Door Edge Guards
Discussion in '5th Gen 4Runners (2010-2024)' started by KYMason, Mar 21, 2023.
  1. Jun 25, 2024 at 10:00 AM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    I have them on the front doors of my 2020 MGM. I wish they were on the back door as well as they blend in way better than the black ones with goop inside.
  2. Jun 25, 2024 at 10:06 AM
    Startrek
    Startrek New Member
    I am not sure what those edge guard guarding?
  3. Jun 25, 2024 at 10:12 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    You'll find out if have a door without them that bumps anything. Paint will chip off the edge at the point of contact.
    Technologic80 likes this.
  4. Jun 25, 2024 at 10:26 AM
    EC15
    EC15 ...
    Then there will be a chip on the edge guard and still a high possibility of damage to the door because the edge guard digs into the paint.
    I would use a strip of ppf instead.
    4runningMan likes this.
  5. Jun 25, 2024 at 10:28 AM
    backpacker
    2023 TRD ORP
    The edge guard is rubbery on the outside. It's a lot more forgiving than a bare edge.
  6. Jun 25, 2024 at 10:34 AM
    EC15
    EC15 ...
    I thought we were taking about the OEM painted metal ones.
  7. Jun 25, 2024 at 10:40 AM
    backpacker
    2023 TRD ORP
    I have the OEM ones. The paint on them is thicker and more elastic than the door edges.
  8. Jun 25, 2024 at 11:06 AM
    EC15
    EC15 ...
    I have a set for a rav4 in my office.
    Owner saw the damage it left on his door when we took off the old set.
    That's probably why it's still in my office. :D
  9. Jun 25, 2024 at 11:09 AM
    backpacker
    2023 TRD ORP
    Ouch!
  10. Jun 25, 2024 at 4:50 PM
    Startrek
    Startrek New Member
    My point exactly: the door does not opens by themselves, it is you, the driver, who opens a door and slams it into the next parked car, mine. It is me, who needs protection from your edge "guard".
  11. Jun 25, 2024 at 6:34 PM
    Damn, settle down Francis, maybe he has a one car garage that is so fucking small he has to fold his mirror in to make it fit.
  12. Jun 25, 2024 at 6:57 PM
    backpacker
    2023 TRD ORP
    It's pretty close to that. The driver's door is the only one I can fully open in the garage, but that's only if I pull so far forward that I can't open the hood. I have to slither out if I leave room for that thanks to the forward pole.
  13. Jun 26, 2024 at 11:07 AM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    spotted this MGM 4Runner in the parking lot...
    door edge guards could have prevented this
  14. Jun 26, 2024 at 11:15 AM
    Per Toyota, these are thermo-plastic coated stainless steel. I imagine the thermo-plastic coating would be similar to what the bumpers are made of. I'll find out when my order arrives today.
    backpacker[QUOTED] likes this.
  15. Jun 26, 2024 at 11:25 AM
    T in Texas
    FEMA Region 6
    thats what they feel like...
    plastic wrapped around metal...
    I left mine in the sun for an hour or so, they got easier to bend...
    mine did not come with instructions, but said to check TIS for the instructions...
    the driver and passenger come individually wrapped and marked and are slightly curved to fit the door
    you gotta make sure the one you are installing is not upside down, just notice the curve of the door vs the curve of the edge guard
    I used alcohol and a shop towel to wipe down the edge of the door (front and back) before install
    I started at the bottom and started the edge guard on the door, and while holding it in place, began tapping with a rubber mallet working up the door
    when finished, went back over it with the rubber hammer from bottom to top and back again
    ETA: I wiped down the 4runner door edge with alcohol prior to install , not the edge guard
    backpacker likes this.
  16. Jun 26, 2024 at 11:30 AM
    Thank you!
  17. Jun 26, 2024 at 12:15 PM
    Startrek
    Startrek New Member
    hung soft padding on the wall.
    or use rear window
  18. Jun 26, 2024 at 12:26 PM
    backpacker
    2023 TRD ORP
    I have padding on the poles, but not on the wall side, since it has tools on it. I also have padding on the inside of the garage door so I can open the liftgate safely. In 48 years of driving, I've never dinged anyone's doors and I'm not removing my factory edge guards.
    glwood54 and Technologic80 like this.
  19. Jun 29, 2024 at 4:03 PM
    #49
    Getting ready to install these. Question - how do you know the starting point?
  20. Jun 29, 2024 at 4:43 PM
    #50
    T in Texas
    FEMA Region 6
    Look back at post #21...
    Notice how the edge guard goes to about 1/2 inch above the lower door crease and extends above the door handle cup?
    I used that pic as a guide, then lined up the guard, without trying to fit it...
    you can tell which is the top and the bottom of the guard cause of the curve, just make sure the curve follows the door...
    after I had the guard lined up like I wanted, I began gently placing at the bottom...just using my hands to push it in place
    you can get a couple of inches at a time this way
    then, starting at the very bottom...use your rubber mallet to tap it in place
    then move upward using the hands only method to seat it...followed up with the mallet
    after you have the whole guard in place, go back of the whole thing...tapping with your hammer to make sure its seated
    something I thought of after I installed them...
    I wonder if one could buy another set and cut them in a few places...then using the cut pieces install them on key points of the rear doors and bottom edge of the front doors.
    basically sacrifice another set to get increased coverage not provided by the two front guards...
    what do you think? would that work?
  21. Jun 29, 2024 at 4:53 PM
    #51
    I did see post 21, but thought I would check with you since you seemed happy with the install. I did go on a walk a bit ago, and saw a new model lunar rock 4Runner that had the oem door edge guards installed and was able to check those out. I believe those were about 3/4" from the crease at the top, and a tad more, maybe 7/8" on the bottom, so I don't imagine it's super critical, as long as they are within that range.
    I did find a YT video, but the guy's hard to watch. I don't know why people make videos that talk about everything else but what the video's supposed to be about...plus, the door edge guards don't even come out of the box until about the 4:00 minute mark.
    https://www.youtube.com/watch?v=FpomH_G_4XI
    BTW, he thinks he got shorted the 'rear guards' but doesn't realize they don't offer those...
    Personally, I don't see needing to add separate pieces, but no reason not to if you want. I pretty much only use the front doors most of the time, and these seem to work for that.
    Thanks again.
  22. Jun 29, 2024 at 5:02 PM
    #52
    T in Texas
    FEMA Region 6
    I like that guy's truck, but that video is useless...
    he spends about as much time talking about his oil cap...as door guards
    I thought Viking's garage was bad, but that guy is worse
    But if he found those rear guards, I'd be interested
  23. Jun 29, 2024 at 9:13 PM
    #53
    We got the rainstorm of the century this afternoon/evening so the installation got put back.
  24. Jun 29, 2024 at 9:23 PM
    #54
    T in Texas
    FEMA Region 6
    lucky you...
    prolly never rain again here in DFW
  25. Jun 30, 2024 at 3:18 PM
    #55
    With your help, it turned into a 10 minute job. Thanks!
