Exhaust reroute
Discussion in '5th Gen 4Runners (2010-2024)' started by timkins42, Jun 18, 2022.
  1. Jul 18, 2022 at 11:38 AM
    #61
    @Saker - just out of curiosity - why welding the tip and/or elbow instead of using clamps?
  2. Jul 18, 2022 at 5:18 PM
    #62
    Saker New Member
    21 Black T4RORP
    Personal preference, I presume.
    On my ‘14, the 90 and the tip were welded, but the tip was not seal welded. I decided I wanted both seal welded.
    Not a fan of putting clamps when it can be welded.
  3. Jul 19, 2022 at 6:23 AM
    #63
    Now you have me researching 'seal welded'...can I assume this means a fully welded seam with no gaps, or is that a special type of welding? You did mention taking your 4R to an individual who does custom work...
    Saker[QUOTED] likes this.
  4. Jul 19, 2022 at 9:15 AM
    #64
    Saker New Member
    21 Black T4RORP
    Yes, fully welded seam with no gaps.
    I brought it to someone that welds stainless exhaust on “specialty/race” cars.
    Your exhaust on your T4R is stainless.
    ElectroBoy likes this.
  5. Jul 19, 2022 at 9:53 AM
    #65
    Good to know, thanks. I know what to convey to the exhaust shop.
  6. Jul 19, 2022 at 4:09 PM
    #66
    matoolie
    Michael
    2021 Lunar Pro
    The exhaust may be some type of stainless, 200 or 400 series stainless, but it is not 300 series as the piping and muffler are all magnetic.
    Saker likes this.
  7. Jul 19, 2022 at 5:23 PM
    #67
    Saker New Member
    21 Black T4RORP
    Ok, I wanted someone that welds stainless to stainless. Didn’t check the series.
    ElectroBoy and matoolie[QUOTED] like this.
  8. Jul 22, 2022 at 8:38 PM
    #68
    Hey @ Saker. I got the elbow on Wednesday and the tip today. I was expecting the tip to just slip right over the stainless piece (or the oem exhaust), but the tip has a larger inside diameter than the pipe's outside diameter...I guess that's why they include the two spacers.
    Edit: I see now why the exhaust tip has a larger ID than the OD of the oem exhaust - it has to slip over the larger OD of the stock exhaust end, which is flared, and the spacers fit in behind that larger section, filling up the gap so the clamp can tighten.
    How did the installer fill up the gap between the OD of the elbow pipe and the larger ID of the tip? It sort of looks like there is a slightly larger piece of pipe in between the two, but I can't really tell from the second photo above; it might just be a reflection on the inside of the tip.
    alittleoff likes this.
  9. Jul 22, 2022 at 10:04 PM
    #69
    Saker New Member
    21 Black T4RORP
    You got it correct, installer used a filler piece to fit the 2 by inserting another short piece in between the OEM OD and the tip ID, then seal welded all together. Made it quite strong without bending and flaring.
  10. Jul 22, 2022 at 10:25 PM
    #70
    Thanks. Did you cut off the slotted portion of the tip prior to taking it to the shop, or have him trim it?
    Sorry to keep barraging you with questions...;)
  11. Jul 23, 2022 at 7:32 AM
    #71
    Saker New Member
    21 Black T4RORP
    No worries on the questions.
    Took it to the shop, he did all the work.
    I just conveyed what I was looking for as an end result.
    He took it from that point to completion.
  12. Jul 26, 2022 at 4:17 PM
    #72
    Took the photos and the parts to two shops today. One didn't fill me with confidence they knew what I wanted, and were too pricey. The other understood exactly what I was wanting, and I have an appointment on Thursday to have this done. @Saker - one last question. Do you know this measurement:
  13. Jul 26, 2022 at 6:22 PM
    #73
    Saker New Member
    21 Black T4RORP
    8 1/2" from rear of mud flap to center line of exhaust tip.....upload_2022-7-26_17-10-31.jpg
    SlvrSlug likes this.
  14. Jul 26, 2022 at 8:40 PM
    #74
    Thanks. I was looking for the measurement to the end of the cut plastic, but I can figure it out from what you gave me.
  15. Jul 26, 2022 at 8:43 PM
    #75
    Saker New Member
    21 Black T4RORP
    That measurement is probably 7 1/2”
  16. Jul 28, 2022 at 5:19 AM
    #76
    Alan_G_TRD
    Alan_G_TRD New Member
    Alan
    2022 4Runner TRD Off-Road
    One of my pet peeve's as well, and I do a lot of trailering!
