Driver side A pillar grab handle.
Discussion in '5th Gen 4Runners (2010-2024)' started by Jimmycue, Sep 15, 2019.
  1. Nov 5, 2022 at 1:24 PM
    #121
    bulldog
    bulldog New Member
    Prepping to buy New
    I got Jason's bracket today and used the KTJO pillar & parts and they went together awesome!!!! Man it's a solid, sweet setup for sure.
  2. Nov 20, 2022 at 7:27 AM
    #122
    Any photos of the finished installation? I'm revisiting ordering the KTJO set, just for the pillar cover...
  3. Nov 21, 2022 at 1:06 PM
    #123
    I am getting ready to place an order for the KTJO kit, in order to have the A pillar trim look like the passenger side. These are photos of the finished product by @Brandonium on the other 4R site:
    There's somewhat of a gap in places at the top. I don't think @Brandonium has been on this or the other site since August to clarify if he did anything about the gap...
    If the pillar trim I receive looks anything similar to that, I will take you up on your suggestion of inserting some foam behind the headliner edge, and see if that takes care of the issue.
    What the heck...
  4. Dec 10, 2022 at 4:04 PM
    #124
    Well, I gambled and lost. The KTJO trim piece did not work with Jason's bracket in my case. Where I had mounted the bracket, the threaded clip did not line up with the bottom hole location in the KTJO trim/handle. I tried my best to get it to work, but it was off just enough to not work. The only way I can see it working with the bracket is to remove the bracket and flip it 180 degrees, as the hole in the bracket is offset to one side, and would probably line up if I flipped it. I don't particularly want to remove and remount the bracket, though...maybe if I used the next larger size screw, or put in a couple of nutserts to mount the bracket with.
  5. Dec 10, 2022 at 5:29 PM
    #125
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Try to install with the supplied rivnut and gun that the kit came with. If it looks suspect or doesn't work out put the original trim back on and say f it. How did the trim piece look? Any issues?
  6. Dec 10, 2022 at 6:38 PM
    #126
    bulldog
    bulldog New Member
    Prepping to buy New
    Do you have a pic? Mine worked perfect.
  7. Dec 10, 2022 at 8:19 PM
    #127
    Can't do that - I already have Jason's bracket mounted. That was the reason I got the KTJO kit, to see if the trim piece and handle would work with the bracket. I'm not a fan of that rivnut attachment method.
  8. Dec 10, 2022 at 8:31 PM
    #128
    If I had mounted Jason's bracket with the KTJO trim piece on hand, I could have lined up the holes to match. I mounted it to work with the oem handle. The bottom hole is about 1/4" too high for the bottom KTJO handle bolt. There's some wiggle room with the threaded clip, but not enough to line up with the bolt. As stated, if I flip the bracket end for end, the offset hole in the bracket will be lower, and would probably then work.
    I took plenty of before photos, but when I couldn't get the bolt to thread in, I put everything back the way it was with the oem handle and trim piece, and didn't take any more photos...
    The KTJO trim piece and handle look just like the factory pieces, both in texture and color.
    For a visual of what I mean, I borrowed a photo of Jason's bracket from @Saker's T4R.org thread when he introduced a lot of people to this mod. The area circled in yellow is what lined up with the KTJO bottom handle mounting hole. As you can see, there's just not enough room to move that threaded clip and still have a place for the bolt to go through. Another thought is, I could drill the bracket right there instead of flipping it.
    My bracket:
  9. Dec 10, 2022 at 8:42 PM
    #129
    @Saker, would you know if Jason's bracket could be rotated 180 degrees?
  10. Dec 11, 2022 at 11:09 AM
    #130
    bulldog
    bulldog New Member
    Prepping to buy New
    I sure don't......why not just move it down some or drill the bracket a bit? I think either would work.
  11. Dec 11, 2022 at 11:11 AM
    #131
    bulldog
    bulldog New Member
    Prepping to buy New
    Ya, try flipping it first though, give that a shot. Just use the same screws to check it and if it works good leave it or upsize them. I see what you mean now :)
  12. Dec 11, 2022 at 12:49 PM
    #132
    Saker New Member
    21 Black T4RORP
    Are you referring to the whole bracket or just the nut clip you have circled?
  13. Dec 11, 2022 at 1:07 PM
    #133
    The whole bracket. It seems if the offset hole was on the other side, the KTJO handle would line up better. Moving the nut clip doesn't help, as the bolt is lower than the hole in the bracket.
