Drivers side lean - fix or ignore??
Discussion in '5th Gen 4Runners (2010-2024)' started by BobbyB, Feb 8, 2023.
  1. Mar 7, 2024 at 6:10 AM
    BobbyB
    BobbyB [OP] Where the road ends, Fun begins!
    Bob
    Marietta, GA
    2021 White TRD Off Road
    It’s only noticeable when my rig is parked on my level garage floor. I don’t notice when driving and have decided to ignore it.
    I did about 600 miles off-road on the Wyoming BDR last summer and the rig was awesome so no need to fix what’s not broke.
    I was able to get a spot on the Rocky Mountain Toyota Roundup in July and plan to drive the trails in the San Juan Mtns as it sits…
    Cheers,
    Bob
  2. Mar 7, 2024 at 6:35 AM
    Auntie Soshul
    Auntie Soshul New Member
    Butch
    2013 SR5 4Runner
    I’m with you. After buying my 2013 new, I started reading on forums about “leveling” and how much owners were paying to correct it. So I crawled under my vehicle with a torpedo level and checked on the frame and found it wasn’t out of level. Later, it dawned on me that folks were leveling for cosmetic reasons. They were raising the center of gravity, which makes the cornering and handling worse, and spending gobs of money to do it. My rig actually corners pretty well with stock suspension and a lower center of gravity, so I passed on any mods to the suspension.
  3. Mar 7, 2024 at 6:51 AM
    HazOpRed
    HazOpRed 22' TRDOR
    This^
  4. Jul 10, 2024 at 5:33 PM
    FourT6and2
    FourT6and2 New Member
    I probably have a higher attention to detail than the average driver. After lifting my 4Runner I now have some lean. I expected it, though. '21 TRD Pro and the stock Fox coilovers have two different spring perch heights for the driver vs passenger side to eliminate the lean from the factory. The difference is about 1/2". The lean absolutely bothers me. It's annoying and it causes the vehicle to pull to one side. In the USA, road crown exacerbates this issue. It does not counteract it as another poster stated. I don't like having to constantly fight the steering wheel while driving or the feeling of leaning to one side. I want a nice level vehicle that tracks straight. All I had to do was adjust the pre-load on the driver-side coilover to account for the lean and my weight. Easy to do.
    To really fix 100% of the lean, a rear driver-side spacer is also needed. But I only have 1/4" (6mm) of lean in the rear now and that's not too bad. Plus the smallest spacer available is 15mm (edit: 10mm).
  5. Jul 10, 2024 at 5:50 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    I used a .25" cornfed spacer on the front drivers side and 10mm OME spacer on the rear drivers side to get rid of the lean. Unless something changed, you can get a smaller spacer for the rear than 15mm.
    Note that I am on Bilstein 5100s with Bilstein 1" springs in the rear. My lift is almost exactly 2"/2".
  6. Jul 10, 2024 at 5:53 PM
    FourT6and2
    The smallest I've been able to find is 10mm. That was a typo on my part.
  7. Jul 10, 2024 at 5:56 PM
    TrueTexas
    The Woodlands, TX
    Right on. Note that it is a rubber /poly spacer and I got a little less than 10mm from it. More like 7-8. Might be worth it to try.
  8. Jul 10, 2024 at 6:38 PM
    FourT6and2
    That would be perfect because I only need about 6mm of lift in the rear.
  9. Jul 10, 2024 at 6:41 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I actually legit have a Passenger side lean lol
    after lift w/ kdss
    scottiezilla likes this.
  10. Jul 10, 2024 at 6:42 PM
    TrueTexas
    The Woodlands, TX
    I would definitely give it a shot. What's the worst that can happen? About $20 and a couple hours wrenching on the 4Runner
  11. Jul 10, 2024 at 6:43 PM
    TrueTexas
    The Woodlands, TX
    Every day I read something about KDSS making things difficult for the fine folks on here. Glad I didn't get it.
    mrmike7189 and djwantke[QUOTED] like this.
  12. Jul 10, 2024 at 6:55 PM
    You’re not wrong.
    It does just require correctional spacers and such.
    But yes there's a reason I publicly recommend SR5’s
    My interior is nice tho.
    mrmike7189 likes this.
  13. Jul 10, 2024 at 7:02 PM
    TrueTexas
    The Woodlands, TX
    Fortunately, we are able to get the TRD OR'S without KDSS here in the gulf states. Also love the interior in my ORP. Also love the shift lever vs switch. Some good nostalgia in that.
    I'm sure the SR5 would have met my needs just fine but I was lured in by the TRD badges and embroidered headrest :)
    fiddy5000 and Jedi5150 like this.
  14. Jul 11, 2024 at 5:19 AM
    Shanky
    Shanky New Member
    For those who cannot stand a vehicle that is not level, what do you do with different passenger counts and weights? Do you have assigned seating or pre-weighed counter balancing sand bags?
    BTW, pre-weighted sand bags are a way to level without raising the center of gravity.
    nimby and 2ndGen22re like this.
  15. Jul 11, 2024 at 8:34 AM
    FourT6and2
    I prefer to get the vehicle buttoned up as its baseline. If the thing is squatted in the rear and leaning to one side and has a bad alignment when it's literally just sitting there in the driveway, it's not right and it will only get worse when adding passengers and other items. If I'm temporarily hauling your mom around town, the added 5 inches of lean ain't gonna bother me.
  16. Jul 11, 2024 at 9:57 AM
    Every day I read about someone really enjoying the improved handling with KDSS. Glad I got it.
    TrueTexas[QUOTED] likes this.
  17. Jul 11, 2024 at 10:05 AM
    2016Pro
    Sell the truck and move on.
  18. Jul 11, 2024 at 10:12 AM
    San Angelo
    San Angelo New Member
    Ignore and find a new hobby to take up the large amount of unused time.
  19. Jul 11, 2024 at 10:53 AM
    #49
    TrueTexas
    The Woodlands, TX
    Fair enough. Wasn't trying to knock it. Just glad it wasn't something I had to contend with for my lift or some future expense to fix.
    Yet we both got rid of our TJs so that is something...
  20. Jul 11, 2024 at 11:17 AM
    #50
    Justkelvin
    Justkelvin New Member
    2023 TRD off road premium
    Or drop the passenger side
