Dobinsons 5th Gen 4Runner Suspension options
Discussion in 'Exit Offroad' started by Crikeymike, Apr 23, 2020.
  1. Apr 26, 2023 at 6:20 AM
    #211
    Crikeymike
    Crikeymike [OP] Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    Hey man, I'm doing great thanks.
    What rear weight is it? If it's on the rear bumper, then you'll want the 327's in the back, since that weight is a good amount of leverage on the rear suspension. The rest of the parts are correct.
  2. Apr 26, 2023 at 2:32 PM
    #212
    zawale
    zawale New Member
    I have a drawer system in the cargo area and a C4 ladder in the back. So the weight isn’t too far back but still over the rear suspension.
  3. Apr 27, 2023 at 5:42 AM
    #213
    Crikeymike
    Jax Beach, FL
    Ok. C59-325 would be about 1.5-1.75" of lift and the 327s would be 2-2.25".
  4. May 15, 2023 at 10:04 PM
    #214
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Hey Mike, what’s the recommended rebuild interval on the MRA shocks (sorry if I missed this in the thread)?
  5. May 16, 2023 at 6:48 AM
    #215
    Crikeymike
    Jax Beach, FL
    Hey bud,
    There technically isn't one.
    Dobinsons USA put this out since Americans couldn't get over the "there's no rebuild schedule" thing, as so many other brands of rebuildable shocks have really low rebuild intervals.
    So anyway, take this with a grain of salt. I have 60k miles on my 3.5 year old MRA's and I've never had to do anything to them.
  6. Jul 12, 2023 at 8:32 PM
    #216
    Adi979
    Adi979 New Member
    ‘23 TRD ORP
    Are the GS59-705 only available in yellow color?
  7. Jul 13, 2023 at 7:04 AM
    #217
    Crikeymike
    Jax Beach, FL
  8. Jul 18, 2023 at 10:42 AM
    #218
    HyperWaveRNR
    HyperWaveRNR New Member
    I did end up adding the spacers at your recommendation. I almost removed them as there was over a 2” height difference in the rear over the front. But I went on a road trip first, thankfully, loaded down the runner was almost level.
    Thank you for your help!!
  9. Aug 22, 2023 at 10:25 AM
    #219
    GoldenDood
    GoldenDood New Member
    2023 ORP Nautical Blue
    I’m looking for a mild 1.5” lift while maintaining about 1.5” of rake on a stock load vehicle. Would the below combination be recommended?
    Front Springs: C59-296 - 1.5" Lift
    Front Shocks: GS59-700 - Twin tube
    Rear Springs: C59-599 - 1" Lift
    Rear Shocks: GS59-705 - Twin Tube
  10. Aug 22, 2023 at 10:42 AM
    #220
    Crikeymike
    Jax Beach, FL
    Yeah, that's correct. It may be closer to 1.75" of rake though. If you want to reduce the rake more, you can use the C59-300 2" front coils
  11. Sep 15, 2023 at 3:55 PM
    #221
    H3llRid3r
    H3llRid3r New Member
    2023 Ice Cap 4Runner TRD Off-Road Premium w/ KDSS
    100% Stock (for now)
    Do the Dobinsons Aluminum UCA's provide the same 3 degrees of castor that the tubular ones do?
  12. Sep 15, 2023 at 7:11 PM
    #222
    OverRunner
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I believe you can get either 2 or 3 degrees based on how you install the spacer (on the chassis mount) it comes with. It can be installed in front of the strut for 2 degrees and a little extra body mount clearance, or behind the strut for 3 degrees of built-in castor.
  13. Sep 16, 2023 at 8:53 AM
    #223
    Crikeymike
    Jax Beach, FL
    That's correct.
    I ended up with 4.5 degrees of caster with my alignment once they were installed and adjusted.
    H3llRid3r likes this.
  14. Sep 16, 2023 at 9:21 PM
    #224
    H3llRid3r
    Any reason to pick the aluminum over the tubular?
  15. Sep 17, 2023 at 8:51 AM
    #225
    Crikeymike
    Jax Beach, FL
    So that you can get the perfect alignment by adjusting the upper and lower control arms
    H3llRid3r[QUOTED] likes this.
  16. Sep 19, 2023 at 6:09 AM
    #226
    H3llRid3r
    I get that. My question is more toward the cost of each. On Dobinson website the tubular UCA’s claim up to 3 degrees of castor. I don’t see that for the aluminum, which cost about $300 more.
