djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Oct 28, 2024 at 9:26 AM
    #181
    captrussia253
    captrussia253 New Member
    Ruslan
    Having two Toyota's is nice but it's getting expensive. My wife's 4runners sliders and tire carrier come in this week and I just picked up a slightly used set of Icon 2.5 coilovers for it. Her build is keeping me from working on the Tundra :annoyed:
    djwantke[OP] likes this.
  2. Oct 28, 2024 at 3:56 PM
    #182
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    You gotta mount fake crows to your roof @Thacrow :laugh:
    This dude also had a skeleton on his taco grill and skulls mounted as ditch lights
    scottiezilla and Thacrow like this.
  3. Oct 28, 2024 at 5:30 PM
    #183
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I wish I could like your post more than once. Thats brilliant.
  4. Nov 3, 2024 at 4:15 PM
    #184
    me next to a train
    Thacrow likes this.
  5. Nov 7, 2024 at 9:50 PM
    #185
    Dabigono likes this.
  6. Nov 10, 2024 at 4:00 PM
    #186
  7. Nov 12, 2024 at 3:41 PM
    #187
    slapped on some thermo-plastic mudflaps yesterday from my autoparts store, fire sale $19.99cad (12”x25”)
    I’m an irritable person - it was so frustrating in the rain, but it’s raining every day for eight months out of the year :canada:
    I have 12” metal and poly KickBack flaps from Action Car & Truck I ran for a while, almost like these better tho.
    Look at my gorgeous LT285/70 Kumho spare under there :D
    Who names a tire Kum-ho
    Thacrow likes this.
  8. Nov 17, 2024 at 4:18 PM
    #188
    thumbnails I like
    captrussia253 and Dabigono like this.
  9. Nov 17, 2024 at 8:20 PM
    #189
    scottiezilla
    scottiezilla New Member
    I dunno man…
    With all those leaves you should probably go hijack a self serve wash n bang some metal
    side note:
    Sure it’s been asked n sure they’re new…almost bought a set of those tires that came with some wheels down here…they are the mix/hybrid terrains? N if you like em thus far?
  10. Nov 23, 2024 at 12:27 PM
    #190
  11. Nov 25, 2024 at 1:44 PM
    #191
    home office view. front row spot
    watching over her like a bird
    new profile pic lol
    captrussia253 likes this.
  12. Nov 25, 2024 at 2:24 PM
    #192
    Photon_Chaser 52,536 and counting…
    Up, down and all around!
    They look ready for some mud!
    djwantke[QUOTED][OP] likes this.
  13. Nov 30, 2024 at 2:53 PM
    #193
    pondering chopping 4R things again, thinking it over with a beer
  14. Nov 30, 2024 at 3:54 PM
    #194
    I know I've seen that tube style before....I think it was some fellow down in the Los Angeles area whom makes it. See if I can remember who that was.
  15. Dec 1, 2024 at 6:57 AM
    #195
    Ah, my bad. I was confusing with a different manufacturer but Nguyen Works has a very thin design that you could use as a guide?
  16. Dec 9, 2024 at 11:55 AM
    #196
    newest work on the build.
    rear bumper cover “clearance chop”
    (future: dom tubing weld work)
  17. Dec 9, 2024 at 12:35 PM
    #197
    scottiezilla
    Was gonna ask for a proper bootiepic in the other thread…throw some daylight on that thang
    Feel like this gonna turn out great…n become the next big “how-to?” coming your way from the masses
    Gonna move the lights up? Maybe a tab on top the DOM
    Plans for the spare?
    djwantke[OP] and Thacrow like this.
  18. Dec 9, 2024 at 1:17 PM
    #198
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That's my biggest question here. I think it looks great and I applaud the balls it too to cut. I really want to know how it was done. I hope there are more pics.
  19. Dec 9, 2024 at 1:29 PM
    #199
    Great craftsmanship and figuring out how to do this! I agree, big Kahunas cutting, well done! :yes:
  20. Dec 9, 2024 at 11:03 PM
    #200
    Photon_Chaser and Thacrow like this.
