Extra Fuel
Discussion in 'General 4Runner Talk' started by Moon Landing, Mar 17, 2021.
  1. Feb 7, 2022 at 11:29 AM
    #91
    Moon Landing
    Moon Landing [OP] AFFTC 1967/68 Eddies Air Patch
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Nervous..........is good :bananadead:
  2. Feb 7, 2022 at 11:36 AM
    #92
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    If I were to roll over? The smell of fuel would be secondary to that other smell. :D
    icebear, GrantA, ElectroBoy and 3 others like this.
  3. Feb 7, 2022 at 4:16 PM
    #93
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    djwantke, Jrunr and Thatbassguy like this.
  4. Feb 7, 2022 at 5:18 PM
    #94
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Those do look like great options. Do they connect to our factory tank? Or will we have to siphon like we would a gas can?
  5. Feb 9, 2022 at 5:31 PM
    #95
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Jrunr and SlvrSlug like this.
  6. Feb 9, 2022 at 9:03 PM
    #96
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
  7. Feb 10, 2022 at 6:01 AM
    #97
    iamincrediboy
    iamincrediboy New Member
    South FL
    While I dont see what thickness steel LRA uses I'd probably suspect 1/8" or 3/16" stainless. In my mind going to 1/4" isnt worth the weight. But the whole solid tank plus 24gals of gas at about 6lb per gallon would be on the order of 250-300lb weight. Nothing our runners cant handle but it is a big consideration for people, losing that much capacity in one mod... Just have to weight it against the doubling in range :cheers:
  8. Feb 10, 2022 at 11:39 AM
    #98
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I've seen some Toyota Landcruisers outfitted with LRA tanks here at Overland get togethers.
    I'm usually off roading locally or in Arkansas and so far have always been able to find a gas station close to the trail.
    A multi day off road trip is where I would want bring some spare fuel along.
    SlvrSlug likes this.
  9. May 24, 2024 at 8:00 PM
    #99
    java
    java fauxrunner
    2023 ORP ice cap
    waivian
  10. May 24, 2024 at 11:56 PM
    #100
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey ya‘ll
    It’s been months and I have no leaks from the full Sceptor cans on the roof. Designed to lay flat no problem. For me, the roof cargo basket is the only spot I have. They’re strapped down, locked with Master steel cables and Master all-weather padlocks.
    java and SmithJ like this.
