Dobinson Lift Installed
Discussion in 'Suspension' started by Roland, May 27, 2021.
  1. Jul 27, 2021 at 10:21 AM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    I went with the C59-314 springs in front. Without the bumper, winch and 2nd battery I was almost at 4". I will have to measure it again to see how much it has settled down with all that weight added now. Like Roland, I am very happy with the setup and recommend talking to Mike at Exit Offroad.
    Roland[OP] likes this.
  2. Jul 28, 2021 at 6:58 AM
    fffffff
    fffffff New Member
    Lift should be going on Friday, going to be driving across the country so should settle nicely.
  3. Jul 28, 2021 at 11:52 AM
    Roland
    Roland [OP] New Member
    Are you going to add a bumper/winch, or stock weight? In case of stock weight, mine didn't settle or sag at all, almost 4K miles with it on all kinds of terrain.
    Congrats & show some pictures when on. I'm sure, you will be pleased.
    I have a buddy that has a full King suspension lift with UCA & diff-drop (more or less same lift height) about 4.5 times the price, he drove my 4runner and I drove his. We compared shocks, both brands are machined & rebuildable.
    Our test: Btw. We have the same tires, makes it easier to compare.
    The only difference, I thought his rig taking tight corners was better, more direct and articulated, as well, high speed on a bumpy road his rig was easer to control, in my opinion. Hence, I’m talking minor differences, I could not feel that up to 85 Mph only above this speed his setup felt more forgiving.
    He said he could not feel the difference in tight corners, only on high-speed bumpy roads, he could feel the difference in stability (Kings are better). Actually the entire setup is what makes that difference at 4.5 times the price. Off-Road the Dobinsons suspension is smoother, and I think shines; (for sure rock-crawling).
  4. Aug 9, 2021 at 8:43 PM
    fffffff
    fffffff New Member
    Sorry for the late response but got my lift installed. Love everything about it a much nicer ride now.
    8426339C-4183-4EF4-943A-E6F6CE4D6A12.jpg B9CAEFA3-1041-481D-BC90-5B9219D40A45.jpg
  5. Aug 9, 2021 at 8:46 PM
    Roland
    Glad you like it, awesome rig. Did you take it Off-Road ?
  6. Aug 9, 2021 at 8:49 PM
    fffffff
    fffffff New Member
    I did take it off road, thought it performed great, I went with Dobinsons UCAs as well. No serious Rock crawling yet.
    Roland[QUOTED][OP] likes this.
  7. Aug 9, 2021 at 8:53 PM
    Roland
    Great, how much lift do you have? I'm back in Moab in fall, you should meet up.
  8. Aug 9, 2021 at 8:54 PM
    fffffff
    fffffff New Member
    2.5“ Front 1.5“ back
  9. Aug 9, 2021 at 8:56 PM
    Roland
    Great looking rig, very nice.
    olliechristoper and nimby like this.
  10. Aug 10, 2021 at 9:44 AM
    Looks awesome man!
    Congrats!
  11. Aug 13, 2021 at 6:18 PM
    Looks reaaally good. What size KO2s do you have?
  12. Aug 13, 2021 at 6:25 PM
    Roland
    Might be wrong, I think they are 285/70/17 If I look at wheel wells looks pretty much the same as my lift with 285's.
  13. Aug 13, 2021 at 8:22 PM
    Evo03
    Evo03 New Member
    Your truck looks great. What tires did you have on before your KO2's? Were they stock size?
  14. Aug 13, 2021 at 8:28 PM
    Roland
    Thank you, the tires before 265/70/17 Nitto Terra Grapplers stock with the TRD Pro wheels when I purchased the 4R, changed to the KO 2's 285/70/17 when I had 11700 miles.
  15. Aug 13, 2021 at 9:14 PM
    Evo03
    Evo03 New Member
    The truck looked pretty good with them on too. Looks like the Nittos might run a little bigger than my 265/70r17 KO2's.
  16. Aug 13, 2021 at 10:53 PM
    Kilo Papa
    Kilo Papa New Member
    TX & NM
    2021 TRD Pro
    Great looking build! Dobinson Direct’s website doesn’t mention delivery times. With everyone backed up as they are these days, how long did it take you to get the Dobinsons after you ordered?
