lb in front of the drivers seat and a 5 lb in the back.
    The front utilizes the mount that came with the extinguisher bolted to a Desert Does It mount panel that is attached to the seat jackets. The seat still has full forward / rearward movement.
    The rear utilizes the mount that came with it bolted to a home made bracket.
    Cheers,
    Bob
  2. Jan 24, 2024 at 5:52 AM
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
    djwantke likes this.
  3. Jan 24, 2024 at 6:39 AM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    Question, why is it a "cool factor" to have the extinguisher mounted in front of my seat? Nobody really sees it. Myself, I think snorkels and Raptor lights are way more of a "cool factor" than fire safety...
    Trail Runnah likes this.
  4. Jan 24, 2024 at 6:40 AM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    It will go all the way up but does start to rub the top of the extinguisher as it nears the end of the forward travel.
  5. Jan 24, 2024 at 7:01 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Awesome! Sorry for all the questions but what fire extinguisher are you running?
    I will be jacking your setup xD
    djwantke and doublewide[QUOTED] like this.
  6. Jan 24, 2024 at 7:33 AM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    H3R Performance Max Out ABC Dry chemical
    :thumbsup:
  7. Jan 24, 2024 at 8:00 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I don’t know. Us guys are weird. Some of us like to mount CB radios, have shit dangling all over the dash, put patches everywhere, molle panels in the front.
  8. Jan 24, 2024 at 2:22 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    In Canada (previously the glorious and free before Turdeau)
    Garrison ABC Dry Chemical Rechargeable Fire Extinguisher With Wall Mounting Bracket, 2-lb, Red
    + black metal vehicle mount off Amazoné
  9. Jan 24, 2024 at 3:31 PM
    3JOH22A Toyota Gigolo
    It's good for under-hood fires (most likely in a vehicle) when it first starts, that's why you want the quickest access.
    For camping I carry a second extinguisher loose with my gear, and put it close to the grill or camp fire (and close to the tent if I sleep with the propane heater running).
    nova likes this.
  10. Jan 24, 2024 at 3:54 PM
    What's the 2lb extinguisher's rating, 1A5BC? I went with a Kidde 2.5lb because it's 1A10BC. The canister is aluminum with no welds, as corrosion would otherwise be a concern in the footwell area.
    djwantke[QUOTED] likes this.
  11. Jan 24, 2024 at 4:17 PM
    That's right 1A5BC
  12. Jan 24, 2024 at 4:18 PM
    I asked for two for xmas.
    After feedback from the boys, sounds like need a second larger tank in the cargo trunk to actually put out a car fire (I'm not installing any in front of seat)
  13. Jan 24, 2024 at 5:14 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    respectfully, as a career firefighter, very few vehicle fires are going to be controlled with a fire extinguisher. If a vehicle spontaneously goes up in flames, you more than likely have fluid involved at a continuous flow.
    That said, I still carry an ABC extinguisher because absolutely anything can happen and it may make a difference, especially if it’s an off road/grass fire issue. But I’m just not giving up foot space for an extinguisher.
    Not to mention, I have other personal experience lol
  14. Jan 24, 2024 at 6:05 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    When I was a teenager in the '70's, my buddies engine caught fire in a McDonalds parking lot. Guy next door ran over with the smallest extinguisher I have ever seen. (The 2.5 lb I carry is a lot bigger) It did the job and we drove the car home. I have come to realize that most big fires started as little fires.
    To paraphrase, "If it saves only one, it was worth it".:D
  15. Jan 24, 2024 at 6:14 PM
    Ah, the mobile version of this forum doesn't show service badges. Always welcome to hear from a professional :hattip:
  16. Jan 24, 2024 at 6:31 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    cars weren’t built with an engine compartment full of plastic and other combustibles in the 70’s.
    either way, doesn’t hurt to have one or use one.
  17. Jan 26, 2024 at 7:24 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    This guy gets it.
    I'm not carrying it for a issue i may run into on MY rig, but, a side of the road thing I may come up to, or camp fire that gets outta hand, or buddies, doing "watch this" things. Its not in my rig to put my junk out. Just there for the other "oh shit" moments. That said, i do carry two, small, out of my way units. And , everyone i travel with knows where they are, and i consider that done/good. Same with my emergency pack. That takes up little space. It wont cure cancer, or heal the planet, but there in case a few of us go wheeling/shooting/spelunking, whatever, and something could do the trick. No more, no less. That said, in 2 decades of horsing around, neither have been grabbed. But, i also will make some simple, out of the way space, for the option.
  18. Jan 27, 2024 at 4:20 PM
    Whoa! What’s the story on that? That fender is aluminum I suppose?
  19. Jan 27, 2024 at 4:35 PM
    #49
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    shit if I know. Doing 75 and notice smoke, pull off highway and it’s beyond gone by the time we got out of the truck. Probably something with the fuel system. Aluminum melts fast lol
  20. Jul 7, 2024 at 4:58 AM
    #50
    LJrunner
    LJrunner New Member
    How did you mount/attach the CO2 tank bracket in back? Thanks.
  21. Jul 7, 2024 at 7:02 AM
    #51
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
  22. Jul 7, 2024 at 1:46 PM
    #52
    TrailSpecial22 New Member
    PA
    thoughts on summer heat effects on extinquisher on cargo area mounting?
  23. Jul 7, 2024 at 4:04 PM
    #53
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    High temperatures aren’t an issue. Chemical is very stable.
    Inside of my vehicle is well over 100 degrees in Texas.
  24. Jul 8, 2024 at 7:30 AM
    #54
    Kyblack76
    Layton, Utah
    18 TRD O.R
    The bracket mounts to oem mounts, its from power tank. The tank, i pieced together myself. Cheers.
