Eibach pro kit stage 1
Discussion in 'Suspension' started by Silverghost, Apr 7, 2020.
  1. Aug 10, 2020 at 8:09 PM
    #271
    Looks awesome!
    What size tire you thinking about?
  2. Aug 11, 2020 at 12:30 AM
    #272
    BCMb808
    BCMb808 New Member
    Oahu, Hawaii
    2018 Sr5p 4x4
    DRobs, GRIZ, Cis915 and 3 others like this.
  3. Aug 11, 2020 at 2:39 PM
    #273
    BicDaddy
    BicDaddy New Member
    2020 4Runner
    Tough tough call re: size of Toyo.
    My buddy did the same lift and absolutely loves the 285’s. No cutting or rubbing.
    However, I’ll prob stay stock size per recommendations on the TRD rims. Something about becoming an old man.
    Fez Runner, Reldn, a-double and 2 others like this.
  4. Aug 11, 2020 at 2:53 PM
    #274
    Damn, i really like that paint job, beautiful truck.
    BicDaddy[QUOTED] likes this.
  5. Aug 11, 2020 at 8:35 PM
    #275
    KSapanza4Runner
    KSapanza4Runner New Member
    Ken
    2018 Silver Toyota 4runner SR5
    What tire sizes is everyone running with the lift? Any other mods with the lift as well?
  6. Aug 11, 2020 at 10:53 PM
    #276
    BCMb808
    BCMb808 New Member
    Oahu, Hawaii
    2018 Sr5p 4x4
    I got 265’s on mine. Might go bigger when these wear down. Relocated the front liners, trimmed some bumper and pushed in mud flaps.
  7. Aug 12, 2020 at 5:00 AM
    #277
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Leaving this here:
    Spring rate for front Eibach Coils = 662lbs Spring rate for rear Eibach Coils = 206lbs +/- 2%
    nimby likes this.
  8. Aug 30, 2020 at 9:41 AM
    #278
    thekrouse
    thekrouse New Member
    BFG KO2 now have a C rated option for some sizes. I got 265/70/17 in C rated. I used to run wild peaks for the C rated but love the new KO2’s in the C rating
  9. Sep 8, 2020 at 8:41 PM
    #279
    Cis915
    Cis915 New Member
    Donovan
    Las Vegas
    '18 Nautical Blue TRDOR
    Eibach Pro Lift; 255/80 Open Country R/T Trails; Motegi Trailite; LFD 7/8; BMC/Pinch Welds; All-Pro Sliders; Custom Drawers; T10 v3; DD SS18 Light Bar; Baja Squadron Pro Ditch Lights; Auxbeam Switch; Alpharex Headlights; Spyder Taillights
    Finally installed the kit. Definitely agree that it rides MUCH better. No brake dive and body roll is significantly improved. Very happy with my purchase so far. 275/70 Wildpeaks on FN wheels.
    GRIZ, HankL818, ForRun and 2 others like this.
  10. Sep 9, 2020 at 7:00 AM
    #280
    Congrats! Looks great!
    Cis915[QUOTED] likes this.
  11. Sep 9, 2020 at 8:15 AM
    #281
    Cis915
    Cis915 New Member
    Donovan
    Las Vegas
    Thanks!
    nimby[QUOTED] likes this.
  12. Sep 11, 2020 at 7:50 AM
    #282
    Miller1236
    Miller1236 New Member
    Chicago
    2020 TRD Premium OR
    Interior LED,LED Back up Lights, Oem Led fog lights,Screen Protector,Canvasback Cargo Liner, Front Film Protection,TRD skid plate, Eibach Pro lift kit, JBA Uca. OEM Door edge protection, Rola cargo roof rack
    I finally installed my Eibach stage 1 kit with JBA std high caster and had an alignment, here is a pic after alignment question is this ok or do I need to go back and have then realign.
  13. Sep 11, 2020 at 8:18 AM
    #283
    I'd either ask for your money back on that one or have them re-do it for free.
    I can't tell if they are incompetent, lazy, or dishonest.
    The biggest change made was by 0.1 and they didn't even get your toe in spec. Caster numbers are way off from one another.
    Perhaps they need some direction?
    Tell them you want the caster on both sides to match (or at least closer to one another) and you want it in the +4.5 range (I'm assuming you want your caster on the higher side since you bought high caster UCA's).
    Then you want the toe and camber close to zero.
    7385 likes this.
  14. Sep 11, 2020 at 8:29 AM
    #284
    Miller1236
    Chicago
    2020 TRD Premium OR
    I new something was wrong. I even gave the the spec sheet that JBA gave me, will have to go back I have a year for them to get it right.
  15. Sep 11, 2020 at 8:31 AM
    #285
    Miller1236
    Chicago
    2020 TRD Premium OR
    Does anyone have a picture of the correct alignment to show them.
  16. Sep 11, 2020 at 11:23 AM
    #286
    Miller1236
    Chicago
    2020 TRD Premium OR
    When and got my money back they told me it could not be done. Looking for a shop in Illinois that know what to do.
  17. Sep 11, 2020 at 1:45 PM
    #287
    So I guess we figured out they are all three (incompetent, lazy, and dishonest).
    Yes, go to another shop. Show them what you've done with the suspension upgrades and tell them what you're looking for. A competent shop should have no issue getting the specs close to what I mentioned above.
    7385 likes this.
