Eibach pro kit stage 1
Discussion in 'Suspension' started by Silverghost, Apr 7, 2020.
  1. May 22, 2020 at 9:13 PM
    #151
    HankL818
    HankL818 New Member
    2020 ORP w/KDSS
    No, I had a 4x4 shop install mine with alignment. I don’t have the proper tools and space to do this myself, especially dealing with KDSS.
    Good luck with your kit, you will love the new ride experience!
  2. May 29, 2020 at 1:20 PM
    #152
    jcarey987
    jcarey987 New Member
    2019 White 4Runner TRD Offroad
    Last week I got a call from BuyBrakes saying that Eibach informed them that I wouldn't get a shipment until June 26th. I checked my junk folder on my email and found a shipment notification, the expected delivery date is June 2. Now to get my JBA UCAs ordered. The frustrating thing is that I have already swapped by 2019 OR wheels for TRD Pro wheels, which will not allow for 285s with the JBAs.. oh well, i will just go with 275 BFG KO2s.. i'll lose the 1/4" but will save about $300 between the tires and other brands of UCAs.
  3. May 29, 2020 at 3:01 PM
    #153
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    Exact setup I’m running. Pics are in some posts above (gray wheels instead of black)
  4. May 29, 2020 at 3:11 PM
    #154
    TOYONICK
    TOYONICK New Member
    2019 TRD Off Road Premium
    you still rubbed with 275 and having the Eibach installed?
  5. May 29, 2020 at 3:19 PM
    #155
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Was going with the exact same setup except I was using the OEM OR wheels. I thought they would work but after I bought the JBA’s I looked at the website and my wheels with 285’s won’t work. Contemplating 275’s or just biting the bullet and getting new wheels and 285’s that will fit. First world problems...
    Those JBA control arms are beefy..
  6. May 29, 2020 at 3:37 PM
    #156
    TOYONICK
    TOYONICK New Member
    Do you think 285's would fit if you didn't use the JBA UCA's? I have the TRD Pro rims and want to go 285's with this kit.
  7. May 29, 2020 at 3:43 PM
    #157
    Cheapest route is to get wheel spacers.
    That might not be your thing though......I don't know.
    Of course getting wheel spacer (or negative offset wheels) may cause rub on the body mount or fender plastics, so that might need trimming.
  8. May 29, 2020 at 3:44 PM
    #158
    That'll work. You may need to trim a little.
  9. May 29, 2020 at 3:47 PM
    #159
    Just get a different UCA.
    These are highly rated and are only $100 more than JBA's.
    https://dirtkingfabrication.com/col...ducts/ball-joint-upper-control-arms-dk-812901
    Commited likes this.
  10. May 29, 2020 at 3:49 PM
    #160
    TOYONICK
    TOYONICK New Member
    I don't mind a little trimming.
    I have it down to 3. Eibach pro kit, Bilstein 6112/5160 stage 2 kit, and the Icon Stage one. The Eibach appears to be the only one that is under 3 inches, but if I can fit 285 its worth the savings.
  11. May 29, 2020 at 3:52 PM
    #161
    Commited
    Commited New Member
    Oscar
    So Cal
    Not sure as I don’t have a lot of experience with this, I just try to research and ask questions. I was going back and forth between JBA and Dobinson’s but once you have them pre-assemble them and shipping, your looking at around $700 +. The JBA’s were the best value in my opinion. Just in what I’ve read, there are probably other UCA’s that will accommodate the setup you want.
  12. May 29, 2020 at 3:56 PM
    #162
    You can fit 285's on a stock 5th gen with some minor trimming.
    It's not the lift height that's the issue. It the fender width.......as in you can easily rub on the front or back of the fender well. Wheel spacers and/or negative offset wheels exacerbate it.
    I have Eibachs. I love them so I can't recommend them enough. Bilstein 6112/5160's are great as well, but more expensive and to be honest, I don't think you get much more for the extra money you spend on them. Others may disagree with that. Icon......I don't have much experience with, but have heard quite a few negative things about leaky shocks. Maybe that's been fixed.
  13. May 29, 2020 at 4:00 PM
    #163
    TOYONICK
    TOYONICK New Member
    Yeah, people seem to be completely divided on Icons. some say they are absolute Garbage, and some say they can go for 50k plus miles without needing a rebuild. I like the whole rebuild factor and kings are out of my price range. Unfortunately I have heard more bad than good about the Icons.
  14. May 29, 2020 at 4:07 PM
    #164
    Yeah, I've heard the same about Icon. For that reason alone, I'd consider something else, personally. I wouldn't feel comfortable risking it. Yes, King coilovers are more expensive, but they are for a reason. The quality of Kings is very high. Do you really need coilovers? If you want them, get them but you might be able to get by just fine on a coil/strut kit like Eibach or Bilsteins.......which are both very high quality as well.
    Oh yeah.....forgot to say that Eibachs an Bilsteins have options to lift between 0 to 2.75" or so. You're going to want to stay below 3" otherwise you start running into CV angle issues.
    7385 likes this.
  15. Jun 1, 2020 at 3:34 PM
    #165
    850RedRunnerORP
    850RedRunnerORP New Member
    FL
    '18 Barcelona Red ORP
    Eibach Stage 1 kit 285 BFG K02s
    Finally got my shipment notification from buybrakes. Kit should be here end of this week!
