Falken Wildpeak A/T3 275/70 R17 on Stock 4Runner ORP
Discussion in '5th Gen 4Runners (2010-2024)' started by knappster007, Dec 18, 2020.
  1. Dec 26, 2020 at 3:55 AM
    275-70-17 stock ORP rims, speedo is on the money! ~ .5 mph. If you get a citation for 2-3 mph over, the cop must be fishin'!20200807_200946[455] 4runner.jpg
  2. Dec 26, 2020 at 4:46 AM
    knappster007
    knappster007 [OP] New Member
    2021 4Runner TRD Off-road Premium
    Yes, I too have a slight bit of oscillation at highway speeds. It doesn't happen every time though, and its minor, but happens around 63 mph.
    POWERPLANTHOMER likes this.
  3. Dec 26, 2020 at 6:07 AM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    Considered tire pressure? I had a similar shimmy periodically at about 60mph. Adjusted tire pressure to 42psi and all is well. 265/70-17 KO2s, however, not Wildpeaks.
  4. Dec 26, 2020 at 6:09 AM
    knappster007
    I read some threads about tire pressure. When I had them put on I asked for 38 psi. I'll take a shot at increasing the tire pressure. Thanks!
  5. Dec 27, 2020 at 6:16 PM
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    Those 275s look really good! That settles it for me: I'm going for some 275/70r17 General Grabber ATXs on my ORP.
  6. Dec 28, 2020 at 8:39 PM
    Jut got a set of stock sized ATX's put on mine last week, I'm very happy with them. Even in stock size, they look so much bigger than the stock Bridgestones. I stuck with the "P" rated because the only other choice was E, and I wanted a lighter tire. We had some snow last week, and I got to play around a bit. Was happy with the performance. They also ride very nice.
  7. Dec 28, 2020 at 11:50 PM
    knappster007
    Good news. Increasing the tire pressure to 40psi eliminated the slight shimmy. Had to take a 90 minute highway drive yesterday and averaged 20.0 mpg. Very pleased with that. I had prepared myself for far worse gas milage. Coming from a series of sports cars, I don't mind the stiffer ride at all.
  8. Dec 29, 2020 at 7:58 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    That must have been downhill...
    If I drive like a grand-ma I can barely squeeze 17 out of her...
    I can't imagine what you could be doing that differently. I don't think I even got 20 out of my stock tires.
    Wait, was this at like 55 MPH? That probably is a lot different than 75-80 MPH.
  9. Dec 29, 2020 at 10:10 AM
    knappster007
    I was quite surprised. I had averaged 18.4 mpg with the stock tires (around the town and mixed highway driving). After the Wildpeak switch that average dropped to 17.5.
    After refueling, and then pumping up the tires to 40 psi and driving for about 90 minutes at a mix of 74mph, then 65mph, and some at 62mph and then back again after a stop at the terminal, it averaged 20.0mpg after the refill. The only thing I can figure is that it was the tire pressure, and cruise control :).
  10. Dec 29, 2020 at 12:33 PM
    Chris In Milwaukee
    Chris
    Tire pressure help my mileage as well. From 36psi to 42psi, I went from about 16mpg to a little over 18mpg on aftermarket tires.
    POWERPLANTHOMER and Toy4X4 like this.
  11. Dec 29, 2020 at 3:26 PM
    DaRunna
    DaRunna New Member
    SE Mi
    2021 Venture
    Pics?
  12. Feb 5, 2021 at 5:21 AM
    Lab Hiken
    Lab Hiken New Member
    2020 SR5 4x4
    Did you have to remove mudflaps or any trimming? I’m looking these same tires but with a 2”/1.5” lift.
  13. Feb 7, 2021 at 7:33 AM
    Dbrown1855
    Dbrown1855 New Member
    David
    Rimrock, Arizona
    I just put these 275’s on about a week ago. No rubbing anywhere and I’m totally stock. They are 10 ply and definitely ride firmer than the stock Bridgestones.
  14. Feb 10, 2021 at 10:01 PM
    QAS
    QAS New Member
    Southern Utah
    2015 Inferno TRD Pro
    What air pressure are you guys running, with 275/70/17 Falken Wildpeak's for the street. what do you air down to for off-road??
    Toy4X4 likes this.
