Engine air filter OEM vs replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by roymm, Aug 19, 2022.
  1. Jan 9, 2025 at 5:52 PM
    #91
    GrizzlyPro
    GrizzlyPro New Member
    2016 Quicksand 4Runner TRD Pro
    Dobinson snorkel, Hefty Fab Banshee bumper, Superwinch SX10SR, Gobi rack and widdle wadder and some aux lighting
    Thank you! I am kind of a nerd and very particular haha
  2. Jan 9, 2025 at 6:06 PM
    #92
    java
    java fauxrunner
    2023 ORP ice cap
    My dealer still carries them wonder if should buy more
    GrizzlyPro likes this.
  3. Jan 9, 2025 at 9:08 PM
    #93
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hah!
    Slick 4Runner you have
    GrizzlyPro[QUOTED] likes this.
  4. Jan 9, 2025 at 11:29 PM
    #94
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I would stay with OEM
  5. Jan 10, 2025 at 6:39 AM
    #95
    2016Pro
    It really doesn't matter just change them at proper intervals.
    icebear and Guppy1301 like this.
  6. Jan 10, 2025 at 7:19 AM
    #96
    GrizzlyPro
    I agree about intervals. But micron ratings and surface area do matter and affect how the oil breaks down with contaminants from anything that bypasses an air filter.
  7. Jan 10, 2025 at 7:25 AM
    #97
    2016Pro
    It won't affect the life of the vehicle. The only brand I'd avoid is k & n. They may cause some serious issues.
    Toy4X4 and GrizzlyPro[QUOTED] like this.
  8. Jan 10, 2025 at 9:38 AM
    #98
    Fram filters from Walmart work fine for me. Cheap, fit well and no trip to the dealer needed.
    icebear and 2016Pro like this.
  9. Jan 11, 2025 at 5:40 AM
    #99
    Guppy1301 and djwantke like this.
  10. Jan 11, 2025 at 8:54 AM
    #100
    Just put a Napa Proformer Air Filter in (part # 29350). For those that don't know, Wix makes Napa air filters. Thick filter with the pre-filter just like OE. The Napa Gold filters are slightly cheaper and have a thinner pre-filter.
    Toy4X4 and Guppy1301 like this.