  14. Dec 11, 2022 at 1:33 PM
    #134
    Saker New Member
    21 Black T4RORP
    You can't flip the whole bracket because the mounting plate is angled for the "A" Pillar.
  15. Dec 11, 2022 at 1:35 PM
    #135
    I appreciate it, thanks. I thought that may have been the case, but couldn't remember.
    I had actually already decided to stick with the oem handle - it's really solid, and I really don't feel like modifying the bracket to accept the lower bolt placement, possibly weakening it.
    The KTJO kit is going up for sale. My loss, someone else's gain.
    Saker[QUOTED] likes this.
  16. Dec 11, 2022 at 4:19 PM
    #136
    bulldog
    bulldog New Member
    Prepping to buy New
    Are you going to use the bracket on the OEM setup?
  17. Dec 11, 2022 at 4:42 PM
    #137
    Yes. I already had the OEM grab handle installed, then decided to see if the KTJO trim & handle would work. Since it didn’t, I put the OEM setup back on.
  18. Dec 11, 2022 at 6:51 PM
    #138
    Sorry it didn’t work out for you.
  19. Dec 11, 2022 at 7:03 PM
    #139
    Thank you. Sort of disappointed; I had high hopes, but knew it was a gamble. Word to the wise - if you go this route, install Justin's bracket at the same time as the KTJO kit to ensure alignment of the bolt holes.
    The consolation is the bracket & OEM handle are as good as advertised, and a perfectly acceptable setup.
  20. Dec 18, 2022 at 2:00 PM
    #140
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    @glwood54 Is the OEM handle and the KTJO handle different sizes? Mind posting a side by side pic of each? Thanks!
  21. Dec 18, 2022 at 9:28 PM
    #141
  22. Dec 22, 2022 at 6:54 AM
    #142
    No luck on the for sale thread. I will revisit this project when the weather warms up.
  23. Dec 27, 2022 at 11:48 PM
    #143
    Emmantik
    Emmantik New Member
    FYI KTJO4X4 is having a sale on the A pillar grab handles. 41% off at the moment!
  24. Dec 28, 2022 at 6:27 AM
    #144
    Clearance items due to cosmetic 'imperfections'. The standard set is still the same price - $170 + shipping.
  25. Jan 5, 2023 at 8:37 AM
    #145
    Emmantik
    Emmantik New Member
    Just received these and I can't seem to find any defects - not even a scratch. Will see how things go once I install but so far the quality seems pretty good! pics for reference;
    20230104_163315_resized.jpg 20230104_163337_resized.jpg 20230104_163337_resized.jpg 20230104_163315_resized.jpg 20230104_163351_resized.jpg 20230104_163357_resized.jpg
    PJSnow likes this.
  26. Jan 28, 2023 at 6:50 PM
    #146
    TonyBess
    TonyBess New Member
    Tony
    2020 Black 4 Runner SR5
    Install of KTJO Driver Side Grab Handle on 5th Generation 4Runner 2020 Year. Modified kit by using M6 metric rivet nut and bolt instead of what was supplied. Great fitment no problem at all and kit arrived on time and without issue.
    https://youtu.be/zkaq9e-iSXI
  27. Jan 28, 2023 at 8:14 PM
    #147
    Nice job. I like your attachment method much better than that small rivet nut and bolt they provide. Good thinking.
    I got the KTJO kit a while back, hoping it would work with Jason's bracket, but the bracket hole was just enough off that I couldn't get it to work. I put the kit up for sale after that, but haven't had any interest. So I think I'll revisit this when the weather warms up, by modifying the bracket to work with the KTJO handle spacing. If you look at the photo of the mounted bracket in post 128, the hole is offset to the top end of the bracket. I plan to make the bottom of the hole about 1/4" lower so that nut clip will slide a bit lower.
    The bracket is a great mounting method, so I hope I can make it work. Wish me luck!
  28. Jan 28, 2023 at 8:35 PM
    #148
    TonyBess
    TonyBess New Member
    Tony
    Good Luck glwood54 I hope it does work for you as I really use that side handle.
  29. Jan 28, 2023 at 8:54 PM
    #149
    I recommend the combination of the A-pillar grab handle and replacing the flip-down grab handle over the door with an FJ Cruiser grab handle. I use the FJ handle to pull me up and the KYJO handle to set back into the seat. Almost painless! :)
    Frizzle77, glwood54 and TonyBess like this.
  30. Jan 29, 2023 at 1:34 PM
    #150
    bulldog
    bulldog New Member
    Prepping to buy New
    Pics?
