Driver side A pillar grab handle.
Discussion in '5th Gen 4Runners (2010-2024)' started by Jimmycue, Sep 15, 2019.
  1. Jun 16, 2024 at 8:21 PM
    #241
    4R Florida
    4R Florida New Member
    Northeast Florida
    2024 4R Off Road
    There was a report recently of a KTJO badly warping. I'm in Florida so that is a major issue for me. Also, last time I checked all they had in stock was factory seconds sold as "damaged."
  2. Jun 16, 2024 at 8:28 PM
    #242
    backpacker
    backpacker New Member
    2023 TRD ORP
    Gotta drill. It's not difficult, but requires care.
    Mine has seen a whole bunch 90F+ days in the Southwest, Midwest and deep South. It sort of widened out in the center about 3/16", but you'd have to be looking for it to notice it.
    SLVRBULIT[QUOTED] likes this.
  3. Jun 16, 2024 at 9:01 PM
    #243
    I posted recently about the KTJO pillar trim developing an unsightly bulge along the windshield edge. It bothered me enough that I went back to the oem trim cover with the Toyota grab handle, and haven't looked back. It still works great as a grab handle. You have to look very close to notice the difference from the passenger side.
    I tried heating up KTJO pillar trim cover to reshape it, and it looked better. I may try it one more time.
    djwantke likes this.
  4. Jun 16, 2024 at 9:28 PM
    #244
    java
    java fauxrunner
    2023 ORP ice cap
    maybe a dumb question, are there right hand drive versions of 4R? Can we use the trim piece and handle from them?
  5. Jun 16, 2024 at 9:41 PM
    #245
    It doesn't appear they sell 4Runners in Great Britain, so maybe not.
  6. Jun 16, 2024 at 10:10 PM
    #246
    4R Florida
    Northeast Florida
    2024 4R Off Road
  7. Jun 17, 2024 at 6:27 AM
    #247
    The question now is, does Toyota manufacture a right-hand drive 4Runner? They may only offer other models, i.e. the Hilux instead of Tacoma, outside the US.
  8. Jun 17, 2024 at 7:02 AM
    #248
    SLVRBULIT
    SLVRBULIT New Member
    2023 SR5
    Are you using Jason’s bracket? Did you modify the oem trim cover or purchase an oem trim cover with the grab handle holes? Or does Toyota not sell them?
    Sorry for all the questions
  9. Jun 17, 2024 at 7:30 AM
    #249
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    Same for me! I was using the steering wheel but felt it might damage the wheel eventually. Ours took about 2 hours to install but my buddy and I actually READ the instructions, Did need 2 holes drilled (I think) but it looks good. I'm currently 300lbs and have a really bad right knee (2x broken kneecap, 1x broken ankle, & arthritis)
  10. Jun 17, 2024 at 9:31 AM
    #250
    I don't mind any questions :) I did the original modification that this thread is about - Jason's bracket, installed, and a hole drilled in the oem A-pillar trim cover, and purchased an oem Toyota grab handle, ran that for quite a while. Some months later, I decided to get the KTJO grab handle setup (when they were still selling them) and was able to make it work with Jason's bracket, as that is a much sturdier mounting method for the bottom bolt. It worked fine, and looked exactly like the passenger side grab handle.
    Fast forward to the recently discovered bulge in the KTJO A-pillar trim cover, which led me to go back to the modified oem A-pillar trim cover with the oem grab handle. If I can somehow get the bulge out of the KTJO trim cover, I will consider putting it back on.
  11. Jun 17, 2024 at 10:24 AM
    #251
    SLVRBULIT
    2023 SR5
    I appreciate the feedback. I think I’ll continue to scratch my head while I decide what I want to do. Thanks again
  12. Jun 17, 2024 at 10:32 AM
    #252
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Great info and details here. Thanks
    I can’t remember now, I just tried researching; can you buy an oem left drivers A pillar with the same raised contours at the the bolt holes that the right passenger pillar has for handle finger clearance?
  13. Jun 17, 2024 at 10:58 AM
    #253
    Seeing as how the DS handle was eliminated on the 5th gen 4R in the US, no. That is why the KTJO was so popular, it matched the PS look.
    People are wondering if there is an international 4R version with right hand drive that may have the passenger left side with a grab handle. Unless Toyota offers the same model 4R internationally with the driver side on the right, my vote is no.
    djwantke[QUOTED] likes this.
  14. Jun 17, 2024 at 6:00 PM
    #254
    4R Florida
    Northeast Florida
    2024 4R Off Road
    You didn't have to reposition the bracket at all?
    After numerous attempts to contact KTJO customer service a few months ago by phone and email, I finally got a one word email answer to when/if they might restock with new kits. It said "Summer."
  15. Jun 17, 2024 at 6:39 PM
    #255
    4R Florida
    Northeast Florida
    2024 4R Off Road
    I don't always trust Wikipedia but this appears correct.
    "As of 2021, the 4Runner is marketed in the Bahamas, Bolivia, Canada, Chile, Colombia, Costa Rica, El Salvador, Guatemala, Panama, Peru, the United States and Venezuela."
    The only one on the list needing RHD would be the Bahamas, a tiny market compared to others. 4R seems to have been sold as "Hilux Surf" with a RHD version until 2005 but that disappeared. The Lexus GX didn't overlook the driver side grab handle. Sigh.
  16. Jun 17, 2024 at 7:22 PM
    #256
    I had to adjust the brackets' hole slightly to line up the bolt in the KTJO handle. If I had installed them at the same time, it would have been easy to line up the bracket then.
  17. Jul 14, 2024 at 8:48 AM
    #257
    AsianAnts
    AsianAnts New Member
    '18 TRD Offroad Prem. BLK
    Too many to list.
    Been considering this mod and really like the simplicity of KTJO but their quality seems to be less desirable..
    I had their LED door handle product and it changes brightness and/or color everytime fire up the 4runner. Even more annoying is that no matter where in the vehicle I use the remote, there's always one LED that doesn't register. Hence making one dimmer/brighter than the others and none is really the same
  18. Jul 14, 2024 at 11:47 AM
    #258
    It appears KTJO has them back in stock. Some have been happy with their kit, others, like me, have done a hybrid install with Jason's bracket. Had the KTJO A-pillar plastic trim not deformed a bit on one edge, I'd still be running it.
  19. Sep 15, 2024 at 1:39 PM
    #259
    Steve Berman
    Steve Berman New Member
    how do I order this thing? the site doesn't have a buy button or a message saying out of stock....
  20. Sep 15, 2024 at 7:21 PM
    #260
    They must be out of stock again. Boat from China delayed. Their website has pretty much been hard to navigate, and their customer service has been spotty at best.
  21. Sep 15, 2024 at 7:33 PM
    #261
    Steve Berman
    Anyone else report the warping issues you experienced? The header of their site says 2024 version coming soon or something. Is that a new revision? Wild to see you go through all the ups and downs of this mod. What are you currently using?
  22. Sep 15, 2024 at 9:42 PM
    #262
    I went back to the oem grab handle and the mounting bracket shown in the install linked in post #2, and also described by @Daytonaviolet in post #9 of this thread. Solid, works great.
  23. Dec 27, 2024 at 5:19 PM
    #263
    java
    java fauxrunner
    2023 ORP ice cap
