Engine noise at idle
Discussion in '5th Gen 4Runners (2010-2024)' started by 2018newbie4rnr, Oct 1, 2020.
  1. Mar 17, 2021 at 5:41 PM
    #91
    What's Schaeffers?
  2. Mar 17, 2021 at 5:45 PM
    #92
    bear1998
    bear1998 New Member
    Bryan
    2011 Shoreline Blue Pearl Limited, ...2004 Dark Blue Sport 4.7l .
    This is oil SLVR SLUG is going to use....
    Cant get it to post....lok back at his post
  3. Mar 17, 2021 at 5:51 PM
    #93
    I don't think the brand makes a difference.
    I was just saying that heavier oil isn't going to make the engine quiet.
    Honestly, I don't know if I would want to use oil that would make a known noisy engine run quietly. I would think something was wrong if it was quiet.
    thirdyota likes this.
  4. Mar 17, 2021 at 6:02 PM
    #94
    bear1998
    bear1998 New Member
    Bryan
    I really dont know why i dont use schaeffers...this oil is great stuff.
    My BIL is a diesel mechanic...some years ago a schaeffers rep showed up at his place n went thru his spiel. He invited him to seminar n i went along. They did several pressure test n other test..open bearing,rod bearing,etc.
    Needless to say....Schaeffers won out. Amsoil,Redline,Royal Purple,etc were all tested.
    Im very skeptical with these test for one reason or another..but after my bil n i duscussed it we were firm believers...jmo
    POWERPLANTHOMER likes this.
  5. Mar 17, 2021 at 6:16 PM
    #95
    I'm sure it's fine oil. I stick to inexpensive oil because I change every 5K. I used Mobil 1 every 10K on my previous 4runner with no issues for 257K miles.
    captsolo and bear1998[QUOTED] like this.
  6. Mar 18, 2021 at 10:58 AM
    #96
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    I was gonna use Canola, but turns out it's not really any cheaper.
    Thatbassguy and thirdyota like this.
  7. Mar 18, 2021 at 11:13 AM
    #97
    Singleminded
    OEM LED foglights
    Does anyone know when Toyota switched from recommending 5-30 to recommending 0-20? Did the motor actually change at all at the same time? I admit to being skeptical about 0-20, that it's sometimes been spec'd just to help get a bump in EPA MPG even though the engine was really designed for something heavier.
    I think Subaru did that several years ago with their 2.5L. So I ran 5-30 in mine.
  8. Mar 18, 2021 at 2:22 PM
    #98
    I can't say for sure, but one guy suggested it was 2016.
    I suspect it is CAFE BS but I continue to run 0W-20. In Puerto Rico, 0W-20, 5W-20, and 5W-30 are all recommended at any temperature range.
  9. Mar 18, 2021 at 2:25 PM
    #99
    bear1998
    bear1998 New Member
    Bryan
    My 2011 calls for 0w20....
  10. Mar 18, 2021 at 2:28 PM
    #100
    Singleminded
    OEM LED foglights
    Interesting. I'm not aware of any significant changes to the engine (or any at all) around 2016. I could imagine switching to 5-30. Espec if I see much consumption between oil changes. I think mine lost about 1/8th of a quart in its first 5000 miles (no big deal of course). Not sure how's it's doing now -- seems still at the exact top line on the dipstick in the 1500-2000 miles since.
    The zero bothers me less than the 20.
  11. Mar 18, 2021 at 2:30 PM
    #101
    Singleminded
    OEM LED foglights
    In that case maybe this motor really is designed for 0-20....
    I'm sure the engineers know what they're doing -- or at least know better than me. But 20 wt just seems so thin...
  12. Mar 18, 2021 at 2:32 PM
    #102
    bear1998
    bear1998 New Member
    Bryan
    I know what ur sayin....thought about goin to 5w30 several times
  13. Mar 18, 2021 at 3:04 PM
    #103
    I guess whoever said that on another thread was mistaken. I had said that the dual-VVT-I 1GR's all called for it, but someone claimed it was changed in '16.
    I don't think it's going to cause any issues. But, as I said in the other thread; If there isn't a mechanical difference between the US and Puerto Rico engines, than there's no reason we shouldn't be able to run 5W-20 or 5W-30.
    I am guessing the only reason they insist on 0W-20 in the US is to squeeze out another .003 MPG.
  14. Mar 18, 2021 at 3:52 PM
    #104
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  15. Mar 22, 2021 at 6:59 AM
    #105
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    use that 5-30wt oil in the warm weather ..Toyota manual states in a warm area above 50F this oil 5-30wt will keep the noise lower..
    in massachusetts yesterday the air temp was 70F and I started it 1PM .. engine noise was much lower ..
    in the cold temps below 30F it does make ticking noise for a few min... but the toyota oil did reduce the noise 0-20wt and had moly 850PPM in it ...
    9003D Supreme 9000™ Full Synthetic 5W-30 had 357PPM moly in it ..
