End of the gas engine?
Discussion in '5th Gen 4Runners (2010-2024)' started by YetiMtnBkr, May 22, 2023.
  1. Mar 14, 2024 at 2:50 PM
    #181
    Toyota hybrids and EVs have the same shitty brake pedal feel as our 4Runners, using similar electronic boosters :laugh: In hybrids and EVs it's to mask the changeover from regular braking and regen braking.
  2. Mar 14, 2024 at 2:59 PM
    #182
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Hydrogen is the future. Toyota is working on a H V8 and Cummins on a 15.0L. I am replacing my Ram with the hydrogen one when the time comes
  3. Mar 14, 2024 at 4:33 PM
    #183
    ^Hydrogen combustion doesn't give enough range. No way around basic thermodynamics.
    2Toys likes this.
  4. Mar 14, 2024 at 5:05 PM
    #184
    Yotaholic
    Olympia, WA
    I bet you don't know more than the titans like Toyota and Cummins.
  5. Mar 14, 2024 at 5:13 PM
    #185
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Sure perhaps that's true
    We've all seen the YouTube vids on Hydrogen outlining the other issue regarding the fact that level of Hydrogen in the gas tank decreases over time on its own unlike gasoline so some extent.
    But,everything's impossible, until it's not.
    "Magic" can be technology we just don't understand yet.
    And I always say, the laws of physics only are the laws of physics on this planet, in this dimension.
    We need to recover a crashed alien ship with hydrogen technology and reverse engineer that bitch
    HuskyMike and 2Toys like this.
  6. Mar 14, 2024 at 5:37 PM
    #186
    Yotaholic
    Olympia, WA
    Do you think gasoline cars and gasoline tanks were perfect right from the start? Of course not. Give them time, they will solve the problems of hydrogen.
    And don't forget, very recently scientists discovered another way to fuse hydrogen without nuclear reaction. Hydrogen is the future, hydrogen runs the universe, so not why not our machines.
  7. Mar 14, 2024 at 5:40 PM
    #187
    Yotaholic
    Olympia, WA
    Toyota is too conservative to come up with a product that will blow your mind. That's not their thing. But they will come up with the future Mirai that will give you 300 horsepower and 600 miles of range. Even today's Mirai is pretty neat.
  8. Mar 14, 2024 at 5:45 PM
    #188
    Yotaholic
    Olympia, WA
    Steve Berman likes this.
  9. Mar 14, 2024 at 5:49 PM
    #189
    Efficiency with burning a fuel is limited by basic thermodynamics. Look up carnot efficiency. The Mirai's hydrogen storage tanks have enough for only about 50 miles of range if burned in a combustion engine. Converting hydrogen into electricity through a fuel cell, being not a combustion process, is able to achieve much higher efficiency.
    The only place you'll see Toyota doing hydrogen combustion is in a racing program or demonstrator where range doesn't matter.
  10. Mar 14, 2024 at 5:50 PM
    #190
    Yotaholic
    Olympia, WA
    Youtubers know more than Cummins and Toyota engineers? I will not waste my time opening that video. Cummins website is more important to me
  11. Mar 14, 2024 at 5:58 PM
    #191
    Youtubers with engineering degrees cutting through marketing fluff.
    If you take time to read the Cummins page, they say hydrogen isn't a good choice for passenger cars i.e. contrary to what Toyota believes. There's nothing on that page at all suggesting they're developing anything for light truck applications. Expect the Cummins name to disappear from the Ram line once the diesel engines become too difficult to meet emissions requirements.
    semprenissart and djwantke like this.
  12. Mar 14, 2024 at 5:58 PM
    #192
    Yotaholic
    Olympia, WA
    Hydrogen not only is the future for cars, it is going to be the future for all our energy needs. Scientists have discovered how to fuse hydrogen without releasing radiations, those harmful radiations are the problem with nuclear reactions. We will have clean/safe hydrogen fusion
  13. Mar 14, 2024 at 5:59 PM
    #193
    Yotaholic
    Olympia, WA
    Lol. EV is all marketimg. Cummins will be there, rest assured.
  14. Mar 14, 2024 at 6:05 PM
    #194
  15. Mar 14, 2024 at 6:07 PM
    #195
    Yotaholic
    Olympia, WA
    Hydrogen Hilux baby. The world doesn't care about EV and Model Y bullshit.
