End of the gas engine?
Discussion in '5th Gen 4Runners (2010-2024)' started by YetiMtnBkr, May 22, 2023.
  1. Mar 22, 2024 at 12:55 PM
    #271
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    ^this really is true more than we've maybe ever realized. There's a shocking amount of sinister s*** going on with the people in power. The difference between the conspiracy theory and the truth is 6 months these days lol
    Thatbassguy, 2ndGen22re and rickystl like this.
  2. Mar 22, 2024 at 12:57 PM
    #272
    ATL4R
    ATL4R New Member
    2024 Limited
    Yet people still vote in the people pushing this crap. Decline is a choice.
  3. Mar 22, 2024 at 1:16 PM
    #273
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Ya'll are my type of people
    :cheers:
    seakuv, Fishhead74, 2Toys and 5 others like this.
  4. Mar 22, 2024 at 1:40 PM
    #274
    Funny reading this article posted by a member, keeps it real right at the end talking about how "[no one in the administration is claiming EV's are going to get cheaper for you by 2032, their electricity is being taxed and will continue to be heavily taxed in new clever ways because it's all about collecting money. The plan is only for internal combustion prices to rise by getting taxed up the ying yang (while EV's are for now, on average, are more expensive than internal combustion, but consistently lacking in infrastructure).
    And then you can believe our tax dollars are about to be used to eliminate and convert all the damn gas station pumps and underground tanks,]
    Thatbassguy and 2ndGen22re like this.
  5. Mar 22, 2024 at 1:42 PM
    #275
    America and it's evil top hat Canada need some serious governmental power changes imo
    Fishhead74, rickystl, 2Toys and 2 others like this.
  6. Mar 22, 2024 at 7:30 PM
    #276
    4R Florida
    4R Florida New Member
    Northeast Florida
    2024 4R Off Road
    Revolt by buying a brand new 4Runner right now if you can afford it, before they downsize it with the 4 cylinder turbo engine and 8 speed transmission next year to meet fuel economy requirements. If it's like the new Tacoma, as it is expected to be, I can't stand it. If you buy a new 4Runner now, we all know that it's good for about 15 years or more if you take good care of it. I'm still driving the 2011 FJ Cruiser that I bought 13 years ago! No batteries for me! Good old 1GR-FE 6-cyl for me!
    ualfltdispatch likes this.
  7. Mar 22, 2024 at 8:28 PM
    #277
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    So when the beer is warm, the game isn't available, and streaming services are down, what is the result? Complete anarchy?
  8. Mar 23, 2024 at 5:11 AM
    #278
    jgalt
    jgalt New Member
    I bet this thread and others like it wouldn't be locked if they were pro narrative. Censorship at even this level - nice.
    MI-FL off roader likes this.
  9. Mar 23, 2024 at 6:09 AM
    #279
    ualfltdispatch
    ualfltdispatch New Member
    2023 TRD Off Road Premium
    SPOT ON.
    rickystl and MI-FL off roader like this.
  10. Apr 7, 2024 at 3:25 PM
    #280
    If even some of this is true, it backs up the dark side of EV's that I keep repeating to climate alarmists:
    This is a Tesla model Y battery.
    It takes up all of the space under the passenger compartment of the car.
    To manufacture it you need:
    --12 tons of rock for Lithium (can be extracted from sea water)
    -- 5 tons of cobalt minerals (Most cobalt is made as a byproduct of
    the processing of copper and nickel ores. It is the most difficult
    material to obtain for a battery and the most expensive.)
    -- 3 tons nickel ore
    -- 12 tons of copper ore
    You must move 250 tons of soil to obtain:
    -- 26.5 pounds of Lithium
    -- 30 pounds of nickel
    -- 48.5 pounds of manganese
    -- 15 pounds of cobalt
    To manufacture the battery also requires:
    -- 441 pounds of aluminum, steel and/or plastic
    -- 112 pounds of graphite
    The Caterpillar 994A is used for the earthmoving to obtain the essential minerals. It consumes 264 gallons of diesel in 12 hours.