  17. Sep 19, 2023 at 6:18 AM
    #227
    OverRunner
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I had the same thought, but the instructions that come with the UCA are more detailed than the advertisement. You still get 3 deg (or less if you want) and you can get even more as Mike alluded to above, because you can use the camber tabs on the LCA to move it all the way forward (increasing caster even more) and use the UCA adjustment to fine-tune (fix) camber.
    This also has the advantage of moving the tire away from the body mount.
  18. Sep 19, 2023 at 6:27 AM
    #228
    Crikeymike
    Jax Beach, FL
    In the description...
    Dobinsons Billet Aluminum UCA’s are among the best in the market and are a great front upper control arm upgrade. Dobinsons worked tirelessly on producing the strongest UCA’s on the market while using the highest quality components to produce excellent strength, functionality, and longevity. The new Dobinsons Billet Aluminum UCA’s are just that, machined from a single piece of billet aluminum to produce a single arm with the best strength available. Don’t be fooled by other cast aluminum arms on the market, they aren’t as strong as billet aluminum. In addition to being a one piece arm, Dobinsons went one step further to incorporate the factory features of stock UCA’s that make stock UCA’s last so long – their high quality ball joints and OE full rubber bushings with vulcanized sleeves. Many other brands use a polyurethane multi-piece bushing that requires constant greasing, and also adding more NVH to the front end (Noise, Vibration, Harshness). When you lift your truck or SUV, you want the added suspension components to help the ride quality, not hinder it, and these high quality billet aluminum UCA’s are made exactly for that purpose.
    Having adjustable ends on the arms, where it attaches to the frame, your alignment shop can dial in the perfect amount of added caster and camber to get your lifted vehicle setup properly. These are on-vehicle adjustable, so once they’re initially setup and installed, the alignment tech can fine tune those settings into the arms without having to remove them again.
  19. Sep 19, 2023 at 10:13 AM
    #229
    H3llRid3r
    Excellent. Thank you both for the explanation. This is what i was looking for.
  20. Oct 15, 2023 at 9:55 PM
    #230
    zawale
    zawale New Member
    Mike, I finally was able to get my MRA + 302 front and 325 rear coil set up installed and am absolutely loving it so far! With the constant weight in the rear, the 325 net me 1.5" of lift, but i was hoping for a little more. Would the 327 get me closer to 2" of lift in the rear, or would I possibly be able to swing the 675V?
    Crikeymike[OP] likes this.
  21. Oct 16, 2023 at 7:32 AM
    #231
    Crikeymike
    Jax Beach, FL
    That's great to hear. Yes, the 327's would bring it up that extra 1/2". What's your hub to fender measurement in the rear now?
  22. Oct 16, 2023 at 10:04 AM
    #232
    zawale
    zawale New Member
    I'm currently sitting at 23 1/2"
  23. Oct 16, 2023 at 11:05 AM
    #233
    Crikeymike
    Jax Beach, FL
    Ok. 327s usually sit at 24-24.5” depending on the load so I'd expect that 24" with your weight
  24. Oct 23, 2023 at 1:37 PM
    #234
    Crikeymike
    Jax Beach, FL
  25. Oct 23, 2023 at 7:34 PM
    #235
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    So I'm looking to replace the shocks and struts but keeping the stock height (stock springs). Ideally I'm hoping for less body roll on the road but not too mush harshness on FSR etc. Am I correct in looking at the Dobinsons GS59-700 struts for the front and the GS59-701 for the rear? When going on roadtrips I usually have a fridge in the the back along with my dog. I also sometimes tow a 700-900lb trailer.
  26. Oct 24, 2023 at 6:20 AM
    #236
    Crikeymike
    Jax Beach, FL
    Hey bud,
    Yes, those struts and shocks would work just fine with the factory coils. You could also consider adding a set of helper air springs inside the coils if that trailer has a heavy tongue weight. https://exitoffroad.com/product/firestone-4135-coil-rite-rear-helper-air-springs-airbags/
  27. Oct 31, 2023 at 12:39 PM
    #237
    Crikeymike
    Jax Beach, FL
  28. Nov 1, 2023 at 9:23 AM
    #238
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Hey crikey, are C59-323 rear coils stiffer than the oem springs?. I'm running trd pro shocks but id like to stiffen up the rear a little.
  29. Nov 1, 2023 at 9:32 AM
    #239
    Crikeymike
    Jax Beach, FL
    Yeah they are. They're the same as the trd pro, 220lb rate compared to 190 stock
  30. Nov 1, 2023 at 2:06 PM
    #240
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I thought all 4runner shared the same rear springs?