  16. Oct 16, 2022 at 6:31 AM
    #106
    BigGilly44444
    BigGilly44444 New Member
    Eric
    19 4runner ORP 4x4
    3" icon lift
    My 19 Sounds like a header or exhaust noise but you only can hear it in the cab, idle, park, and low rpm 0-35. Dealer said normal sound. Wondering if anyone else's sounds like an exhaust pressure echo or vibration sound in cab only.‍♂️ 45k miles
  17. Oct 16, 2022 at 7:17 AM
    #107
    gmoliver
    gmoliver New Member
  18. Oct 16, 2022 at 7:31 AM
    #108
    gmoliver
    gmoliver New Member
    Bernie
    Have a 2020 Limited with 10,500 miles. This is my first 4Runner and had posted this same concern to the forum. These engines are a bit noisy and can be a cause of concern. Evidently the construction engineering is the reason for the “noise”. My 4Runner after 2 years runs great and has no issues
    Check out “Car Care Nut” channel on YouTube. He has a lot of very good and interesting videos on Toyotas. He is a Toyota/ Lexus master technician. Look for a picture of the opened (covers removed) timing chains in the engine compartment. It’s pretty amazing and visually you can see the reason why there’s some noise. Hopefully this helps.
    Glenn
  19. Oct 16, 2022 at 7:02 PM
    #109
    These engines are pretty noisy, Toyota didn't put much money into NVH suppression with them, it seems. For the longest time after purchasing mine I was convinced there was something internally wrong with the motor However, I bought it with 80,000 on it, and at almost 150K it still runs fine.
    It's hard to tell without actually hearing yours, but I imagine you're talking about a tick tick tick tick tick type sound. Mine definitely makes it, and I've heard many others that make that same noise.
    Supposedly this motor is very reliable, but like most other things about the 4Runner, just kind of crude.
  20. Oct 16, 2022 at 7:15 PM
    #110
    BigGilly44444
    Eric
    19 4runner ORP 4x4
    3" icon lift
    No its not the tik, its more deep like an exhaust sound. You can only hear it in the cab. Outside and with hood popped its extremely quite and steady. Almost not much of a tik to it. But in the cab its very noticable like a low diesel thud sound.
  21. Oct 16, 2022 at 8:16 PM
    #111
    Oh okay, that's interesting. Mine I hear even more outside the vehicle and with the hood open.
  22. Oct 16, 2022 at 8:24 PM
    #112
    4runGirl88
    4runGirl88 Get a little mud on the tires!
    2018 Black SR5 Premium (AKA Black Betty)
    Am I the only one who doesn't think the engine is loud? I swear my fiance's subaru outback is is just as loud. :notsure:
    whippersnapper02 likes this.
  23. Oct 17, 2022 at 8:49 AM
    #113
    BigGilly44444
    Eric
    19 4runner ORP 4x4
    3" icon lift
    My wife's outback is louder
    4runGirl88[QUOTED] likes this.
  24. Oct 17, 2022 at 2:48 PM
    #114
    j cat
    j cat New Member
    massachusetts
    could be the muffler is inside the plates or the cat converter ....
    run the engine under the runner then use a sound tool like a rubber tube to in your ear and the other orifice to sound the noise ..
    the muffler shield ?
    BigGilly44444[QUOTED] likes this.
  25. Oct 17, 2022 at 3:05 PM
    #115
    BigGilly44444
    Eric
    19 4runner ORP 4x4
    3" icon lift
    I got under it and tried finding it and checked for anything lose. Problem is you can't hear it under the vehicle or in the engine bay. Onlwhile sitting in the cab‍♂️ and of course Toyota just says they are noisy.
  26. Oct 18, 2022 at 2:00 PM
    #116
    j cat
    j cat New Member
    massachusetts
    the engine oil is the 0-20wt ... the SN PLUS is updated of the oil.....around 2018 ///...
    I did the 0-20wt with sn plus mobile engine oil ...engine runs a little bit ...
    I did the 1oz SN PLUS ADDITIVE ,,,....and the engine runs very good noise ... and the MPG is higher around 1-2 MPG ...650PPM...
    I did my boat engine FORD 470 MCM FLAT TAPPETS and the SN PLUS PUT IT IN ENGINE 5 OZ.....the engine runs quiet .... [ZINC ] ..2000PPM ..
    did you use the engine oil ?
  27. Oct 18, 2022 at 2:22 PM
    #117
    BigGilly44444
    Eric
    19 4runner ORP 4x4
    3" icon lift
    I have lifetime oil changes so yota does them
  28. Oct 18, 2022 at 3:36 PM
    #118
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I have M1 in the sump currently and it is much noisier than my other oil changes over the years.......I use whatever is cheapest. I don't care, I know it's protected perfectly. See you at 300k.
  29. Oct 18, 2022 at 3:56 PM
    #119
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    As previously said the robust timing chains that give the 4.0l it some of it's inherent reliability also makes a certain amount of noise that is normal. Especially 5th gen 1GR-FE4 dual VVT-I. I use the called for ilsac gf-6 motor oil for my 2022 and it does seem to make a difference noise wise. It always seems to be quieter with fresh oil. Change my oil every 6 months regardless of mileage as per severe service guidelines stated in the owner's manual. Not to open another online ****show but I was quite happy with how quiet my new engine was with the bottled Pennzoil Ultra Platinum I put in compared to the dealer's bulk synthetic oil they supplied.
  30. Oct 18, 2022 at 4:15 PM
    #120
    BigGilly44444
    Eric
    19 4runner ORP 4x4
    3" icon lift
    It just had an oil change 200 miles previous...sounds same at 5k