  15. Feb 11, 2021 at 2:30 AM
    I have 38lbs. in our 275's, the difference is we have Coopers instead of the Falkens, everyday driven to work by my wife. The ride is firm, but not in a bad way. When the time arises, going to expieriment with the pressure, I have not ruled out going down to 28-30lbs for the trails.
  16. Feb 11, 2021 at 3:02 AM
    Lab Hiken
    2020 SR5 4x4
    I’m running 35 psi cold. Only have had them for two days and only about 50 miles.
    POWERPLANTHOMER and Dbrown1855 like this.
  17. Feb 11, 2021 at 4:19 AM
    jcoon
    jcoon New Member
    Peasleeville NY
    19 4 runner TRD off road
    I’m running 35 psi also, I run them on my Silverado also, but run 40 psi on them.. when going on long interstate trips i run them up to 45 psi. Max is 51 psi for mine.
  18. Feb 11, 2021 at 6:57 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    According to the tire and vehicle manufacturers and engineers, LT rated tires should be run at 40 PSI on the 4Runner. Do what you'd like of course. I run 40 PSI front and 38-39 rear.. cold of course.
    @Lab Hiken What lift is that? EDIT: Nevermind, went and stalked your posts and found out. Thanks :)
    Lab Hiken likes this.
  19. Mar 17, 2021 at 8:37 PM
    #49
    Tricio69
    Tricio69 New Member
    Patrick
    Hi everyone, new owner here ('21 Venture) and thinking of putting these or the BFG TA KO2 on. Curious how the extra weight vs. stock tires has impacted the acceleration and MPG. Much difference or barely noticeable? Thanks in advance!
  20. Mar 17, 2021 at 8:51 PM
    #50
    Here's my mpg experience with BFG KO2 285/70R17. I don't feel any difference with acceleration though.
    https://youtu.be/nzrcjKHEKeM
  21. Mar 18, 2021 at 1:28 PM
    #51
    ShakyDog
    ShakyDog New Member
    Steve
    2021 4R TRD ORP Nautical Blue
    Remember that the MPG on the 4Runner is going to be wrong as it is expecting the tires to be 100% true to size. With a larger sized tire it is not going to know true miles unless recalibrated...Best to do the math at the pump.
    Just saying
    Well it looks like for the 285s the speedo is dead on, so maybe the 265s will show wrong...what do I know I don't even own one right now...
    Steve
  22. Mar 18, 2021 at 1:40 PM
    #52
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Nice. But wow that glare off the skewp :rofl:
  23. Mar 18, 2021 at 1:45 PM
    #53
    Ha ha.. Of cause.. Me thinking "This stupid non functional scoop.." and also me "that scoop looks good on pics" :D:D:D
  24. Mar 18, 2021 at 2:03 PM
    #54
    Singleminded
    OEM LED foglights
    I can't resist the chance to poke at all the fake skewp lovers around here...;):boink:
    nimby and kmeeg[QUOTED] like this.
  25. Mar 18, 2021 at 2:05 PM
    #55
    LoL, my wife hates it..
  26. Mar 19, 2021 at 10:27 AM
    #56
    Dean0017
    Dean0017 New Member
    Dean
    2016 4Runner SR5
    None yet
    Say the guys with SR5s and Limiteds.... LOL
    A&P likes this.
  27. Mar 19, 2021 at 11:43 AM
    #57
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Much difference.
    Tricio69[QUOTED] likes this.
  28. Jun 3, 2021 at 9:38 AM
    #58
    Ben84
    Ben84 New Member
    Any rubbing on the 275/70/r17 on an off road with KDSS?
    I just got '21 TRD OR and I don't want to do any mods for it other than tires for now
  29. Jun 3, 2021 at 5:50 PM
    #59
    They should clear the same as a non-KDSS 4Runner.
    A&P likes this.
  30. Jun 7, 2021 at 8:15 PM
    #60
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    I bought Cooper AT3 LT, last Friday. Went directly to the mountains and aired down to 16-18 psi and ran almost 25 miles for 2 days. No rubbing whatsoever on my 2021 with KDSS. No rubbing on road, no running Offroad in the rocks. Granted slow speed, I’m pretty easy on my 4RUNNER.
    Chris In Milwaukee likes this.
