Does a body mount chop damage or make your 4Runner weaker?
Discussion in 'General 4Runner Talk' started by Longralph2, Sep 8, 2023.
  1. Mar 25, 2024 at 9:56 PM
    #61
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Nah you can still get em off. It's not that bad.
  2. Mar 25, 2024 at 10:11 PM
    #62
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Is that right, good to hear
  3. Mar 25, 2024 at 10:32 PM
    #63
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    If you need a blow torch to get them off you would just break the stud anyway.
    It will be a pain to get the off as they will take more force for a lot of turns. But just clean the threads up after.
  4. Mar 26, 2024 at 11:51 AM
    #64
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    @djwantke IME red loctite is not as permanent as most claim it to be. But a little heat does go a long way. Even just a heat gun helps quite a bit.
    Back to the BMC I do believe that it does make the body mount a little weaker. But not enough to worry about.
    At the end of the day almost all modifications we do for improvements off road could be viewed as making the truck weaker in some sense. Or at least exposing weaknesses. Big tires? more likely to break CVs. Steel bumper and winch? More likely to cause frame damage in a simple fender bender. More weight? More stress on all components causing additional wear. Hell I did spindle gussets and was then told the heat from welding the spindles could make them weak and more prone to failure. Which if true, would negate the whole reason for spindle gussets.
    Don't overanalyze it too much. Everything is a compromise to some degree. Life is too short to worry about these things.
    I doubt very seriously a 4Runners cabin will detach from the frame because of a simple body mount trim and weld job.
    :notsure:
  5. Mar 27, 2024 at 5:10 PM
    #65
    Thanks for this knowledge dude
    Good to know this as well.
    1. It's still true that I don't have the heart to uninstall (and then do what with) the spidertrax I paid a premium for to receive all the way up in Canada.
    2 . Putting a heat gun near these gorgeous black aluminum spacers makes me anxious ;)
    When I get new tires
    295/70, 285/75, 255/85
    in x amount of years, I will play another game of "Name that rubbing noise!"
  6. Mar 27, 2024 at 5:15 PM
    #66
    Me, after I installed the spacers and my wife said what the hell is that noise when I turn!?
  7. Mar 27, 2024 at 6:42 PM
    #67
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    If you out 295's with those spacers you're guna need to do a lot of cutting to make it fit.
    djwantke[QUOTED] and Thatbassguy like this.
  8. Mar 27, 2024 at 8:03 PM
    #68
    Already have cut
  9. Mar 27, 2024 at 10:43 PM
    #69
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    oh my bad yeah you got a viper cut. Yeah with the wheels pushed forward.....might not have to BMC
    djwantke[QUOTED] likes this.
  10. Mar 28, 2024 at 11:47 AM
    #70
    I'm a few steps ahead of that even
    :quickdraw:
    Old Tanker and Thacrow[QUOTED] like this.
  11. Mar 28, 2024 at 11:58 AM
    #71
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    For those who have done this, how much are you getting charged to have it done? I didnt want to get bigger tires, but if its not that expensive... well. Yeah. :spending:
    djwantke likes this.
  12. Mar 28, 2024 at 12:22 PM
    #72
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Well hats off to you sir! Cocked, locked, and ready to rock. That's really clean too. Did you take that somewhere? did you do it?
  13. Mar 28, 2024 at 2:07 PM
    #73
    HAH!
    That's correct, thanks dude
    @Thacrow @laxman09
    I paid $300CAD cash to a skilled fella about my age well known in the local offroad shop world, to do it all at his home shop. He was fast, like <3 hours. I walked over to Cabela's few blocks away, it was an awesome day.
    (I cut liner in front of wheel clean off @ top of viper cut)
    Very clean job. He was part of ARC-1 Industries at the time.
  14. Mar 28, 2024 at 2:21 PM
    #74
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That dude did really good work. you got a good deal there. And you're clearly very ready for those tires :headbang:
  15. Mar 28, 2024 at 2:37 PM
    #75
    Yes sir I agree, thanks buddy
    :rockband:
  16. Mar 28, 2024 at 5:35 PM
    #76
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Chopping and welding the body mount really doesn't take to much time(if you know what your doing). Id say 2-4hrs But with labor rates sky high expect to pay $400-$800.
