Engine noise at idle
Discussion in '5th Gen 4Runners (2010-2024)' started by 2018newbie4rnr, Oct 1, 2020.
  1. Jan 16, 2021 at 11:21 AM
    Matt83
    Matt83 New Member
    Northeast
    The Toyota 0w20 is a great oil and much higher in Molybdenum then anything else. Go over to Bob is the Oil Guy and do some reading on it.
    With that said, any 0w20 meeting specs is fine.
    j cat likes this.
  2. Jan 23, 2021 at 5:22 AM
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
    I only use the Toyota 0W-20 oil with a TRD or Amsoil oil filter. As noted it's an excellent oil - manufactured by ExxonMobil to Toyota's specifications. The oil has a high level of Moly and Zinc additives - excellent for anti-wear. The TBN - Total Base Number is very strong - this supports Toyota's 10k OCI recommendation (I still do 5k OCI's). I buy it on Amazon for about $6.91 a quart. Here is the VOA Blackstone report I had done and posted on Bob is the Oil Guy:
    POWERPLANTHOMER and j cat like this.
  3. Jan 23, 2021 at 3:39 PM
    MAXIM
    MAXIM New Member
    1900 RPM on cold start up seem little high. It should be around 1300 at 20-32'F and settle down to 1000 within minutes. At what outside temperature you getting this 1900 RPM?
  4. Jan 24, 2021 at 7:33 AM
    gmoliver
    gmoliver New Member
    Thanks for the information. I live in the Deep South so temps are regularly on the warm side.
    I’ve checked this out and it appears to be normal start up.
    POWERPLANTHOMER likes this.
  5. Feb 18, 2021 at 5:27 AM
    RHUTCH
    RHUTCH New Member
    2021 $Runner SR5
    none
    Agreed... I just traded in my 2017 TRD Off Road because the engine noise was the worst I have heard in an car I have owned with any mileage since 1982. It had 30k miles. Unacceptable. I have the same 4.0 in my 2007 FJ and at 150k, it is difficult to know it's running it's so quiet. A 4th ten Runner with 180k parks in the space next to me, and my 30k and now NEW Runner make more noise - it's embarrassing. This is not normal and needs to be addressed by Toyota. I traded the TRD in for a New 2021 SR5 yesterday, and it is also noisy, but without the lifter noise that developed in the TRD. A new 4.0 motor from Toyota is $18k. I cannot see this engine going to 250-400k like the many FJs I see. There might be an issue the needs to be addressed in the software or perhaps there is a faulty sensor, low oil pressure? Who knows, but if it were in both cars I would accept the answer, "That's just the 4Runner or this engine." But the noise is not in all 4.0 engines. It is in recent 5th gen 4Runners. And if enough of us get together and write the issue might get resolved. Here is Scotty Kilmer on the subject. Here is his video on it. He ran a scan tool on it, with a 15k car, and the readings are not right, will we get the same:
    https://www.youtube.com/watch?v=4Ux667qwtGo
    As a group we will get better attention of the issue and perhaps a resolution.
    Toyota Motor Sales, U.S.A., Inc.
    P.O. Box 259001
    Plano, TX 75025-9001
    Toyota Phone: 800-331-4331
    Fax: 310-468-7814
    Mon-Fri: 8:00 a.m. – 8:00 p.m. ET
    Sat: 8:00 a.m. – 5:30 p.m. ET
    TTY/TDD Users: Dial 711, then request the operator dial 1-800-331-4331
    GazzaKid4runner and Trail Runnah like this.
  6. Feb 18, 2021 at 6:41 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    on my last oil change in nov2020 I added 1 OZ of
    Lucas Break-in Oil Additive TB Zinc Plus...
    now toyota oil has moly in it 800PPM .. well I put in mobil oil 0-20wt SN PLUS. I did the calculation to add 1 oz of the zinc plus and the oil will now have 1200 PPM..
    my engine is much quieter and my MPG increased a bit. I have a scan tool that indicate the MPG .. so the MPG rises a bit also.
