Engine noise at idle
Discussion in '5th Gen 4Runners (2010-2024)' started by 2018newbie4rnr, Oct 1, 2020.
  1. Oct 18, 2022 at 4:15 PM
    #121
    BigGilly44444
    BigGilly44444 New Member
    Eric
    19 4runner ORP 4x4
    3" icon lift
    It just had an oil change 200 miles previous...sounds same at 5k
  2. Oct 18, 2022 at 5:58 PM
    #122
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I did the lab oil
  3. Dec 2, 2022 at 4:12 PM
    #123
    shumif1
    shumif1 New Member
    Tommy
    New Jersey
    2018 4Runner Premium
    I have a 18 4 runner and have the same issue , I came from a 09 Highlander with 218 k and it was quiet as a church mouse .
  4. Dec 2, 2022 at 6:40 PM
    #124
    j cat
    j cat New Member
    massachusetts
    did you buy the 2018 4runner new ? did you also change the oil changes and use the Toyota oil filter ..0-20wt synthetic sn plus ...
  5. Dec 5, 2022 at 3:02 PM
    #125
    shumif1
    shumif1 New Member
    Tommy
    New Jersey
    I always use the Toyota filter and Mobile 1, 0-20 I bought it used in dec. 2019
  6. Dec 5, 2022 at 3:35 PM
    #126
    j cat
    j cat New Member
    massachusetts
    I do the oil change and the drive shafts grease ... in nov/dec around 7500 miles .. I run the engine with the correct temp then the oil is draining .mobil 1 0-20wt SN PLUS ....synthetic ..
    drain it 45 mins.... my engine oil is like the same new color ...
    many Toyota vehicles are rodents and the soy material is chewing up the harness ...peppermint spray ,, I did the rat wire screen to the air filter port ...
    shumif1[QUOTED] likes this.
  7. Dec 27, 2022 at 10:29 AM
    #127
    knoxnil
    knoxnil New Member
    19 SR5 Premium
    Just to chime in on 4Runner's noisy engines, recently scared the crap out of my grandson, he was hanging out in his garage, my '19 SR5 was parked just outside the closed garage door, I went outside to start up the truck to move it out of the way. of course the engine fan roared at start up and grandson came running out of the garage shouting what the hell!!. He said it sounded like an airplane was going to crash though the door.
    I also have the knock/rattle till it warms up good. I was concerned at first but had a friend tell me his father has owned 2 5th gen 4Runners and they both sounded just like mine. At 70 mph and 2000 rpm, reminds me of grandmas old Singer sewing machine hammering out a hem.
  8. Dec 27, 2022 at 4:08 PM
    #128
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    I notices this also at a test drive.
    Sounded like injectors or lifters to me.
    We bought the truck and have a 100k Warreny. No worries here
  9. Dec 27, 2022 at 4:49 PM
    #129
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    danielmiao and Singleminded like this.
  10. Dec 28, 2022 at 9:59 AM
    #130
    knoxnil
    knoxnil New Member
    19 SR5 Premium
    Question for Limited owners, I haven't had the opportunity to drive a Limited. Was wondering if they might have more sound deadening since they are a higher end model. And maybe they don't notice the engine noise as much.
  11. Dec 28, 2022 at 10:23 AM
    #131
    Foothills
    Foothills New Member
    When I bought this 2014 at 127k it had what seemed to be lifter noise, changed oil and haven't heard any engine noise since.
  12. Dec 28, 2022 at 10:44 AM
    #132
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Nope
  13. Jan 16, 2023 at 7:34 PM
    #133
    mystiqueskillz
    mystiqueskillz New Member
    I have a 2020 4Runner with 43k miles and it makes a flapping noise while accelerating while it's cold. Like it's fluttering or wings are flapping. Once the engine is warm, the noise isn’t as audible, but if you listen closely you can hear it.
  14. Jan 17, 2023 at 3:13 AM
    #134
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Yep, it’s a noisy engine. My second gen Taco wasn’t that quiet either.
    These threads are interesting… like the guys who don’t understand why the tcase lever vibrates, and the folks who get confused about when to use 4H, I think we have a lot of younger members on here who didn’t grow up working on cars and don’t remember what it was like driving cars with carburetors and distributors and manual transmissions, 10w30 oil that needed to be changed every 3000, timing belts that would snap catastrophically if you went too far past 60k, etc…
    If you remember having to set the choke, crank and crank until it fired and then god forbid don’t touch the gas pedal till it warmed enough that the high idle solenoid kicked off and it dropped down to normal idle you know what I mean ;)
  15. Jan 17, 2023 at 4:23 AM
    #135
    I also think it could be a lot of people buying these come from Civics and Camrys or whatever and bought this as their first SUV. I see a lot of new member posts that start out with "... finally got my dream car!", and might not be enthusiasts in the typical way that includes having some mechanical knowledge. Nothing wrong with that of course, that's why we're here to help, but considering how uninvolving most new cars are, the more basic and mechanical nature may be a bit of a shock.
