Dobinsons 5th Gen 4Runner Suspension options
Discussion in 'Exit Offroad' started by Crikeymike, Apr 23, 2020.
  1. Jun 15, 2021 at 7:20 AM
    #61
    Crikeymike
    Crikeymike [OP] Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    The Treaty Oak spacers relocate the KDSS sway bars front and rear down to a more stock angle, whilst the Dobinsons lean correction spacers push that side of the car higher to compensate for how the KDSS system usually creates a lean. This is why only one method is really needed, and the Treaty Oak spacers work better than coil/strut spacers from what I've found. It also makes it ride smoother with a better sway bar angle.
    Tuco S. and Red_5 like this.
  2. Jun 15, 2021 at 8:11 AM
    #62
    Red_5
    Red_5 New Member
    Excellent explanation. Thank you.
  3. Jun 15, 2021 at 8:27 AM
    #63
    dsstao
    dsstao New Member
    David
    Gotcha..Thank You. Do you know why the Treaty Oak kit "only" has 3 spacers instead of 4?
  4. Jun 15, 2021 at 8:44 AM
    #64
    replica9000
    replica9000 New Member
    Jason
    New Vertiform City
    2019 TRD OR Premium
    If i wanted an extra 1/2" of lift, would it be better to adjust the shock, or add a spacer like PS59-4030?
    I ask because I don't know if that adjustment would negatively impact ride quality, and throwing on a spacer might be faster than compressing the coil for a small adjustment.
  5. Jun 15, 2021 at 11:16 AM
    #65
    Crikeymike
    Jax Beach, FL
    The piston side on the front can get really long and a spacer isn't needed on it
  6. Jun 15, 2021 at 11:16 AM
    #66
    Crikeymike
    Jax Beach, FL
    For just half an inch, adjusting the shocks would be fine. But yeah, adding a spacer is easier, but it costs money to do that too.
  7. Jun 16, 2021 at 8:05 AM
    #67
    OVERL8ND
    OVERL8ND New Member
    Hi Mike,
    I'm currently running fox suspension with icon 2” rear springs and now have sag with my new setup. I’m running 33”, tire carrier, new heavier RTT, and fully loaded with gear. I’m looking to get new rear springs to help with the major rear sag it has now. The truck is usually only loaded during summer for multiple trips. But other than that I unload it.
    Which rear spring would you recommend? I’m non-kdss. Thank you.
  8. Jun 16, 2021 at 8:56 AM
    #68
    captrussia253
    captrussia253 New Member
    Ruslan
    Teal Front Spring: C59-314
    Teal Rear Spring: C59-327
    Front Shock: GS59-700
    Rear Shock: GS59-705
    Will be adding a front bumper with winch and a rear tire carrier as the ride is a little stiff at the moment.
  9. Jun 16, 2021 at 9:28 AM
    #69
    replica9000
    Jason
    New Vertiform City
    2019 TRD OR Premium
    I put on my Dobinsons lift Saturday. The rear seems to have a slight pogo affect. I have the IMS59-50705 shocks and C59-325 springs. I also put the PS59-4025 15mm poly spacer on each side for extra lift, but I may remove them since the back is higher than I expected it to be. Would this spacers be causing the pogo effect?
  10. Jun 16, 2021 at 9:35 AM
    #70
    Crikeymike
    Jax Beach, FL
    Hey man. C59-677V is what I'd recommend, but they're 3" springs. If you're looking to stay at 2" of lift, C59-329's would be the next best bet. When unloaded, you'll be sitting at like 2.5" of lift.
    OVERL8ND[QUOTED] likes this.
  11. Jun 16, 2021 at 9:45 AM
    #71
    OVERL8ND
    OVERL8ND New Member
    Do you have the C59-677V and 329s in stock? In Black?
  12. Jun 16, 2021 at 9:58 AM
    #72
    captrussia253
    Ruslan
    Definitely take those spacers out. It'll look better and should get rid of the "pogo" effect.