  17. Aug 14, 2021 at 6:16 AM
    Evo03
    Evo03 New Member
    I just ordered 2 inch front, 1.5 inch rear Dobinson IMS kit from Exit Offroad. They were in stock
  18. Aug 14, 2021 at 8:52 AM
    Roland
    Which shocks & coils did you order, do you have the numbers like in my signature?
  19. Aug 14, 2021 at 9:01 AM
    #49
    Roland
    IMOP, The KO 2's are better than the Nitto's, just me, opinions might differ.
  20. Aug 14, 2021 at 1:37 PM
    #50
    Evo03
    Evo03 New Member
    Same IMS shocks as you, but I got C59-300 front springs (1.75 - 2 inch) and C59-505 1.5 inch rear springs. I'm hoping the 1.5 inch rear isn't too much for my stock size KO2's. But I'm wanting to keep some rake. If the rear lift actually ends up being 1.5" I think I'll be OK.
  21. Aug 14, 2021 at 3:04 PM
    #51
    Roland
    I have 2.7" F & 1.7" R no spacers around 4000 miles with it, still the same height, mine didn't settle like some members say. I still have some rake. The nice thing about these shocks if you don't like the rake, you can adjust them a bit more (0-3.5"), will give you some more lift in the front. I think I posted some pictures with the 265's and with the 285's you can see the difference. Congrats, post some pictures.
  22. Aug 14, 2021 at 3:17 PM
    #52
    Kilo Papa
    TX & NM
    2021 TRD Pro
    New b at lifting here so this thread has been really helpful. So how does one go about adjusting these Dobinsons? Are they fairly easily adjusted? I’ve read that some other brands require removal and spring compression, etc? Doesn’t sound like much of a DIY for me!
  23. Aug 14, 2021 at 3:35 PM
    #53
    Roland
    "require removal and spring compression" Yes, this is correct; you need to readjust the locking rings to bring the coil seat lower or higher. With most other brands as well.
  24. Aug 14, 2021 at 3:40 PM
    #54
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Got it.Thanks. So, Best to get the desired “pre-set” lift correct with the best match factory settings part # and go from there.
    It also sounds like getting the Dobinson UCA, while not required w the lower lifts, tends to provide a better ride and better chance for good alignments?
  25. Aug 14, 2021 at 4:15 PM
    #55
    Roland
    I got it right the first time, put 285's shoes on, got an alignment done, no rubbing no problems on/off-road.
    With the stock UCA's I did some heavy off-roading (rocks, ledges) etc., no problems, no rubbing. Checked afterwards everything in spec. Some members will agree and others not so much, highly debatable.
    I figured in case checking after my trip and everything is still in spec, I keep the OEM UCA's for more than one reason, their maintenance free, and the less you mess with the geometry the better, otherwise you keep on adding and adding, I never heard any complaints about the OEM UCA's. If out of spec because of the UCA's, I can always change them for aftermarket. Just my 2c.
    I respect everyone's opinion.
  26. Aug 14, 2021 at 9:18 PM
    #56
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Thanks, Roland. That’s helpful. I’m running 275 KO2’s so with a less than 3” lift on the front, OEM UCA’s should be good.
  27. Aug 14, 2021 at 11:34 PM
    #57
    fffffff
    fffffff New Member
    These are actually 265/70/17 so stock size KO2s. Going to go up in size when these are done.
  28. Aug 14, 2021 at 11:35 PM
    #58
    fffffff
    fffffff New Member
    I ordered from exit offroad took about 3 weeks for everything to arrive.
  29. Aug 15, 2021 at 12:56 AM
    #59
    excellent to hear. I have stock size KO2s, so its nice to think that, I too, can have a 4runner that looks this badass lol
    Roland[OP] and Evo03 like this.
  30. Aug 15, 2021 at 12:13 PM
    #60
    Even worse is "I leveled my truck with 2" front, 1" rear".
    Yeah that's a LIFT.
    nimby[QUOTED] likes this.
