Does the 2023 Off Road Premium not come with auto headlights?
Discussion in '5th Gen 4Runners (2010-2024)' started by walkerap, Jul 26, 2023.
  1. Jul 26, 2023 at 10:03 AM
    broken-giver
    broken-giver BFD
    Please! premium hard plastic all around. Premium hot leatherette seats. Premium all 4 auto windows and rear window!? You really are asking too much if you want more.
  2. Jul 26, 2023 at 10:04 AM
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    What test drive? My dealer didn't have any unsold units on the lot. All I knew going into it, was it would drive like a brick on wheels.
    5six and broken-giver like this.
  3. Jul 26, 2023 at 10:11 AM
    So you signed on the dotted line then drove away in your brick on wheels with no test drive once it arrived?
  4. Jul 26, 2023 at 10:11 AM
    ReRunner
    ReRunner Fred Berry Enthusiast
    2022 MGM ORP
    My ORP has Part-Time AWD, whatever MPG, and way too much premium shit in it. I'd pay more if I could get less of this digital cheapness. Auto headlights? I have those. Its called muscle memory. I don't even think about turning on my lights. My left hand just reaches up and twists. No thought required.
    A key, A KEY, my kingdom for a key!
    MeefZah and djb1 like this.
  5. Jul 26, 2023 at 10:13 AM
    And now, apparently, for TRD wheel center caps...the hoarders on Ebay are ca$hing in.
  6. Jul 26, 2023 at 10:16 AM
    ReRunner
    2022 MGM ORP
    Yup, I need one for the spare replacement I just bought. No big deal to pop one from the others should the need arise though.
  7. Jul 26, 2023 at 10:18 AM
    broken-giver
    broken-giver BFD
    lol.
  8. Jul 26, 2023 at 10:29 AM
    This is the downside of having a dash that is always lit. I forget to turn mine on all the time. Someone pulled up next to me on the freeway last Thursday to tell me to turn them on. o_O
  9. Jul 26, 2023 at 10:30 AM
    Hmmm. Which is more likely?
    • Toyota’s owner’s manual is wrong, and no trim level of 4Runner has full-time 4WD. Or …
    • There’s some codicil in the EPA regulations to explain the logical discrepancy. Perhaps the EPA only requires testing of one trim level per engine. Or maybe the EPA requires an averaging of the mpg across all trim levels. Who knows?
    Think what you want.
  10. Jul 26, 2023 at 10:32 AM
    Stitches1974
    Yep. Did the same with my 2015 JKU.
  11. Jul 26, 2023 at 10:33 AM
    Thepremier141
    Thepremier141 Member
    Nate
    Northern California
    ‘22 SR5P
    I'm sure in the hundreds of MPG threads, surely some limited owner would have spoken up by now....
  12. Jul 26, 2023 at 10:34 AM
    Airdam, skirts, and P-metric street tires :gossip:
    Realistically the EPA fuel economy rating is its own boondoggle with dyno test results adjusted by a multitude of fudge factors.
  13. Jul 26, 2023 at 10:35 AM
    I have to say, I did the same when I got my new 2013 Tacoma. Made the deal by email, went down, signed the paperwork, then drove away. I did have 2 2nd gen Tacomas previously, though, and knew what I was getting.
    I had to test drive the 4R, just to see how much different it was from the Tacoma. I was sold on the first drive.
  14. Jul 26, 2023 at 10:37 AM
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Actually the Toyota Full Time 4WD is quite different than Toyota AWD. As you mention it has a Torsen center differential that can be locked so that equal power is going to both the front and rear wheels. However, when not locked, the center differential will only allow a 60/40 split between power front to back - so even if the center diff senses torque reduction there will always be at least 40% power going to the front or rear wheels. Toyota AWD is typically 100% front wheel drive until slippage is sensed and power is sent to the rear wheels. Also, as you mention, the Full Time 4WD system has a dual range gear box - which typical AWD does not.
    Well, the 4Runners less than stellar gas mileage is way more due to weight and aerodynamic drag than it is to driveline inefficiencies within the 4WD system. Also, when in High 4 Free (H4F) - the normal driving condition in the Full Time 4WD Limiteds - the center diff is open/free so that power can be adjusted somewhat between the front/rear wheels. When the part time 4WD systems are in 4HI - there is no center diff - and equal power is being sent to the front/rear wheels. I'm guessing that when the Full Time 4WD system is put into H4L it is very much like the part time 4WD system in 4HI and would get similar gas mileage. Also, the Limited has a different front bumper than some of the other trims - and it has an air deflector under the front bumper than decreases the amount of air that gets under the vehicle. This decreases the aerodynamic drag when the vehicle is moving. I'm thinking this also helps the full time 4WD Limited get the same gas mileage in H4F than the part time 4WD vehicles get in 2WD.
    erfer1 and Thepremier141 like this.
  15. Jul 26, 2023 at 10:40 AM
    I know that but people are already confused about lights so I chose a much simply explanation of the system.
  16. Jul 26, 2023 at 10:41 AM
    Stitches1974
    Since I knew what I was getting into with the JKU. I had no expectations of a car like ride or anything similar, with the 4R. I just made sure there were no interior/exterior defects. The 4R has a bit more body roll than the JKU, but I'm already used to it.
    I love it so far!