  16. Mar 14, 2024 at 6:14 PM
    #196
    ^That has as much chance of reaching production as a V8 Tacoma - zero.
  17. Mar 14, 2024 at 6:16 PM
    #197
    Yotaholic
    Olympia, WA
    We will see.
    djwantke likes this.
  18. Mar 14, 2024 at 6:40 PM
    #198
    Spare Parts and Yotaholic like this.
  19. Mar 14, 2024 at 6:44 PM
    #199
    I'm indifferent on all this stuff
    But comparing Tesla sales to 4Runner sales I could care less, apples & oranges. 4Runner has next to zero sales attributed to honeymoon phase fads.
    Ain't nobody living out of a Tesla with solar panels in the bush. And then there's the 4Runner :p
    And, I am proof of this, the hottest chicks fckn dig 4Runner owners 10 to 1
  20. Mar 14, 2024 at 6:50 PM
    #200
  21. Mar 14, 2024 at 7:07 PM
    #201
    ^"FCEV" is short for fuel cell electric vehicle, i.e. not combustion.
    The article says Toyota will build 10 prototypes of the FCEV Hilux. That's very far from production.
    To put things in perspective, Toyota hand-built 400+ prototypes for 4th gen Tacoma development. That's the level of investment for a production model.
    djwantke[QUOTED] likes this.
  22. Mar 14, 2024 at 7:32 PM
    #202
    Good points
    But trying to dunk on ya
    But;
  23. Mar 14, 2024 at 7:33 PM
    #203
    Man I don't even want to know how many prototypes they built for the 4th gen 4R and still landed on that monstrosity (visually, imo) :D
    they started the big ass chunky spoiler too. The wiper and guts inside ain't that big..
  24. Mar 14, 2024 at 9:05 PM
    #204
    Yotaholic
    Olympia, WA
  25. Mar 14, 2024 at 9:11 PM
    #205
    Where's your rear-facing autocannon (deploy by rolling down rear hatch glass)?
  26. Mar 15, 2024 at 3:17 AM
    #206
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Why is it that EVs must be perfect for folks now? Shouldn’t we give them time before shitting on them?
  27. Mar 15, 2024 at 3:33 AM
    #207
    Daddykool
    I do find it curious that people think that Toyota hasn’t read all the same articles and seen all the naysaying videos regarding hydrogen. I’m sure they ignore those. Toyota (and Cummins, BMW, and several other companies) are investing a tremendous amount of money and resources into this technology. They all have teams of engineers as well, and they aren’t idiots. I don’t think that someone on this or another forum knows something about hydrogen that Toyota doesn’t.
    Spare Parts and Thatbassguy like this.
  28. Mar 15, 2024 at 4:23 AM
    #208
    To be fair, they've been around since 1888. :D
    I think some people are just looking for a better alternative.
    There needs to be a breakthrough in battery technology before I'll take them seriously as an alternative to ICE vehicles. A more environmentally friendly power supply would be a good start. Better range, and/or reduced charging times would also be good.
    I know things are improving. I'll be interested to see if they can ever really compete in a free market. Right now it feels like the government is just trying to mandate us into buying an inferior product.
    I do believe that they're a great option for some drivers, though. A lot of people never drive very far, so an EV is perfect for them.
    Daddykool and Texan4Runner like this.
  29. Mar 15, 2024 at 6:33 AM
    #209
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    The law of physics apply through the whole universe. No matter when and where you are.
    but I understand what you mean. We don’t know something exists or think that it is possible until we did it.
    Planes were an impossible concept to grasp 400 years ago. Going into space and landing on the moon did not make sense 100 years ago. A motorcycle that can go around a track faster than most people or a “taxi” with no driver was out of the question 50 years ago. All these are now reality though
  30. Mar 15, 2024 at 6:46 AM
    #210
    Spare Parts
    Southern Maine
    22 LR ORP
    agreed, it was a comment towards all those against EVs, but defending Hydrogen by saying give it time.
    At one point, I wouldn’t even bought a Hybrid, now I own a plug in hybrid.
    Imagine if we have up on Computers because they took up whole rooms.
    everything is a trade off, and nothing is a one size fits all.