    That said, I'm definitely familiar with that high idle, to this day I don't put my vehicles in gear till the idle slows. My first vehicle was a squarebody Chevy pickup with a carb'd 350 with a fairly agressive cam, and even that engine was quieter than the damn 4.0, haha. Not counting the exhaust, but unlike the 4.0, the 350 sounded amazing through headers and true duals.
    4 years later, the sound of the 4.0 STILL makes me cringe.
  16. Jan 17, 2023 at 5:01 AM
    #136
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    Is there any 1 oil that these engines like the best to reduce noise ?
    Over in my chevy form some say mobil 1 is noisey. We are talking 5w 30 weight there not 0w 20
  17. Jan 17, 2023 at 5:34 AM
    #137
    I've tried Mobil, Valvoline, Pennzoil platinum, and even the Toyota branded stuff, and I didn't notice any perceptible difference in sound.
    I read in another group that an additive from Liqui-Moly is good for quieting it down, but I'm hesitant to try things like that.
  18. Jan 17, 2023 at 8:15 AM
    #138
    Flapping sound is a weird way to describe it. There could be something going on. Tie down the rubber splash shield in the wheel wells. Zip tie them in, might help. Or look for plastic bags.
  19. Jan 17, 2023 at 8:48 AM
    #139
    It would seem odd at that age/mileage, but my first thought was exhaust leak.
  20. Jan 17, 2023 at 9:56 AM
    #140
    It crossed my mind, but I had the same thoughts regarding the age. First mental image I got was a an old delta 88 making that slappy ffft ffft ffft sound every 8th combustion cycle lol.
  21. Jan 20, 2023 at 3:28 PM
    #141
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
  22. Jan 21, 2023 at 4:04 PM
    #142
    snakehn
    snakehn New Member
    mine has this stupid rattle that started about 2 months ago, it started like a loose bolt or some tiny metal to metal rubbing, now is louder and sounds like coming from the passenger side, under dash or even door, no longer as metal rubbing is just a weird rattle when idling in Drive or Reverse, its absent when in park, tomorrow I am going to check the exhaust flange as I have the feeling its either the bolts or springs in it. already check the rubber covers in the wheel wells and is not that.
  23. Jan 27, 2023 at 6:59 AM
    #143
    j cat
    j cat New Member
    massachusetts
    the toyota plastic nuts are breaking down in the wheel well ....I changed the plastic of the s/steel screws and locked it up ....I took it out and used the black metal rustproofing and my 4runner is no rust and no noise ..
  24. Jan 27, 2023 at 9:05 AM
    #144
    HazOpRed
    HazOpRed 22' TRDOR
    Normal operation, I promise
  25. Jan 27, 2023 at 12:02 PM
    #145
    Foothills
    I've tried both 0W20 and 5W30 oil in this truck and find the engine runs quieter with 5W30.
    Frizzle77 and Polymers like this.
  26. Jan 27, 2023 at 6:03 PM
    #146
    Frizzle77
    Frizzle77 Mawl Crawler
    Eric
    2020 TuRD ORP
    Mods: TBD
    Interesting
  27. Jan 27, 2023 at 6:04 PM
    #147
    Frizzle77
    Eric
    2020 TuRD ORP
    Mods: TBD
    I'm coming from a 2500 Diesel so I don't find it very noisy... :notsure:
    RingSteel likes this.
  28. Jan 27, 2023 at 6:12 PM
    #148
    Frizzle77
    Eric
    2020 TuRD ORP
    Mods: TBD
    On my next oil change I plan to try Valvoline Extended Protection (I have been using Mobil 1 Extended Performance). I hear that the Valvoline runs more quiet. We shall see.
  29. Feb 2, 2023 at 6:46 PM
    #149
    Exactly lol. Compared to a diesel it’s pretty quiet :p
    2Toys likes this.
  30. Feb 2, 2023 at 7:20 PM
    #150
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Thing about it is...
    When you are standing over it with the hood open, or even listening from outside with the hood closed, there is so much going on with the loud fan, OHCs, their timing chains, valves and fuel injectors, all at the top of the motor in your face, nothing really stands out other than the fact that it's one noisy mofo.
    It's the fact that a lot of that gets filtered out when you are sitting in the driver's seat at idle and the characteristic "ticking, clacking" or whatever you want to call it is more pronounced behind the wheel and makes you wonder if your motor is about to come apart until, over time, you realize that's just the way it is.
