djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Jan 31, 2025 at 6:17 PM
    #241
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    the rain returned today with a vengence
  2. Feb 2, 2025 at 5:28 PM
    #242
    first snow, & joyride this winter
  3. Feb 2, 2025 at 7:12 PM
    #243
    scottiezilla
    scottiezilla New Member
    What the malarkey?…how are the Canadians getting snow after Alabama?!?!?
  4. Feb 2, 2025 at 9:13 PM
    #244
    I have no idea, it’s a weird one this year. Weather ebb’s and flows over the decades
  5. Feb 2, 2025 at 9:17 PM
    #245
  6. Feb 3, 2025 at 7:15 PM
    #246
  7. Feb 5, 2025 at 12:09 PM
    #247
  8. Feb 14, 2025 at 10:47 PM
    #248
    cleaned valance w/ soap & water.
    dried inside house.
    bought proper flat black primer at Walmart.
    ..and eggos and diapers, and beer
    might prime tnite.
    Thacrow likes this.
  9. Feb 15, 2025 at 12:26 AM
    #249
    front valance primer coats done
  10. Feb 19, 2025 at 7:13 PM
    #250
    TOYOTA Things That I Like
    this week:
  11. Feb 24, 2025 at 12:06 PM
    #251
    over the weekend:
    4R passed front end inspection at the suspension shop. UCA’s r next week
    they posted it on social media.
    my boys and I painted my front valance with 1K Raptor Liner.
    Photon_Chaser likes this.
  12. Feb 24, 2025 at 5:36 PM
    #252
    scottiezilla
    Now I can’t remember dude
    Is there any of the rear valance left anymore?
    Or were you able to just remove it n do those cuts?
    This feels like something I was supposed to do(your bumper mod) last night in a few minutes time haha
    kinda excited to play with the butt as well till I pick up a rear bumper
  13. Feb 24, 2025 at 6:33 PM
    #253
    Yo buddy, good question(s). So I did not cut the rear valance, it got left whole, but it must be removed before cutting bumper cover.
    The cutline follows the top edge of the holes that are in the bumper for the valance clips to attach to
  14. Feb 26, 2025 at 6:04 PM
    #254
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Probably the best beer ever. Go Liverpool
  15. Feb 26, 2025 at 6:27 PM
    #255
    Right!? Yeah dude
  16. Feb 26, 2025 at 6:28 PM
    #256
  17. Feb 26, 2025 at 6:32 PM
    #257
    FN2187
    FN2187 Stormtrooper
    Earth
    The basements a work-in-progress but I'm setting up shop as well. Even painted the walls with a bit of red
    djwantke[QUOTED][OP] likes this.
  18. Feb 26, 2025 at 6:33 PM
    #258
    scottiezilla
    Dude movie theater
    WHO ARE YOU?!?!?!?
    side note:
    n a trampoline!
  19. Feb 26, 2025 at 6:38 PM
    #259
    FN2187
    FN2187 Stormtrooper
    Earth
    In all fairness, the trampoline isn't mine
    BassAckwards likes this.
  20. Feb 26, 2025 at 6:40 PM
    #260
  21. Feb 26, 2025 at 6:48 PM
    #261
    scottiezilla
    Of course it isn’t
    DIBS
  22. Feb 26, 2025 at 6:56 PM
    #262
    FN2187
    FN2187 Stormtrooper
    Earth
    Nice thread you have going BTW @djwantke, you've inspired me to actually take photos and contribute to the forum when the ROF tire carrier comes in and when I get around to installing the ARB diff breather kit and blue sea systems cutoff switch for the winch. I tend to use the forum for a bit of grab assery and fun rather than being a good contributer
    djwantke[OP] likes this.
  23. Feb 26, 2025 at 7:26 PM
    #263
    scottiezilla
    I concur @djwantke
    Paving roads here
    Much appreciated
    side note:
    But we all know this is reeeally @FN2187 ’s n my thread now…muuuhahaha
  24. Feb 26, 2025 at 10:15 PM
    #264
  25. Feb 26, 2025 at 10:17 PM
    #265
  26. Feb 27, 2025 at 11:56 PM
    #266
    as clean as she gets right here, post wash.
    Raptor liner held up beautifully.
    deep cleaned the wheels with shammy’s till my fingers hurt to an adequate degree. just sat on the curb tnite with a work light like a weirdo.
  27. Mar 1, 2025 at 4:07 PM
    #267
    happy 4th birthday to my oldest
    drove the 4R and the Jeep to the in-law property for a party with both sides of the fam
    scottiezilla likes this.
  28. Mar 2, 2025 at 1:57 PM
    #268
    travelled to the mountains at Pitt Lake, w/ the wife & kids for the first time. this is the same area I use to engage 4wd a bit - we did that together too. boys got to see a pretty neat, blue jet boat do his thing too.
    then we drove south the quaint Osprey Village, walked Trans Canada Trail at Shoreline Park Fraser River. 5500 steps today.
  29. Mar 2, 2025 at 5:18 PM
    #269
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    dude that rain pic is bad ass
    Photon_Chaser and scottiezilla like this.
  30. Mar 2, 2025 at 5:27 PM
    #270
    scottiezilla
    Gotta love Canada
    “Eh it’s still the dead of winter…let’s go out on the water n sing kumbaya!”
    sweet trip dude
    Think my 4 day is an all clear all go
    Gotta check with @FN2187 if he or anyone is still game for the park
    side note:
    No Canadians were harmed in the production of this post…
