Eibach pro kit stage 1
Discussion in 'Suspension' started by Silverghost, Apr 7, 2020.
  1. May 3, 2020 at 12:05 PM
    #91
    A lot of times you're still able to get your 4Runner back in spec with the 2.75" Eibach lift in the front, but you're probably on the lower end of the caster spec (+2.6 degrees). The truck drives a lot better when you're at the higher end of the caster spec (+4 degrees) and that's impossible to get with a 2.75" lift and stock UCA's.
    If you're happy with the way it handles, then you're good. If you wander on the highway a bit and wished the handling was better, then UCA's will help that a lot.
    pk808[QUOTED] likes this.
  2. May 3, 2020 at 2:34 PM
    #92
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Any one running the Pro Kit that has KDSS? Looking at different builds looks like 3” is the max lift for a vehicle with KDSS. The Pro Kit lift from Eibach is 2.75 upfront which is pretty darn close to the max limit. Anyone having or had issues with it? I’m asking cause I’m about to pull the trigger on it or go 6112’s / 5100’s. Thanks.
  3. May 3, 2020 at 9:11 PM
    #93
    pk808
    pk808 New Member
    Hawaii
    2020 T4R Nautical Blue Venture 4x4
    No wandering for me while driving. Mine is currently at 2.8% which is within spec of 2.8 to 3.8 (just made it!). At least, that’s the spec range the technician utilized.
    nimby[QUOTED] likes this.
  4. May 3, 2020 at 9:15 PM
    #94
    Why would you say that KDSS-equipped 4Runners are limited to a maximum of 3" of lift? Not that I plan to lift mine any more, just curious as to where that comes from...I've seen plenty of postings with the Eibach Pro Truck lift on KDSS vehicles.
  5. May 3, 2020 at 10:08 PM
    #95
    Commited
    Commited New Member
    Oscar
    So Cal
    I did a search and most say max lift is 3”. I’ll try to post a link from Accutune, they recommend not going over 2.5”. Just trying to get some accurate info from guys that actually have the entire kit installed with KDSS.
  6. May 5, 2020 at 9:08 AM
    #96
    jcarey987
    jcarey987 New Member
    2019 White 4Runner TRD Offroad
    Anyone have firm date on when Eibach is going to start shipping?
  7. May 5, 2020 at 9:18 AM
    #97
    Dark Knight
    Dark Knight Get off my lawn
    My buddy was told last week from toytec it would be 1-2 weeks
  8. May 5, 2020 at 9:18 AM
    #98
    Silverghost
    Silverghost [OP] New Member
    2020 venture
    Trd pro grill, Trd skid plate, trd led foglamps, trd exhaust, led hi and low beam headlights, full led interior lights, raptor grill lights, eibach lift kit, rsg sliders, falken wildpeak 275 tires, oem black hood scoop, tinted windows. More to come
    I havent heard but tried to get a hold of them 2 weeks ago to get some bump stops, left a message and havent heard back yet.
  9. May 5, 2020 at 9:23 AM
    #99
    Commited
    Commited New Member
    Oscar
    So Cal
    Ordered the Pro Kit Stage 1 direct from Eibach. I received an email that kits could start being sent out by May 6th. I would imagine 3rd party vendors might be a week or 2 behind that date.
  10. May 6, 2020 at 10:05 AM
    #100
    jcarey987
    You mind letting us know when you shipment notification hits?
    7385 likes this.
  11. May 6, 2020 at 11:04 AM
    #101
    Commited
    Commited New Member
    Oscar
    So Cal
    Will do, I was going to wait a day or 2 before trying to contact them.
  12. May 6, 2020 at 12:33 PM
    #102
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    Ordered mine through wheelers.com and I had it in about a week. Price was good as well, just did the email sign up and got 10% off plus free shipping. With assembly it was around $760 all together.
  13. May 6, 2020 at 3:48 PM
    #103
    Silverghost
    2020 venture
    I did same went thru wheelers.com $760 Assembled and got it within a week.