  21. Dec 10, 2024 at 12:43 PM
    #201
    captrussia253
    Ruslan
    Looks good. Nicely done. I did the same to my GX but now considering doing the same to the 4runner.
    Thacrow and djwantke[QUOTED][OP] like this.
  22. Dec 10, 2024 at 2:28 PM
    #202
    That’s right, yeah man I remember. I’ve been brainstorming ever since, thx for inspiration
  23. Dec 10, 2024 at 4:20 PM
    #203
    1. little bit brighter photos attached below
    2. I like that idea of moving lights up, a tab on the DOM would be smart ya cuz there not much else
    3. Plan for spare: I like maybe the rigid ultraswing tire carrier to get wheel out from under there on trips
  24. Dec 10, 2024 at 5:07 PM
    #204
    @scottiezilla scratch that rig’d ultraswing is like $2300 haha nope
    captrussia253 and Thacrow like this.
  25. Dec 10, 2024 at 6:54 PM
    #205
    captrussia253
    Ruslan
    Way too much!
  26. Dec 10, 2024 at 7:03 PM
    #206
    captrussia253
    Ruslan
    For sure. Love a good high clearance rear. I don’t mess around haha.
  27. Dec 10, 2024 at 7:05 PM
    #207
    Guide:
    Rear bumper cover “clearance chop”
    2016 ORP
    >This cut likely precedes dom tubing weld work
    >To get out ahead of that did the bumper cover cut myself, so I’m to blame if it’s janky
    >Note:
    rear bumper cover was already was painted black on lower portion in a separate project.
    factory rear mudguards previously cut off with a reciprocating saw.
    1. YouTube how to remove bumper cover and do that. Unclip the valance easily from backside.
    Mask off and then spray out flat black the lower half of the newly exposed painted metal that lies behind the rear wheels, and under hatch a bit.
    Spray inner foam piece flat black. Add a couple 3M Velcro strips between foam and crossmember.
    *I bent undercarriage fastening brackets UP with a rubber mallet, since they ain’t doing anything no more.
    2. Tape off a straight line on bumper cover using masking tape, starting just under the third fastener from the seam with the body (12” down from seam), and line that mark up with the top edge of all the valance clip fastener slots in bumper cover. (If you don’t have valance trim, the cut is 1-3/4“ down from top surface of bumper cover step).
    For the fender liner behind wheel, cut it in a straight line across starting from your cut line that’s just under third fastener from seam (12” down from seam)
    3. Trace top edge of the masking tape with a dry erase marker. Remove tape and fix your cut line where needed. I tried to stay parallel with the horizontal bumper/body seam.
    4. Fasten bumper cover upside down, to some kind of table or platform, using screws through inconspicuous existing holes.
    5. Wear eye & ear protection. Cut your line with a corded Dremel tool, recommend cutoff wheel No. 409. I broke like 4 of ‘em. Let the melted plastic pelt your face!
    6. Peel what you can off cut edge by hand. Sand edge quickly w/ 120grit, I used a corded multitool.
    7. Reinstall bumper cover.
    8. Install black automotive edge trim w/ heat gun, especially if you’re below 18°C/65°F. I bought at Canadian Tire.
    Sink a self tapping screw through fender liner into a metal bracket area behind it, between the second and third fastener down from seam.
    Extra angles:
  28. Dec 10, 2024 at 7:26 PM
    #208
  29. Dec 11, 2024 at 7:15 AM
    #209
    captrussia253
    Ruslan
    Nicely done!
  30. Dec 11, 2024 at 7:31 AM
    #210
    Only thing left to do is to cut off that rear crossmember at the rear body mount and move it upwards…add a couple of flanges and gussets to reinforce.
    Come on Dj, let’s see some welding skills!
    djwantke[OP] and captrussia253 like this.
