djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Dec 11, 2024 at 7:47 AM
    #211
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Looks great. You have the clearance now.. and room for a custom rear bash bar with side hoops :cool:
    captrussia253 and djwantke[OP] like this.
  2. Dec 11, 2024 at 4:58 PM
    #212
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Exactly! Side hoops would be rad
    I’m no welder tho…yet lol. I’ll likely use someone here on the coast
  3. Dec 16, 2024 at 6:49 PM
    #213
    Sunday
    filled gas tank.
    drove family in 4R our favorite park on Alouette River that just reopened after renovation. mom treated the boys to nugget happymeals.
    outside garage I drilled & chopped brackets for rear LED pods. now they don’t stick out a lot.
    completed the look I was going for.
    captrussia253 and Thacrow like this.
  4. Dec 17, 2024 at 12:15 PM
    #214
    I didn’t notice the “bootiepic” reference last time :laugh:
    Finished nightshifts last night, got to take a daylight photo this morn.
    captrussia253 likes this.
  5. Dec 17, 2024 at 7:33 PM
    #215
    scottiezilla
    scottiezilla New Member
    DUUUDE
    Haha I was gonna say something like
    Well folks he’s at it again…pictures of DarkAssCanada
    That looks great, can really see the clearance as well…throw that DOM on there or not(we know it’s coming), looks “finished” with the lights up
    Excited to see next step
  6. Dec 19, 2024 at 9:19 PM
    #216
    LOL I woulda had it coming!
    My bad, Canada is dreary and dark af in winter.
    Thanks bud
    :cheers:
  7. Dec 19, 2024 at 9:21 PM
    #217
    Late night grocery shop after bedtime for children’s food, and crucial items for dad: eggs, bacon, hashbrowns, eggos
  8. Dec 19, 2024 at 9:23 PM
    #218
    more crucial supplies:
  9. Dec 20, 2024 at 12:24 AM
    #219
    •removed 5 decals from skid wind guard
    •made a mistake installing ARB skid kit, re-added spacers where I had forgotten
    •cleaned off-road light lenses
    •jammed to Metallica
  10. Dec 20, 2024 at 7:20 AM
    #220
    scottiezilla
    THIS would be a good thread!
    “What couldn’t wait till tomorrow…”
    That amount of crap I get in the last minutes before closing is beyond me…I’m not that guy but based on schedules n ideas…necessary haha
    djwantke[QUOTED][OP] likes this.
  11. Dec 20, 2024 at 4:25 PM
    #221
    Dude right!? Haha
    I was the last guy in No Frills, and Walmart was closing within the hour.
    And now it’s almost time for me to start my yearly last minute manly Christmas shopping
  12. Dec 20, 2024 at 11:39 PM
    #222
    broke the set of Christmas lights on the 4R Garage again :facepalm:
    100% my wife’s face when lights go on tmro
  13. Dec 25, 2024 at 8:54 AM
    #223
  14. Dec 27, 2024 at 12:51 PM
    #224
    removed and stored hitch assembly.
    gained 3” clearance.
    *edit: that exhaust pipe will likely get crushed, I know! If I chop I worry about drawing attention from law enforcement and border guards, possible VI
    day
    night
  15. Jan 3, 2025 at 9:28 AM
    #225
    my work van was Found On Road Dead this morning
  16. Jan 6, 2025 at 8:41 AM
    #226
    captrussia253
    captrussia253 New Member
    Ruslan
    Chop the exhaust behind the axle. I've done the same to my GX and Tundra and never had any issues with law enforcement.
  17. Jan 6, 2025 at 9:30 AM
    #227
    Understood! Much thanks
    You or anyone got photos exactly where behind axle..and what blade type/tool
  18. Jan 6, 2025 at 11:19 AM
    #228
    captrussia253
    Ruslan
    I used a sawzall. (not my picture, googled it)
    djwantke[OP] likes this.
  19. Jan 9, 2025 at 3:29 PM
    #229
    I used a sawzall all on mine too, in visitor parking lol. Took me bloody forever cuz out was a dinky little 12v. I wonder what tool would be better
    captrussia253[QUOTED] likes this.
  20. Jan 9, 2025 at 4:35 PM
    #230
    captrussia253
    Ruslan
    I had no problem with mine. Took maybe a minute.
  21. Jan 9, 2025 at 5:43 PM
    #231
    I should just do the 18-21v or buy a corded.
  22. Jan 11, 2025 at 4:52 PM
    #232
    washed the runner, bigly.
    drove it to the liquor store for white wine & beer for the wife and I plus bought our BC legal greens
  23. Jan 11, 2025 at 5:41 PM
    #233
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Nice job on the high and tight rear. Also recommended for haircuts, wives, and girlfriends
  24. Jan 12, 2025 at 12:12 PM
    #234
    wanted to get outta the house, did a little garage shopping, need CRC throttle body cleaner next time
  25. Jan 12, 2025 at 2:24 PM
    #235
    drove 4R to the in-laws for the kids and cousins to play around. walked 3kms to Whonnock Lake too
  26. Jan 13, 2025 at 1:04 PM
    #236
  27. Jan 18, 2025 at 11:22 AM
    #237
    recent toyota content I really like
  28. Jan 18, 2025 at 4:50 PM
    #238
    I said I was gunna chop it
    1SilverRunner likes this.
  29. Jan 19, 2025 at 8:44 PM
    #239
    favorites from this weekend
  30. Jan 26, 2025 at 9:43 AM
    #240
    before & after
    scottiezilla likes this.