  14. May 7, 2020 at 7:20 AM
    #104
    wmdtech
    Nate
    Mid TN
    18 TRD ORP
    I ordered a t-shirt from Eibach on 30 APR, still haven't received shipping notification. Not sure if that helps, but whatever
  15. May 7, 2020 at 7:33 AM
    #105
    Commited
    Commited New Member
    Oscar
    So Cal
    Update: Received a notification from Eibach, my kit is scheduled to be shipped on Monday the 11th
  16. May 7, 2020 at 10:10 AM
    #106
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I’m interested in using these rear springs with an ELKA suspension, and I didn’t see that Eibach specified any requirement for a spacer. Is this essential? ELKA engineering is pretty high tech, and doesn’t require any spacers, and specifies KDSS equipped or not. I liked the Eibach rear spring because it only gives 1” of lift, which should be perfect. Btw, does anyone know how this spring is rated relative to the stock spring? If I end up using a spacer anyway, I may as well just put a spacer on my stock springs. I’m hoping the Eibachs will be a little heavier than stock.
  17. May 7, 2020 at 10:35 AM
    #107
    Charlievee
    Charlievee Not new member.
    Not sure of the exact numbers,i will find them when i get a minute. They are rated heavier then stock. The spacer is for esthetics, IOT take out the lean on the driver side rear.
  18. May 7, 2020 at 10:43 AM
    #108
    Dark Knight
    The front kits specify KDSS or not because of the reservoir mounting location. Very possible you could still have some “lean” if you don’t adjust the compression collar to account for it.
  19. May 7, 2020 at 3:47 PM
    #109
    Charlievee
    Rear springs - E30-82-071-01-02 "206 lbs"
    Still need to find the stock spring rate.
    Oldtoyotaguy and 7385 like this.
  20. May 7, 2020 at 4:51 PM
    #110
    Finding the stock spring rate is going to be hard. I think you need actual spring measuring equipment to determine this and places that have this equipment don't usually give their numbers up readily.
    I tried to find the answer to this a while ago and the answers varied a bit, particularly in the front.
    Fronts ranged from 550 - 600 lbs.
    Most people seemed to think the stock rears are around 200 lbs.
  21. May 7, 2020 at 4:59 PM
    #111
    Oldtoyotaguy
    Interesting, basically stock with increased length. Hmm. Thanks guys, I really appreciate your help!
  22. May 7, 2020 at 6:14 PM
    #112
    Charlievee
    Its been posted, but the search functions are not what they used to be.
  23. May 7, 2020 at 6:15 PM
    #113
    ForRun
    ForRun 4Runner
    2020 orp
    The spacer is not required. Some 4runners have the "lean" where it sits lower on the drivers side. Mine is 1/2" lower, my old pro was 3/4". Some runners are smack dab even? dunno why? That 10mm spacer levels the rear ~1/2" if you have the lean
  24. May 7, 2020 at 6:49 PM
    #114
    Charlievee
    I have seen one or two running 4th gen rear springs, they say it lifts 3/4" . I cannot confirm or deny.
    Oldtoyotaguy[QUOTED] likes this.
  25. May 7, 2020 at 8:28 PM
    #115
    HankL818
    HankL818 New Member
    2020 ORP w/KDSS
    Eibach’s claim of 2.75” & 1” lift is pretty spot on for me. 2 weeks and 100 miles in, no spacers, my DR is about 3/4” higher than the other 3 corners. I think that’s still within Toyota’s spec in height difference. Doesn’t bother me.
    Oldtoyotaguy likes this.
  26. May 8, 2020 at 6:29 AM
    #116
    Oldtoyotaguy
    Haha, I might have trouble with something like that. But that’s just me.
    brownersd and HankL818[QUOTED] like this.
  27. May 8, 2020 at 8:08 AM
    #117
    HankL818
    HankL818 New Member
    2020 ORP w/KDSS
    Could have been worst with a reversed rake... that I cannot stand.
  28. May 8, 2020 at 8:46 AM
    #118
    Oldtoyotaguy
    Oh yeah, for sure I agree!
  29. May 8, 2020 at 8:48 AM
    #119
    Bro-Leanin' Liberal
    Bro-Leanin' Liberal New Member
    2008 BroRunner
    As much bro-lean as possible
    Not sure what you're talking about.
    I have the hottest looking rig in this entire place.
  30. May 8, 2020 at 2:45 PM
    #120
    13ToySR5’18
    13ToySR5’18 New Member
    Shane
    2018 white 4Runner 4x4
    Ultra Motorsport wheels blk w/milled accents on Toyo open country a/t III
    Should have went smaller rims and saved a lil cash for the other half of that lift