    LandCruiser likes this.
  13. Jun 16, 2021 at 10:00 AM
    #73
    Crikeymike
    Jax Beach, FL
  14. Jun 16, 2021 at 7:14 PM
    #74
    Cashville224
    Cashville224 New Member
    Mt. Juliet, TN
    16 TRDP Quicksand
    Lasfit LED's
    Mike,
    Looking to put a 2" lift on my 16 trdp, which springs would work with Bilstein?
  15. Jun 16, 2021 at 9:36 PM
    #75
    OVERL8ND
    OVERL8ND New Member
    I'll be at 2.5" lift unloaded on the 2" or 3" spring?
  16. Jun 17, 2021 at 6:55 AM
    #76
    Crikeymike
    Jax Beach, FL
    All of the Dobinsons front springs will work on 5100's, but none will work on 6112's.
    Use C59-300 if you're stock weight up front.
  17. Jun 17, 2021 at 6:55 AM
    #77
    Crikeymike
    Jax Beach, FL
    On the C59-329's.
  18. Jun 17, 2021 at 7:54 AM
    #78
    OVERL8ND
    OVERL8ND New Member
    So I would assume the 3" sit at 3.5" unloaded? I have garage clearance issues, so I have to be pretty precise on my measurements.
  19. Jun 17, 2021 at 10:46 AM
    #79
    Crikeymike
    Jax Beach, FL
    The 677V sit at about 3.25" unloaded usually. If you have clearance issues, go with less lift for sure.
  20. Jun 30, 2021 at 10:10 AM
    #80
    Crikeymike
    Jax Beach, FL
    Free shipping on any order of $500 or more from now until midnight on 7/7/21 EDT. Excludes all armor, leaf springs and awnings, and drawers, but applies to all shocks, struts, coils, UCA's, etc
    https://exitoffroad.com/
    First, add items to cart, go to checkout, use coupon code “JULY4TH” for the discount to be applied. Not valid with any other discounts, will not work with excluded products in the cart (remove those and buy separately)
    Chris In Milwaukee likes this.
  21. Jul 17, 2021 at 7:24 PM
    #81
    TexasGreyGhost
    TexasGreyGhost New Member
    2019 4Runner TRD Off-road
    2/1 lift
    Hey Mike. I have installed a Dobinsons 2/1 lift on our 2019 and now I have a left lean, 3/4" rear and "1/2 front. I originally thought we had KDSS but once under it, realized we didn't. Didn't use the supplied spacers. Should I use them on the left side to correct the lean?
  22. Jul 19, 2021 at 6:16 AM
    #82
    Crikeymike
    Jax Beach, FL
    Hey man.
    Yeah, using those spacers front and rear on the low side should push you back level. That's quite a lot of lean for a low lift, but it happens sometimes.
  23. Jul 19, 2021 at 6:46 AM
    #83
    DukemavT4r
    DukemavT4r New Member
    2019 SR5 Premium
    Full length prinsu Rack Cali raised ditch lights/brackets Cali raised slim led bar Dobinsons Lift RCI Skids Method Wheels 23zero Walkabout 23zero 180 awning
    Hey Mike!
    I am running about 400lbs of extra weight with full length rack, rtt, sliders, and platform in the trunk with fridge/slide. I am looking for 2.5 front, 1.5 rear lift.
    What would be your suggested setup?
  24. Jul 19, 2021 at 7:47 AM
    #84
    Crikeymike
    Jax Beach, FL
    Hey man.
    Does the RTT stay up there all the time? I've had guys run the C59-505 even with a RTT and not have a problem with the lift height. Technically the 2" C59-325 would squat down to 1.5" of lift with 200-220lbs on them, so that would be the next option, but if you take the tent off, it will be 2" of lift or there about.
    And up front, C59-302 coils would get you the 2.5".
    Then you would just need to decide which level of struts and shocks you want to go with. Twin tube, IMS or MRA.