    Finally you get a “zero emissions” car.
    Presently, the bulk of the necessary minerals for manufacturing the batteries come from China or Africa. Much of the labor for getting the minerals in Africa is done by children! If we buy electric cars, it's China who profits most!
    BTW, this 2021 Tesla Model Y OEM battery (the cheapest Tesla battery) is currently for sale on the Internet for $4,999 not including shipping or installation. The battery weighs 1,000 pounds (you can imagine the shipping cost). The cost to replace Tesla batteries is in $US
    Model 3 -- $14,000+ (Car MSRP $38,990)
    Model Y -- $5,000–$5,500 (Car MSRP $47,740)
    Model S -- $13,000–$20,000 (Car MSRP $74,990)
    Model X -- $13,000+ (Car MSRP $79,990)
    It takes SEVEN years for an electric car to reach net-zero CO2. The life expectancy of the batteries is 10 years (average). Only in the last three years do you begin to reduce your carbon footprint. Then the batteries have to be replaced and you lose all the gains you made in those three years.
    Let that sink in.
    This kind of logical critical thinking is the dirty little truth about electric cars that is disregarded and gets you called a conspiracy theorist.
    ualfltdispatch, Gstick, Saker and 6 others like this.
  11. Apr 7, 2024 at 3:29 PM
    #281
    4R Florida
    Northeast Florida
    2024 4R Off Road
    :amen:
    Climate change is a cult and a scam at the same time.
  12. Apr 7, 2024 at 3:40 PM
    #282
    Right!?
    I call it the hysterical creepy sex cult
  13. Apr 7, 2024 at 4:34 PM
    #283
    mac1usa
    mac1usa New Member
    It’s a money maker is what it is.
  14. Apr 7, 2024 at 4:38 PM
    #284
    4R Florida
    Northeast Florida
    2024 4R Off Road
    That's the scam half of what I said. The other half is the cult.
    jgalt likes this.
  15. Apr 8, 2024 at 3:47 AM
    #285
    jgalt
    jgalt New Member
    Well done!!! The 30% with brains get this. The 30% in the middle might one day. The 30% who support evil will not let facts get in the way of their feelings.
    Gstick and rickystl like this.
  16. Apr 8, 2024 at 5:28 AM
    #286
    The fact that 60% (based on your numbers) still believe there's a real difference between the two main parties is a big part of the problem.
  17. Apr 8, 2024 at 5:31 AM
    #287
    jgalt
    jgalt New Member
    ^ Correct!
  18. Apr 8, 2024 at 6:17 AM
    #288
    Daddykool
    My two cents, which I occasionally drop into a conversation such as this, is that man-made climate change isn't provable.
  19. Apr 8, 2024 at 6:28 AM
    #289
    jgalt
    jgalt New Member
    rickystl likes this.
  20. Apr 8, 2024 at 9:47 AM
    #290
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    As I get older I see that lots of former conspiracy theoriesare true. There clearly is an agenda behind the destruction of Americas oil and gas industry. As example: The government control of oil drilling leases and production gets some attention, but not enough. It is part of a master plan to weaken America. The enemies of Freedom are continuously chipping away at our Country by every means they can!
    We need ICE for civilian freight moving and all our vast military vehicles from trucks to aircraft.. Can you imagine our military strategic oil reserves depleated-oh, I forgot they have been!
    2Toys likes this.
  21. Apr 8, 2024 at 9:58 AM
    #291
    jgalt
    jgalt New Member
    ^ Oil&Gas, food, "healthcare," freedom to think, much less speak, right to protect property, you name it. Oh, and nobody really owns "their" property either. As long as you have to pay taxes on it, your property is essentially in a lien. Stop paying taxes and your property is taken by the gov.
    2Toys and Fishhead74 like this.
  22. Apr 8, 2024 at 12:44 PM
    #292
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    The only law involving electric vehicles I would support is ALL energy used to charge them MUST come from wind, solar or nuclear plants. Otherwise it's nothing more than false virtue signaling. Even though a great deal of fossil fuels are needed to produce every part of those energy production methods.
