Does a body mount chop damage or make your 4Runner weaker?
Discussion in 'General 4Runner Talk' started by Longralph2, Sep 8, 2023.
  1. Sep 10, 2023 at 12:58 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    It was incorrect of me to say poor quality mild steel. It's their paint prep and paint that is garbage.
    I should not have said anything after my first comment telling OP to not bother worrying about it.
    I joke to myself that japanese 4runners and tacomas rust because they don't use steel that's been folded a bunch of times and their local steel is of poor quality.
  2. Sep 11, 2023 at 12:15 PM
    That’s pretty cool! Where did you find this?
    djwantke[QUOTED] likes this.
  3. Sep 11, 2023 at 1:19 PM
    Because of the shape of the front body mount in the drawing I question whether it is a 5th Gen 4Runner.
  4. Sep 11, 2023 at 1:52 PM
    Good eye! It does look different.
  5. Sep 11, 2023 at 2:28 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  6. Sep 11, 2023 at 2:30 PM
    I did notice that too. Doesn't particularly represent 5th Gen's; "it applies to the entire J120/J150 platform family.The platform originates with the Land Cruiser Prado 120 & 150 sold over seas and is basis for all the following vehicle's frames:"
    -2002~2009 Toyota Land Cruiser Prado (J120 or sometimes called "Prado 120")
    -2003~2009 Toyota 4Runner (4th gen, J120)
    -2007~2009 Toyota FJ Cruiser (J120)
    -2005~2009 Toyota Tacoma (J120)
    -2003~2009 Lexus GX470 (J120)
    -2010~Current Toyota Land Cruiser Prado (J150, or sometimes called "Prado 150")
    -2010~Current Toyota 4Runner (J150)
    -2010~2014 Toyota FJ Cruiser (J150)
    -2010~Current Lexus GX460 (J150)
    -2010~2015 Toyota Tacoma (J150)
    *2016~Current Toyota Tacoma (J150, I have not seen any official documentation stating platform, but it appears to be a J150 frame with one or two minor changes)
  7. Sep 11, 2023 at 5:13 PM
    How many MPa do you think the cab mount material retains after a few salty winters? :stirthepot:
    Thacrow and djwantke[QUOTED] like this.
  8. Sep 11, 2023 at 11:44 PM
    It looks exactly the same as my 4runner as far as can tell. The front are small little mounts. The ones behind the wheel (the body mounts in question that are chopped) have that forward swept look. And the two sets behind it are small round ones like the front. All the xmembers are the same as well.
  9. Sep 12, 2023 at 3:12 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    DRT relocation kit. It has a base plate that get welded between the mount and the frame. More surface area to spread the load across the frame.
    kolter45 and Chris In Milwaukee like this.
  10. Sep 12, 2023 at 8:31 AM
    garoto
    garoto New Member
    Also think about being able to resell or trade your car if you go that route.
    During the trade you’re obligated to disclose that.
  11. Sep 12, 2023 at 9:04 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I don't see that as an issue at all.
    There's a BM chop to makes these tires fit which you would have had to do so obviously this saves you time and money.
  12. Sep 12, 2023 at 9:29 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You don't have to tell them anything. Its the buyers responsibility to inspect the vehicle.
    I traded in my tacoma that had a bmc+ pinch weld flattening. They put it on a lift to inspect. And didn't even notice the modifications.
    This thread is silly.
  13. Sep 12, 2023 at 10:22 AM
    Nope. There are a hundred ways for a used vehicle to be unsafe (think rusted brake line, leaking fuel line, tire defect...). It's the buyer's responsibility to inspect the vehicle. If trading in, the dealer's used car manager will have decades of experience picking out defects for the purpose of de-valuing your trade - you don't need to give them any help.
    djwantke likes this.
  14. Sep 12, 2023 at 10:26 AM
    I was curious, as I thought there was something where you had to report any kind of frame damage. But, as far as I can tell, the only thing you have to report (in Wisconsin, at least) is whether or not the odometer is known to be accurate, whether or not it was a fleet or rental, and whether or not it had a salvage title or flood damage. I may have missed something, but I did not notice anything specifically about the frame.
    3JOH22A[QUOTED] likes this.
  15. Sep 12, 2023 at 11:48 AM
    Well - there’s legal obligation and then there’s moral obligation.