  25. Aug 15, 2021 at 6:11 AM
    #85
    bigdaddy2021
    bigdaddy2021 New Member
    Brian
    So-Cal
    2019 4runner - TRD Off-Road
    Armored, Dobinson's lift, 33's, MC TacoBox, Frontrunner rack, light overland mods, M8000 winch.
    just read through this thread. Very much appreciate the info Here's our rig:
    2019 4runner TRD Off-road w/ KDSS | Front/Rear full bumpers w/ winch and tire swingout | 2 adults/3 kids | full drawers | Fridge | normal amount of food/gear | no RTT/Rack at the moment but planned.
    Basically, she's a heavy beast.
    This is what i came up with for 2.5" of lift with all that weight using the builder. How'd I do? also, what kind of lead time is there on my list? thanks!
    Dobinsons 1" to 3.5" Build-A-Kit Toyota 4Runner 2010-21 (All Options)
    · Dobinsons C59-354 Front Lifted Coil Springs for Toyota 4x4 Trucks and SUV's
    o Teal Dobinsons Coils
    · Dobinsons GS59-574 Pair of Long Travel Front Struts for Toyota FJ Cruiser 2010+ and 4Runner 2010+
    o Yellow Twin Tube Struts/Shocks
    · Dobinsons C59-329 Rear Coil Springs for Toyota 4Runner and FJ Cruiser
    · Dobinsons IMS59-50701 IMS Monotube IFP Rear Shocks for 2003-21 4Runner, FJ Cruiser, GX470 GX460 (0-3" lift)
    · SC59-001 Mounts and Strut Assembly Bundle
    o Dobinsons Pair of Strut Top Plates for Toyota Tacoma 2005+, 4Runner 2003+, FJ Cruiser, GX470, GX460 and Strut Assembly - Labor Charge (adds 2+ weeks delay in shipping due to backlog)
    · Dobinsons Coil Spacer
    o Front and Rear Lean Correction Spacers Bundle
    · Dobinsons PS59-4030 1/4" Alloy Strut Top Mount Spacer for Toyota and Lexus 4x4→
    o Dobinsons Rear Spacer, 15mm | 4Runner FJ Cruiser Lexus GX470 GX460
    · Treaty Oak Offroad KDSS Spacer Kit
    o KDSS Spacer Kit - Lexus GX460 5th Gen 4Runner by Treaty Oak Offroad
    · $1720.00
  26. Aug 16, 2021 at 9:03 AM
    #86
    Crikeymike
    Jax Beach, FL
    Hey man.
    Yeah, that's pretty close. You ordered twin tube front struts and monotube IMS rear shocks though, so you'll need to match those up front and rear. The coil spring selection is correct.
    With the Treaty Oak spacer kit, you won't need the front and rear leveling spacers.
    As of right now, it's in stock, and would just take 2-3 weeks for the assembly.
    bigdaddy2021[QUOTED] likes this.
  27. Aug 16, 2021 at 10:06 AM
    #87
    bigdaddy2021
    Brian
    So-Cal
    Thanks for the reply! I’ll go back to the site and make those corrections, and look at the new quote. Much appreciated.
  28. Aug 16, 2021 at 10:19 AM
    #88
    DirigoT4R
    DirigoT4R New Member
    ‘21 ORP NB
    Could you pair dobinson coil/springs with Eibach shocks?
    bigdaddy2021 likes this.
  29. Aug 16, 2021 at 10:24 AM
    #89
    Crikeymike
    Jax Beach, FL
    In the back no problem. But up front, I'm not sure. They might use a different coil end configuration on their struts that may not match Dobinsons. Dobinsons use the OE configuration.
  30. Sep 2, 2021 at 6:22 AM
    #90
    Gossamer
    Gossamer lunarrocktrdpro1
    Middle of America
    any ideas what to do with a 21 trd pro so I can stiffen up the back end and eliminate the extreme sag from dogs and a small trailer?
