Eibach Pro Truck Lift Kit Stage 1 vs Stage 2
Discussion in 'Suspension' started by ShaggyDoge, May 3, 2022.
  1. Jul 19, 2023 at 7:38 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  2. Jul 19, 2023 at 8:10 AM
  3. Jul 19, 2023 at 8:58 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
  4. Jul 19, 2023 at 9:49 AM
  5. Jul 19, 2023 at 9:56 AM
    You can buy everything separately. I believe the pair of front coilovers is around 900 bucks.
    The rear springs are the same rate as stock, so unless you think your stock springs need replacing, a 1" spacer would do the trick.
  6. Jul 19, 2023 at 9:58 AM
    Good point about the spacer vs. a new spring. Mine just hit 13k miles, so I think they're up to the task. Thanks for pointing that out.