  16. Sep 12, 2023 at 12:26 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Life's way too short. I say just cut the sob :laser:
    Chris In Milwaukee and Henry J like this.
  17. Sep 12, 2023 at 3:04 PM
    By the way, basic off-the-shelf DOM tubing is 90 ksi or 620 MPa i.e. between high-strength and ultra-high-strength steel.
  18. Sep 12, 2023 at 3:40 PM
    It’s great that you know what that means. Maybe you could explain it to the rest of us.
  19. Sep 12, 2023 at 4:47 PM
    #49
    Henry J
    Sacramento Ca
    It’s tough, man tough
  20. Sep 12, 2023 at 4:54 PM
    #50
    I understand that sentiment. I’ve only sold my old cars private party “as is”. I make it clear what I think it needs done, what’s bad, and what I think is good, then reiterate “as-is.” and what that means. If I sell my 4runner private party some day, and can’t or wont return it to stock, I’ll make it clear that it’s been modified and sold as-is. If they ask details, I’ll disclose details. I have no idea what a buyer would care about, so I’m not sure that listing out everything they might possibly consider a problem will help anything. If they ask details about the modifications, then I’ll explain specifically. I’ve sold a few motorcycles, which are deathtraps by design, and I have to assume the buyer is capable or taking some level of responsibility for what they are buying. I think the same goes for an obviously modified 4runner.
    I suppose if a guy or gal with three little kids in tow falls in love with it, and says stupid stuff like “I love the cute bumper with the string on it”, I’ll probably tell them it’s a death trap, it’s not for sale anymore, and they should maybe consider a nice rav4 or highlander. Lol
  21. Sep 12, 2023 at 7:01 PM
    #51
    garoto
    garoto New Member
    If you truly read where you sign in the dotted line when you trade, there are quite a few things “that are not wrong with the car” that you agree to, as well as disclaimers about things you promise to have disclosed.
    Just trying to help.
  22. Sep 12, 2023 at 8:06 PM
    #52
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    It has been a while, but I believe ksi is shear strength, and I don't remember what the MPa (Mega Paschals?) represents.
  23. Sep 12, 2023 at 8:22 PM
    #53
    K-Paul
    Corbin Dallas
    SR5 4WD
    If you take a flux capacitor and mount it on the right side rear frame at a 30 degree angle whilst screaming "Jesus Take The Wheel", I assure you it is most certainly safe to do a BMC.
    if you ignore my comments, you will most certainly perish in a possum collision. Your choice.
    Chris In Milwaukee likes this.
  24. Sep 12, 2023 at 9:03 PM
    #54
    And you have disclosed everything to the best of your knowledge as a non-professional reading about 4Runners from random fuckers on the internet i.e. unenforceable ;) After all, the dealer took the vehicle on trade-in after inspection by their licensed mechanic.
    In reality, their offer on your trade-in has been de-valued by "repairs they'd need to do to bring the vehicle to standard". The dealer will go out of their way to point out all the things broken on your 4Runner, to make you comfortable accepting their low-ball offer.
  25. Sep 12, 2023 at 9:40 PM
    #55
    Yeah, I’m sure a dealer contract will have all sorts of details that will allow them to take the deal back. They might not in this market, but if they wanted to they could make life interesting if all of a sudden they don’t want it. So in a way, it probably wouldnt matter if you verbally disclosed anything you could think of…signing the contract might actually nullify your disclosure unless it’s written down in the contract.
    If anyone has stared down a possum caught in headlights while it’s bearing it’s tiny little devil kitten teeth, then you know exactly how terrifying this is…
    I don’t care how tasty they are…still terrifying.
  26. Sep 12, 2023 at 9:51 PM
    #56
    This is hilarious
  27. Sep 14, 2023 at 4:24 AM
    #57
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
  28. Mar 25, 2024 at 4:00 PM
    #58
    The BMC choice was made for me, after I chose to put red Loctite on the OE wheel studs before spacers.:anonymous:
    raimieb likes this.
  29. Mar 25, 2024 at 4:04 PM
    #59
    K-Paul
    Corbin Dallas
    SR5 4WD
    Is red locktite that strong?
  30. Mar 25, 2024 at 4:54 PM
    #60
    @K-Paul I mean I haven't tried to breaker bar the Spidertrax spacers, but I've read on here that once you red Loctite wheel studs for instance, you have to blow torch/heat the b*tch up first. Which I'm like, NOPE