  17. Mar 28, 2024 at 5:47 PM
    #77
    laxman09
    Oof. Ok that tamps down the desire
  18. Mar 28, 2024 at 5:57 PM
    #78
  19. Mar 29, 2024 at 9:34 AM
    #79
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    This is what really did it. This is the money supply for the USA. But other countries' money printing mimicks this.
  20. Mar 29, 2024 at 9:38 AM
    #80
    Not 100% sure what that means but our economy and supply and labour costs and everything is a direct result of leader ship policies and an answer to the skyrocket on the graph since the beginning of Covid you could say is leftism in general across the board LOL
  21. Mar 29, 2024 at 9:59 AM
    #81
    It really is true. Liberal party has ruined Canada, ask any Canadian.
    Hence me posting the photo of Biden.
    He’s just the latest placeholder, and latest face, or face mask I should say :p
    There’s a plethora of reasons we can pick, you and the graph are 100%correct. But we don’t have to look any further than the legislation against normal ppl & businesses (Covid rules, red tape, licensing, tax, DEI), this simply being one of the largest reasons I pay the exorbitant increase difference on prices in every category of goods and services in North America.
    Ask me what my mortgage is
    Ask me what my phone bill and cable bill are
    Ask me how much it cost to fill the 4R
    Ask me how much a box of cheerios costs
    Ask me how a 6-pack of Budweiser costs!
    (screenshot below: +tax & deposit!)
    Forget the rest of the world that we cannot control, our leader policies are all we can confidently blame for going out of their way to methodically extract every dollar they can squeeze out of citizens.
    This is how I believe a cash sale, privately fabricated BMC from a friend goes from $300 to $800
    off on a tangent rant over..
  22. Mar 29, 2024 at 10:58 AM
    #82
    DangitDad
    DangitDad New Member
    Ken
    2023 White 4Runner
    3"/2" Ironman lift, Method 703 wheels, K02's, Pedal Commander, more to come
    Holy shit. That's crazy. $16.35 more than I would pay for Budweiser.
  23. Mar 29, 2024 at 3:50 PM
    #83
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I can't speak for Canada. From my understanding Canada is screwed harder than any other countries. Cost of living has gone up more than anywhere else in the world which from my understanding is because the percentage of homes purchased in Canada by private organizations is higher than anywhere else in the world. Which is actually capitalism hard at work.
    The graph I posted shows a dramatic uptick in the American money supply when the US government started loaning rampantly to banks at 0 percent interest to fight off a depression when covid hit and keep the economy propped up. The rest of the world printed a lot of money as well. Economics 101 tells us that increased money suplly like that causes inflation. And we just saw the most inflation since the 90's here in the USA.
    That money supply was increased by both the trump and biden administrations. It's a global issue. And here in the US it isn't a left or right issue.
    It's just politicians wanting good economies so they can stay in office so they sacrifice our money in the long term for a very short term success.
    Trail Runnah and Thatbassguy like this.
  24. Mar 29, 2024 at 6:40 PM
    #84
    You’re clearly a very educated man on the subject
    I agree with those statements
    I guess my point is it’s the fault of the uniparty, yes, and it being a global problem doesn’t matter to me - I only care about what we’re creating and causing to ourselves alone
    4RunTM likes this.
  25. Mar 30, 2024 at 9:35 AM
    #85
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    The economy would have been fine if liberals didnt decide to stop the entire workforce for that long during covid
  26. Mar 30, 2024 at 9:49 AM
    #86
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    BNC ==> End of civilization
    Quite the journey this discussion has taken.
    hossler1788 and Thatbassguy like this.
  27. Mar 30, 2024 at 12:58 PM
    #87
    I take the blame for that
    I don't wanna get a one month you know what for politicking, I'm done I promise