  18. Oct 29, 2020 at 1:55 PM
    #288
    GRIZ
    GRIZ New Member
    San Pancho
    2019 Nautical Blue TRD ORP
    Heritage PRO Grille, General Grabber ATX, Diode Dynamics SS3 Sport Fogs, 1" front spacers by 88Rotors, Blacked out Emblems, USR Black Tail Lights, Raptor Lights, MESO Puddle Lights
    Update on the stage 1 kit, when I installed the kit I did the recommended front setting at the first clip thinking it would be more than enough but added a half inch corned spacer to the rear to get 1.5" in the rear but ended up with 2" instead. That resulted in a factory looking rake but lifted and wish I had done the second clip instead. I waited a few weeks to see if the rear would settle and it stayed the same. I was preparing for bigger tires from 265's so when I went to a shop to have my bmc done and I also had them change the clip setting. I had the second clip in mind but they encouraged the third clip instead as a buy once cry once and said f*** let's do it (thanks stellar built) and I was also going to upgrade UCA's anyway. Long story short, the rig looked exactly how I envisioned it when I first installed the lift after changing it to the third clip. Factory looking rake is gone and is completely leveled for now until I start adding weight to the front.
    brownersd, DRobs, 7385 and 2 others like this.
  19. Oct 29, 2020 at 2:08 PM
    #289
    goicuon19
    goicuon19 New Member
    Phil
    Portland, OR
    2020 Magnetic Grey TRD Off Road Premium
    Eibach Lift Kit 2.75in front / 1in rear JBA Off Road UCA K&N Cold Air Intake TRD Exhaust Alpharex Luxx Series Alpha Black Morimoto XB Fog Lights LED Interior Swap Predator Tube Steps Black Sequential Side Mirror Turn Signal Black Rhino Sidewinder Wheels 275/70/17. BFG KO2
    7385 likes this.
  20. Oct 29, 2020 at 4:17 PM
    #290
    glass
    glass Knick knacks and grocery bags
    CA
    18 ORP
    Love your truck!
    GRIZ[QUOTED] and 7385 like this.
  21. Oct 29, 2020 at 4:51 PM
    #291
    Looks awesome!
  22. Nov 4, 2020 at 1:15 PM
    #292
    kittyhawk
    kittyhawk New Member
    Dave
    2013 4Runner SR5
    None
    After reading pages and pages and pages on multiple forums I pulled the trigger and
    just ordered the Pro kit stage 1 for my 13 SR5 2x4. I got them pre-assembled at 2.75. The trucks currently at 145,xxx miles And going to have my shop install the kit and check the to see if anything is needed to be replaced. I'm hoping to get away without uca but if I need then whats everyone's thoughts on Freedom Offroad. Also what else am I going to need?
  23. Nov 6, 2020 at 3:22 PM
    #293
    KSapanza4Runner
    Ken
    No problem with the 285s fitting?
  24. Apr 7, 2021 at 6:16 AM
    #294
    Chops84
    Chops84 New Member
    Ryan
    2021 4runner
    Did you have any problems with reverse rake after installing the Eibach kit? I know some people are using stock or wheelers springs. Your rig looks great!
  25. Apr 7, 2021 at 8:30 AM
    #295
    850RedRunnerORP
    850RedRunnerORP New Member
    FL
    '18 Barcelona Red ORP
    Eibach Stage 1 kit 285 BFG K02s
    Thank you sir! I'm very happy with the setup.
    No reverse rake at all for me. I'm also one of the lucky ones that didn't get any rubbing either, with stock UCA's and 285's.
    This pic was when she was loaded down in the back for a family trip, and still no reverse rake.
    nimby likes this.
  26. Apr 17, 2021 at 8:15 AM
    #296
    Here's a question for those who would know - supposing I could find some in stock somewhere, from time to time I consider adding the Pro Truck springs to my setup to complete the stage 1 lift. My question is, what needs to be undone to remove the complete front strut & spring? I feel like I can get access to a spring compressor (not the 2-piece auto parts version), and would like to see what's involved. When I installed the Eibach struts, I used the no-compressor method, but that was a lot of work with my KDSS...maybe not so much since I already did it once...
    Another question - does anyone else offer the same, or close to, size springs as Eibach's Pro Truck lift?
  27. Apr 17, 2021 at 8:32 AM
    #297
    CORunner
    CORunner New Member
    Some recent reports disclose the Eibach bushing on the mount is too small and although only a reported few millimeters many are recommending using washers to keep from bending the mount. It is reported that Eibach did not change the bushing of the FJ/4runner when the model changed in 2010. I have not seen a response from Eibach. Just FYI.
    koukimonster likes this.
  28. Apr 17, 2021 at 12:53 PM
    #298
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    BS - see my response to his thread on the other board.
    He needs to bolt that shit down. His video shows movement of the shock with only the lower bolt inserted not tightened down!!!
    Wow shit moves when it's not tightened down...
    Thatbassguy, nimby and Charlievee like this.
  29. Apr 17, 2021 at 12:59 PM
    #299
    Charlievee
    Charlievee Not new member.
    Waiting for a weekend that i have nothing going on to do the same. Definitely, when i get new rubber.
  30. Apr 17, 2021 at 1:03 PM
    #300
    Charlievee
    Fyi, that was not this kit. Would be interested in your first hand knowledge and not propaganda.
    Thatbassguy, DRobs and nimby like this.