  16. Jun 1, 2020 at 3:38 PM
    #166
    850RedRunnerORP
    FL
    Will 285's not work on the OEM OR wheels because of the aftermarket JBA's or did it tell you that 285's won't fit on the OEM wheels? I'm planning on running 285 KO2's on OEM wheels and didn't think that would be an issue since I feel like I've seen others with that setup. Is that not going to work?
  17. Jun 1, 2020 at 4:23 PM
    #167
    Commited
    Commited New Member
    Oscar
    So Cal
    My interpretation of the graph on JBA’s website was that the size of the tire (285’s) and combination of the OR wheel offset and backspace you’ll rub, again that’s the way I interpreted it. I tried calling and emailing them a few times but never got thru. So I just purchased wheels with offset and backspace according to the graph on the website that will work with a size 285 tire. However, 275’s will work with the OR wheels. They also specify BF Goodrich tire measurements, so if you’re going with another brand tire, I would make sure that they are close to being the same as BFG KO2’s. Or go with another brand of UCA. Hindsight I should’ve done more research, probably would have gone with another brand because I wanted to hold on to the OR wheels for at least a couple of years, but hey it was inevitable that I would get new wheels, just got em sooner...
  18. Jun 1, 2020 at 5:08 PM
    #168
    285's work on the OEM OR wheels just fine.
    It's the combo of the JBA's with 285's and the OR wheels that can cause rubbing on the JBA UCA.
    You can run all of these together if you get a wheel spacer.
    Or you can run the OR wheels and 285's with a different UCA.
    Or you can run the 285's and JBA's with a wheel that has a different offset and backspacing than stock.
    7385 and Commited like this.
  19. Jun 1, 2020 at 5:27 PM
    #169
    Commited
    Commited New Member
    Oscar
    So Cal
    That’s a pretty good explanation of how It works.
    nimby[QUOTED] likes this.
  20. Jun 2, 2020 at 4:07 AM
    #170
    850RedRunnerORP
    FL
    Awesome, thank you for the info gents. I already have wheel spacers and was waiting to see how it looked with 285s before installing them.
    I figured I would have to do some sort of trimming, etc. just wanted to make sure I didn't have to get new wheels for 285s.
    Thanks again!
  21. Jun 2, 2020 at 5:20 AM
    #171
    wmdtech
    Nate
    Mid TN
    18 TRD ORP
    Biggest issue with running 285 on stock wheels is the wheel width, regardless of what UCAs you run. It is “recommended” that a wheel width of 7.5 inches minimum for 285. You’ll end up ballooning the side walls. To each their own, but manufacturers know a thing or two (or at least we hope they do) which is why I went 275 KO2. Eventually I’ll run some 285 on SCS or something similar but for now the 275s look good, ride nice, even if they’re heavier than hell
  22. Jun 2, 2020 at 6:12 AM
    #172
    The OR wheels are 7.5" wide.
    850RedRunnerORP likes this.
  23. Jun 2, 2020 at 8:28 AM
    #173
    wmdtech
    Nate
    Mid TN
    18 TRD ORP
    My bad, I have the gray pro wheels, 17x7. Regardless, that’s why I’m sitting with 275
    nimby likes this.
  24. Jun 2, 2020 at 10:02 AM
    #174
    Gotcha. I suspected that's what you meant, but wast sure. Just wanted to make sure the correct info is out there for people considering OR (and Pro) wheels.
    A lot of people still put 285's on 7" wide Pro wheels, but you're right, most tire manufacturers suggest at least a 7.5" wheel width for that tire size. I personally would have zero problem it, but some people do and that's fine.
  25. Jun 2, 2020 at 11:56 AM
    #175
    TOYONICK
    TOYONICK New Member
    just pulled the trigger! Supposedly they are in stock. Saved about $1k by not going with Icon stage one. Might as well get bigger tires to celebrate :muscleflexing:
    nimby likes this.
  26. Jun 2, 2020 at 12:58 PM
    #176
    kami
    kami New Member
    Ordered in April, came in Yesterday... Just in time for another deployment. I guess they'll be waiting in the box.
    DRobs likes this.
  27. Jun 6, 2020 at 2:20 PM
    #177
    KSapanza4Runner
    KSapanza4Runner New Member
    Ken
    2018 Silver Toyota 4runner SR5
    Will post better pics later but finally got my kit installed today with the help of my buddy. Took about 3.5hrs and overall not bad a experience with the install. Thank god for the auto hobby shop here on base. Only paid $17 to use the lift.
    DRobs and Cis915 like this.
  28. Jun 6, 2020 at 3:46 PM
    #178
    Silverghost
    Silverghost [OP] New Member
    2020 venture
    Trd pro grill, Trd skid plate, trd led foglamps, trd exhaust, led hi and low beam headlights, full led interior lights, raptor grill lights, eibach lift kit, rsg sliders, falken wildpeak 275 tires, oem black hood scoop, tinted windows. More to come
    Looks good man, nice having a lift to work on truck.
  29. Jun 8, 2020 at 7:52 AM
    #179
    KSapanza4Runner
    Ken
    Update: Couldn’t help myself and had to test out the new lift on some trails with my friends. Got a little muddy but handled everything very well. Next up, tires!
    7385 and nimby like this.
  30. Jun 8, 2020 at 9:05 AM
    #180
    850RedRunnerORP
    FL
    Got the kit and 285 KO2's installed over the weekend. Love it!
    Chops84, DRobs, 7385 and 7 others like this.