    I used toyota oil prior to the nov 2020 oil change and this works the same . cost is $14 of the zinc plus 16 OZ..
    do not put more than 2OZ in the oil...
    on my 1996 chev Impala I added 2OZ in the oil and on a cold start it starts up quickly and has no engine noises.. zinc coats the metal protects when on a cold start.. engine spins faster.. on a cold crank ..
  7. Feb 18, 2021 at 7:53 AM
    mac1usa
    mac1usa New Member
    Has this proven to be an issue for anyone causing any significant repair?
  8. Feb 18, 2021 at 8:11 AM
    Matt83
    Matt83 New Member
    Northeast
    Not that I have ever seen or read about.
    Neighbors down the street have three 5th gens between 100,000 and 250,000 miles. All sound exactly the same and just like my 2019 with 17,000 miles.
  9. Feb 18, 2021 at 10:40 AM
    RHUTCH
    RHUTCH New Member
    2021 $Runner SR5
    none
  10. Feb 18, 2021 at 2:50 PM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Novel approach to that particular issue, but our engines are nasty noisy when idling, not just on start-up.
    And to take the above fix one level higher, I'd install an adjustable delay-on timer that gets 12v only when the key is in the "on" position and shuts juice after 2 seconds. Hitting that rocker switch every----single---time I start the truck would get old after awhile. Though to be honest, I've become quite the lazy muther....
  11. Feb 19, 2021 at 9:08 PM
    You'd think with all that overly complicated BS going on they'd have figured out how to make this engine make some useable power below 4k rpm.
    GazzaKid4runner likes this.
  12. Feb 20, 2021 at 9:13 AM
    j cat
    j cat New Member
    massachusetts
    my 4runner cold start below 40F has the 1800 rpm .. then the idle drops a couple of min..
    my other 2 GM V8 engines cold start is 1700 rpm ...
  13. Feb 20, 2021 at 11:13 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Dealer says that the noise I hear is injector noise. Are they using mini-hammers to open the injectors?
  14. Mar 14, 2021 at 7:20 AM
    GazzaKid4runner
    GazzaKid4runner New Member
    Dave
    2015 4Runner
    I purchased a 2015 4Runner with 65k and I’ve had it to two Toyota dealers as this is the noisiest engine I ever had. Both dealerships said it’s in good shape and this is normal 4Runner lifter noise?? I had a 2003 Tundra for 20 years with 240k on it and it didn’t make half the noise this engine makes. It sounds like a valve tap or it’s about to throw a rod. I’ve seen multiple posts on this and this can’t be normal engine noise. It’s sounds like Toyota doesn’t want to do a recall to address this issue.
  15. Mar 14, 2021 at 7:29 AM
    Lol.
    Mine rarely needs to go above 2500-3K. Getting on the freeway and passing are pretty much the only exceptions. Even getting on the freeway I don't usually need to go past 3K, unless I need to merge aggressively.
  16. Mar 14, 2021 at 7:37 AM
    I have read that the lifters are part of the cause. If I'm not mistaken, the lifters are solid, not hydraulic. I'm not sure why Toyota did this.
    Which motor was in your Tundra?
    The 4.7 V8 had a timing belt rather than a chain and those motors were nearly silent compared to the V6.
  17. Mar 14, 2021 at 7:46 AM
    Mtbpsych
    Mtbpsych New Member
    Lol, the 4.0 knock is normal. I’ve had two 4runners now, both of them had/have it.
  18. Mar 14, 2021 at 9:03 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Correction, 2nd gen 4 litres are noisy muthers. My 2007 FJ makes no such noise. And FWIW, I did an oil change using Amsoil XL 5W-30 and I swear the engine seems quieter after warmed up. Didn't check cold, will try to remember.