    2Toys likes this.
  23. Apr 8, 2024 at 1:07 PM
    #293
    4R Florida
    Northeast Florida
    2024 4R Off Road
    And the batteries and car. See post #291. I reposted that in the 6th gen forum when people were talking about how great a "hybrid" 4Runner would be. Hybrid = all of the disadvatages of both electric and gas!
    rickystl and Rob41[QUOTED] like this.
  24. Apr 8, 2024 at 5:06 PM
    #294
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    We have 3 ICE vehicles, plenty for us to sit on the sidelines and watch how the great EV experiment pans out.
    2Toys likes this.
  25. Apr 8, 2024 at 5:20 PM
    #295
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Me too. New 2024 4R TRD OR so I'm all set. :popcorn:
    I can't wait for the EPA to have to set up Superfund sites to clean up the mess from discarded burned up batteries (they seem to like to burst into flames), toxic waste sites where companies try to recycle them and sites that try to dispose of them, etc. For now they will just hide the mess and lie about it. Post #291 addresses the mess made when people try to make these things. They also have to be disposed of. Giant worn out windmill blades are piling up in huge stacks because nobody can recycle them profitably or dispose of them properly.
    When people write ICE all I think of is Immigration and Customs Enforcement, which is a whole other disaster like EPA.
    2Toys likes this.
  26. Apr 8, 2024 at 5:34 PM
    #296
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Fewer and fewer people want a new vehicle with a giant battery. Then those who buy them, including hybrid, will get killed on the trade in or resale later!
    This piece on Yapoo News is laughable:
    "... the same price decreases that make used EVs affordable make them harder for traditional used car business models to make money on. What’s more, used EVs are more complicated to sell than conventional cars.
    One challenge dealers face is that used EV values depend on novel metrics — primarily battery health — that used-car dealers and financers aren’t used to quantifying. That makes it harder to establish their appropriate resale prices, or calculate the risks that financiers take on by lending against a vehicle they might have to repossess.
    Another problem is that it takes extra work to combine the $4,000 federal tax credit for used EVs with state and utility incentives into an up-front discount on a vehicle’s purchase price — a step that experts agree makes a big difference for cash-strapped car buyers.
    If these barriers aren't resolved, the used EV market could wind up growing slower than its full potential, holding up the EV revolution ..."
    So we are subsidizing this crap too! Subsidize it when sold new and then AGAIN when sold used!
    Doesn't sound like much of a "revolution" to me unless you mean revolutionary taxation to pay all of the subsidies.
    "... the number of used EVs sold in the U.S. grew from 283,000 in 2022 to just under 400,000 in 2023, and are expected to reach nearly 560,000 in 2024."
    As people figure out they suck and dump them.
    Oh, and it costs more to insure one, especially a new one, because a little fender bender accident can easily total the car due to battery replacement cost. People buying these nightmare battery jobs aren't thinking things through.
  27. Apr 8, 2024 at 6:28 PM
    #297
    Yeah, more torque, better fuel economy, what a nightmare. :rolleyes:
  28. Apr 8, 2024 at 6:29 PM
    #298
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Yep, battery = nightmare. Read the thread. I'll ask you 15 years after you buy one. Good luck.
  29. Apr 8, 2024 at 6:40 PM
    #299
    Read what thread? I've already read practically every thread on this forum.
    The battery in a hybrid is not as big as the battery in an EV. Toyota has proven that they can be reliable. There are plenty of 200+K mile Priuses out there.
    I wouldn't hesitate to buy a plug in hybrid if I needed a fuel efficient vehicle for commuting and occasional traveling.
  30. Apr 8, 2024 at 6:43 PM
    #300
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Age kills as bad as mileage. Bad for the environment to make, bad for the environment to dispose of, more expensive to insure, wears out, low resale value compared to gas, etc. I'll ask you 15 years after you buy one. Good luck.