  17. Jul 26, 2023 at 10:46 AM
    broken-giver
    broken-giver BFD
    you mad bro? ;)
    I am just pointing out discrepancy. Usually in real world, you have to pay to get something more in return. Otherwise, why stop with 4WD then, lets have the "super limited full time6WD" trim, and still have MPG at same numbers.
    Maybe they have thrown away lots of stuff to make up for lost MPG due to limited's "full time 4WD" or maybe...just maybe...toyota likes to call its AWD in 4Runner as "full time 4WD".
  18. Jul 26, 2023 at 10:52 AM
    Haha. When you figure out how to put a Limited into 2WD mode you let me know.
    EC15 likes this.
  19. Jul 26, 2023 at 10:53 AM
    #49
    backpacker
    backpacker New Member
    2023 TRD ORP
    I agree that the lack of auto headlights is a tad disappointing. My last vehicle without auto headlights was a '76 Nova. However, that was also the last vehicle I had until now with a full-sized spare tire.
  20. Jul 26, 2023 at 10:54 AM
    #50
    broken-giver
    broken-giver BFD
    You made a valid point. I did not know, so I looked and it seems limited is heavier than ORP.
    So its a heavier vehicle, gives full time 4WD and gives you same mileage as ORP, or any other trim.
    What gives? Does limited have a small battery pack I don't know about?
    I don't know why limited crowd gets riled up when I ask this question. I simply don't understand how toyota can give more (full time 4WD, with more weight) with same fuel consumed. This to me reads like marketing gimmick to sell more Limited.
  21. Jul 26, 2023 at 10:56 AM
    #51
    backpacker
    2023 TRD ORP
    Are the 20" rims part of the explanation? (i.e. some reduction in unsprung weight).
  22. Jul 26, 2023 at 11:28 AM
    #52
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    TLCA #25089
    Premium off road capability and premium longevity and premium resale and making Prius owners feel like premium bitches.
    erfer1, ReRunner and Thatbassguy like this.
  23. Jul 26, 2023 at 11:29 AM
    #53
    shooter1231
    I don't think the weights are that much different - so I don't think that has a significant impact. I think it is a combination of things that allows the Limited with full time 4WD to get the same mileage as the other trims with part time 4WD. Like I said in an earlier post - the 4Runner's generally shitty gas mileage is mostly due to the weight of the vehicle, its aerodynamics, and its 5 speed tranny (when compared to other similarly sizes vehicles that have 8-10 speed trannies). I don't think there is more than a few % difference in vehicle weight between the different 4Runner trims - so I don't think the small weight difference between a ORP and a Limited has much to do with differences in gas mileage. I think you can drive around in H4F in a FT 4WD Limited and get very close to the same mileage as driving around in 2WD in any of the other trims. I think there are multiple reasons that combine for this - weight and aerodynamics just have a lot more to do with 4Runner gas mileage than mechanical inefficiencies in the 4WD systems - and there are some differences in the Limited that help make up for the FT 4WD with respect to gas mileage. The front bumper of the Limited is lower to the ground and it has an additional air deflector below the bumper that helps reduce the amount of airflow beneath the vehicle - this reduces drag and improves gas mileage. The Limited has 20" wheels with lower profile street centric tires. The lower profile tires have stiffer sidewalls and the tire treads are designed more for road than off-road - so they have a little less rolling resistance. Things like this make up for the slight mechanical inefficiencies in the 4WD system that cost some gas mileage compared to 2WD. I can say this through personal experience though - I don't think the published gas mileage figures are a marketing gimmick. I think all the 4Runner trims have the same mileage estimates (16 city, 19 hwy). I can say that my 2023 Limited exceeds those numbers. When I drive around town (not block by block city driving) stopping at stop lights, slowing/stopping to make turns, etc... I routinely get 17.5-18mpg. When cruising on the highway on longer trips at 75-80mph I usually get 20.5-21.5mpg (closer to 21.5 if I keep the cruise control set close to 75mph.
  24. Jul 26, 2023 at 11:39 AM
    #54
    you arent missing anything with auto- high beam. On the highway it is so annoying. on/off/on/off/on/off.
  25. Jul 26, 2023 at 11:41 AM
    #55
    I'd say anything straight axle would do better on rocks and even the Bronco has a little more capability than the Runner.
    If the frame doesn't rust.
    I don't buy thinking about selling.
  26. Jul 26, 2023 at 11:41 AM
    #56
    ReRunner
    2022 MGM ORP
    It doesn't seem likely that every variation of trim would be tested for MPG.
    Captain Spalding likes this.
  27. Jul 26, 2023 at 11:42 AM
    #57
    Thepremier141
    Nate
    Northern California
    ‘22 SR5P
    @kmeeg Has both trims, maybe he can tell us if the mpg is a lie
  28. Jul 26, 2023 at 11:44 AM
    #58
    MeefZah
    Lexington, Ohio
    GX460
    TLCA #25089
    Well maybe you should be if you gonna cry about straight axles and frame rust!!!!
    Thatbassguy and Thepremier141 like this.
  29. Jul 26, 2023 at 11:47 AM
    #59
    ReRunner
    2022 MGM ORP
    @walkerap Thank you for starting this fantastic shit posting thread. Some peoples first posts are clearly better than others. Welcome to the site bro.
  30. Jul 26, 2023 at 11:51 AM
    #60
    Then buy nothing because no vehicle the general public can afford will appreciate in value. I bought what I wanted and drive/mod it as I want without thinking about the next owner.