  19. Mar 14, 2021 at 9:16 AM
    #49
    Mtbpsych
    Mtbpsych New Member
    Good to know, I have no experience with the first batch of 4.0’s. I do remember trying 5w-30 in my first 4runner and it definitely made the knock quieter.
    7Runner and Thatbassguy like this.
  20. Mar 14, 2021 at 9:22 AM
    #50
    I would have guessed this was a matter of single VVT-I VS dual VVT-I, but my '15 Taco was a noisy one, too. I'm still curious what the reason behind the solid lifters was.
  21. Mar 14, 2021 at 9:24 AM
    #51
    Mtbpsych
    Mtbpsych New Member
    I came across a thread on t4r where a member posted a video, and was persistent with the dealer about the knock. A rep from corporate contacted him and confirmed that the knocking is due to a “piston slap”.
    who knows though, things run forever with proper maintenance so as long as I get some use out of it my engine can knock all it wants:D
  22. Mar 14, 2021 at 9:35 AM
    #52
    "Piston slap" sounds dirty. :D
    I'm happy with the performance of mine. At times I do wish it was as quiet as the 4.7 in my '03 was. At 257K miles, you could barely hear it idling. But, at 52K this motor seems to be getting better with age. Hopefully it will be as bulletproof as that 2UZ was.
  23. Mar 14, 2021 at 10:09 AM
    #53
    mac1usa
    mac1usa New Member
    I had piston slap in a 3.0 V6 Accord in 2005. It got worse and was awful in cooler spring weather or winter. The dealer and Honda to my suprise were awesome and replaced with a new crate engine (car was 7 years old with 38k miles). Hope this does not happen on a new 4R
  24. Mar 14, 2021 at 11:31 AM
    #54
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
    I just picked up a 2021 4 Runner Off-Rd premium engine sounds like its knocking 51 miles on it.I never heard it on the road test I think the radio was on then but i noticed it the next day
  25. Mar 14, 2021 at 11:36 AM
    #55
    Knocking or ticking? The valvetrain is very noisy on these motors. But, if you believe it's knocking, take it to the dealer. Maybe start another 4Runner on the lot to compare the noise.
  26. Mar 14, 2021 at 11:53 AM
    #56
    SYTY
    SYTY New Member
    I just went to check again sounds like a diesel engine at idle & just off idle. I was listining to the lower engine with a long screw driver to my ear sounded more like the lower half, the head & timing cover area was more of a faint ticking. Also i have to bring it back to check the alignment drifts right and wheel is slightly off to the right.
  27. Mar 14, 2021 at 3:01 PM
    #57
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Everybody complains about this.
    It’s a noisy engine. Normal.
    POWERPLANTHOMER and Thatbassguy like this.
  28. Mar 14, 2021 at 4:05 PM
    #58
    SYTY
    SYTY New Member
    Not every body buys a 40 + thousand dollar vehicle with a engine noise like diesel motor, I don't think a 2021 4Runner with a gas engine & 51 miles on it should sound like a diesel engine ever. i didn't buy this 4 runner with a diesel motor & i expect it not to sound like one.
    $40,000 is a lot of money to me not sure every one that says its normal has this kind of money to through around if they do than they have no worries. Sorry for the rant been a long day at work & i feel like i not getting a fare deal doesn't seem rite.
    I never seen any advertisements about 4Runners with a normal knocking motor for sale on tv or at any toyota dealers yet.
    Maybe it's just me but that's not normal.
    Trail Runnah and Thatbassguy like this.
  29. Mar 14, 2021 at 4:12 PM
    #59
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Other than the idle noise, how do you like it?
  30. Mar 14, 2021 at 4:14 PM
    #60
    mac1usa
    mac1usa New Member
    I feel for you dude. I am supposed to get one also and now wondering. $40k is a lot of cash for sure and i worked hard to get it like everyone else. I hope situation turns out ok. Please keep us posted.
