Do I "Need" a 3" Lift?
Discussion in '5th Gen 4Runners (2010-2024)' started by FourT6and2, May 20, 2024.
  1. May 21, 2024 at 1:29 PM
    #61
    FourT6and2
    FourT6and2 [OP] New Member
    Well I never wanted a 3" lift, that's just what all the shops I contacted about the install told me was required to fit -38 ET wheels with 285s. It's hard to say what lift I want vs what I need before seeing the wheels/tires on the vehicle. But I suppose 2"/1" is the way to go. I can get there with either the Eibach Fox replacement springs w/fixed height (2.4" front, 1" rear) or coilovers with 1" rear springs. And then I can set the front to whatever height I want.
    If I go that route, trying to decide between Fox or DirtKing/Elka.
  2. May 21, 2024 at 1:38 PM
    #62
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Ah I gotcha.
    As @Thatbassguy stated in post #2 you don't need a lift to fit tires. Lifting might hide the need for trimming until you flex out the suspension.
    But fitting large tires properly comes down to trimming.
    With that said, do you want a lift? Because you certainly don't need it to fit large tires
  3. May 21, 2024 at 1:48 PM
    #63
    Wants & Needs are often confused on this site. I tell myself all the time that I NEED the newest-prettiest-shiniest-coolest mod or accessories that comes out (and if you have a new one to tell me about, keep it to yourself - my wallet will thank you later), but I actually want them. I probably only NEED about 2% of the shit that I've slapped onto my truck.
    nonuniform likes this.
  4. May 21, 2024 at 2:08 PM
    #64
    FourT6and2
    No, I don't want a lift. Unless I see the new wheels/tires on and I'm like yeah... it'll look better with a subtle lift. I suppose I could go that route first. Just put the new wheels/tires on the stock suspension, do a body mount chop, and trim what needs trimming. Drive that around for a minute and see if I like it and then decide if I want/need new coilovers/springs.
  5. May 21, 2024 at 2:20 PM
    #65
    1SilverRunner
    Tejas
    Sounds like a great plan!
    Make sure you get you BMC done by a reputable shop who work on Toyotas often.
    If you don't have one in mind I'm sure if you post about asking for a good shop in your area you'll get pointed in the right direction. Posting this because if a shop is telling you that you NEED a 3" lift to fit big tires that could be a red flag.
    My first BMC was a dumpster fire. Needless to say I will not be returning to that shop.
    It was later redone by a shop that specialized in Yotas.
  6. May 21, 2024 at 2:21 PM
    #66
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I have a pic from my 20 AG Pro with stock size tire and SCS wheels if you need to see it.
  7. May 21, 2024 at 3:04 PM
    #67
    FourT6and2
    I'm in the SF Bay Area. Shops I've talked to and/or I'm considering are Stellar Built, Klean Ridez (yeah, I know the name is janky lol), and Milogen Fabrication. Stellar seems to have a good reputation (but they're the ones telling me I need a 3" lift for -38 wheels). SCS recommended Milogen. And some nice rigs I've seen with aggressive setups were done at Klean Ridez. I spoke to them and they seemed good on the phone at least. They sent me photos of the BMC their fabricator does and it looked good, but I'm no expert.
  8. May 21, 2024 at 3:07 PM
    #68
    Side note, @FourT6and2 , are you a Tool fan, by chance? ;)
  9. May 21, 2024 at 3:07 PM
    #69
    FourT6and2
    I think I've seen the photo in another thread, but post it up again! And it's on stock suspension as well?
  10. May 21, 2024 at 3:07 PM
    #70
    FourT6and2
    Hell yeah
  11. May 21, 2024 at 3:12 PM
    #71
    RusPro17
    Don
    Pa.
    Not a fan of the fake bead lock wheel but gave it a try. That’s why I always favored the F5’s and Gen5’s. IMG_3069.jpg
    I went thru stages. Removed the Pro roof rack and added the black rails and then removed them and did smooth top with Eibach springs and 285’s with SCS wheels F5’s.
  12. May 21, 2024 at 3:14 PM
    #72
    I was wondering if the username was a reference, or just a coincidence.
  13. May 21, 2024 at 5:25 PM
    #73
    If you have your heart set on big tires, consider a Jeep.
  14. May 21, 2024 at 5:26 PM
    #74
    FourT6and2
    I'm curious what you consider big tires.