  17. Jul 28, 2022 at 8:04 AM
    #77
    Well, major disappointment today. The shop I visited on Tuesday who said to come back this morning, where I dropped it off today, just called, and they want to 'make some additional modifications' which included cutting off the hanger and repositioning it. For an additional fee, of course. I told them to take my 4Runner off the lift, and DO NOT do any work on it, I would be by to pick it up. If they can't do it the way I left photos and instructions, leave it alone.
    I will be looking for another shop. Rats. The guy the other day said 'No problem! We can do it just like that!' Yeah, right.
  18. Jul 29, 2022 at 6:25 AM
    #78
    Custom fabricator found, 5 minutes from work. I am going back on Saturday, I think this will work. He understood what I want.
    Saker and alittleoff like this.
  19. Jul 29, 2022 at 3:25 PM
    #79
    blksubykid
    blksubykid New Member
    Cut mine just after the rear axle and welded on an extra hangar for support. I got tired of crushing the tip flat...
    ESCT4R and OverRunner like this.
  20. Jul 30, 2022 at 9:29 AM
    #80
    LetsTacoboutit
    Adobe
    Did the same. So far no headaches or elevated carcinogens in blood work. lol
  21. Jul 30, 2022 at 2:27 PM
    #81
    Project side exhaust complete. Mine turned out a bit different than @Saker, using the same materials. I don't know if my stock rear hanger was a bit higher, but we did not end up cutting or modifying that at all. Because of that, the tip had to be angled a bit more down, to clear the bumper plastics, and is a bit further back. Same end result, more or less.IMG_0348.jpg IMG_0349.jpg IMG_0351.jpg IMG_0352.jpg IMG_0353.jpg
    Thanks to @Saker for all the help and photos.
  22. Jul 30, 2022 at 3:57 PM
    #82
    Saker New Member
    21 Black T4RORP
    Looks good!
  23. Jul 31, 2022 at 10:46 AM
    #83
    So having done this project this way, I got to wondering...would it have been possible for an exhaust shop to have put a 90* bend in that stock exhaust tail section to route it to the side? In lieu of adding a separate elbow & tip? Just curious.
    Saker and ElectroBoy like this.
  24. Jul 31, 2022 at 1:25 PM
    #84
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    It looks good. I’m wondering if the chrome tip is necessary, maybe get more ground clearance with just a plain elbow pipe tucked up higher.
    So how does it perform with the hatch window open, any smell detected? I suppose you could try plugging a carbon monoxide monitor into the AC outlet in back to see if it gets triggered by any CO getting swept in. There are several variables to consider, like how far the window is open, speed, hard accelerating or decelerating, etc.
  25. Jul 31, 2022 at 9:18 PM
    #85
    That was sort of the reason for the question in my last post. I could've just left the outlet side on the elbow longer, and perhaps angle cut the end, and it would have accomplished what you are saying. I personally am not going to get into too many situations where the tip is in danger of being flattened. Plus, I liked the look on @Saker's rig so much, I wanted to go that direction. If the OEM rear exhaust pipe section could be bent to the side, it would have saved a lot of cutting, fitting, and welding, though.
    I've not had a chance to check that out yet, just finished this project yesterday. I will see if I can check that out.
    Saker and ElectroBoy[QUOTED] like this.
  26. Oct 1, 2022 at 7:28 AM
    #86
    Amerxon555666
    Amerxon555666 New Member
    Paul
    Red 2021 4runner TRD off-road
    that's a smart way to store your rotopax,
    blksubykid[QUOTED] likes this.
  27. Oct 1, 2022 at 12:02 PM
    #87
    blksubykid
    thanks. I can’t take the credit, saw someone else do it on the other 4Runner forum. It came in handy especially it’s hidden and no one knows it’s there. But since I got my rear bumper I haven’t purchased more to put there.
    Amerxon555666[QUOTED] likes this.
  28. Oct 14, 2022 at 7:33 AM
    #88
    Amerxon555666
    Paul
    has anyone done this? I have been wanting to do this mod, but the rear cabin vent is hindering me to drill hole on the body. got this photo from Milk.Wagon on instagram
    Saker and Bikeric like this.
  29. Oct 14, 2022 at 8:19 AM
    #89
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    I might go this route!
    If you wheel often, I feel like you're bound to hit your exhaust tip more often. On the trails, I hear the mud flaps dinging rocks all the time.
  30. Oct 14, 2022 at 8:49 AM
    #90
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Love it!
