Dog Humor
Discussion in 'General 4Runner Talk' started by BearBio, Oct 10, 2023.
  1. May 16, 2024 at 4:31 PM
    GtownRunner
    GtownRunner New Member
    2022 Black TRD Pro
    None Yet
    Islay watching the neighbours barbecuing looking for the rent cheque! Lol thinks she owns everything!
    Thacrow, icebear, brownersd and 2 others like this.
  2. May 16, 2024 at 4:59 PM
  3. May 16, 2024 at 5:17 PM
    erfer1
    erfer1 New Member
    Eric
    SW NM
    2019 Limited
    brownersd likes this.
  4. May 16, 2024 at 5:27 PM
    rottielvr
    rottielvr New Member
  5. May 26, 2024 at 3:36 PM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
  6. May 27, 2024 at 4:27 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    That’s hilarious. I’ve already sent it out to a few dog loving friends.
    jeepster09[QUOTED] likes this.
  7. May 27, 2024 at 5:02 AM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
  8. May 27, 2024 at 5:03 AM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
  9. Dec 17, 2024 at 6:06 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  10. Dec 25, 2024 at 4:26 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    IMG_3109.jpg Honey, have you seen my boots?
    brownersd, HuskyMike and AuSeeker like this.
  11. Dec 26, 2024 at 10:02 AM
    Start them young!!
  12. Dec 26, 2024 at 11:29 AM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
  13. Dec 26, 2024 at 12:51 PM
    jwctaco
    S.W. Michigan
    23’ T4R
  14. Mar 18, 2025 at 8:16 PM
    stay still!
  15. Mar 25, 2025 at 4:46 PM
    Chillin’
    Trail Runnah, brownersd and Bagman like this.
  16. Mar 25, 2025 at 9:41 PM
    HuskyMike
    HuskyMike New Member
    Max's "grinch hair" after just waking up from a nap.
  17. Mar 26, 2025 at 12:34 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    brownersd and HuskyMike like this.
  18. Mar 31, 2025 at 12:20 PM
  19. Mar 31, 2025 at 12:27 PM
    #49
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I get this vibe...or a snowboard.
    Edit: Either way Max likes to shred the gnar
  20. Mar 31, 2025 at 9:43 PM
    #50
    brownersd
    Sean
    Humble / Kingwood, Texas
    Where's my food, B?
  21. Mar 31, 2025 at 9:45 PM
    #51
    brownersd
    Sean
    Go on...
    HuskyMike and Thacrow like this.
  22. Apr 1, 2025 at 11:27 AM
    #52
    FatChance
    Sedona
    2024 4Runner Limited
  23. Apr 6, 2025 at 6:05 AM
    #53
    Fishbum
    Fishbum New Member
  24. Apr 6, 2025 at 6:05 AM
    #54
    Fishbum
    Fishbum New Member
    I have no idea why this is comfortable
  25. Apr 6, 2025 at 6:20 AM
    #55
    Banshee
    Banshee New Member
    Sara
    Western PA
    '22 AG Trail Special Edition
