djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Aug 18, 2024 at 7:47 AM
    #151
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Ahh is that right eh. Nice, ya I had my off-road shop cut a similar sliver off the bottom of front fender in front of tire, it rubbed there at full lock reverse. And took front mud guards off for good measure. Keep in mind, I went with 9” wide wheels tho.
    I think I wouldn’t worry about the pinch/dent you have, probably looks much better than some guys fender liners that that have seen too much heat gun.
    I’ve gone a lot crazier with the cutting and chopping since the off-road shop started it, but over all I would definitely recommend the viper cut, have fun and go for it - these bumper covers aren’t forever!:p
    Advice; I would have cut more moderate if I could do it over, and don’t cut too big of a weird curve at the bottom on each side.
    Bend_4R[QUOTED] likes this.
  2. Aug 18, 2024 at 8:05 AM
    #152
    Bend_4R
    Bend_4R New Member
    I have definitely been looking at very modest cuts. This one looks good to me:
  3. Aug 18, 2024 at 9:03 AM
    #153
    This one does this good to me as well, good height and the right side cut looks perfect. I like when folks are able follow the faint body lines down there with their cuts
  4. Aug 18, 2024 at 9:03 AM
    #154
  5. Aug 18, 2024 at 12:57 PM
    #155
    about to dock in Vancouver
    SlvrSlug likes this.
  6. Aug 18, 2024 at 4:24 PM
    #156
    Bend_4R
    Bend_4R New Member
    I had everything mocked up with blue tape and even plugged in my cutting tool! But I "pulled the plug" and decided to wait until the window washer reservoir cover and trim arrive. Now, I have time to fine-tune how I want to trim the bumper. What I mocked up was more modest than the picture I attached, but came in on the side in a similar point. I was planning to cut below the tape in these pictures.
  7. Sep 1, 2024 at 1:24 PM
    #157
  8. Sep 1, 2024 at 5:06 PM
    #158
    Oof
    scottiezilla likes this.
  9. Sep 4, 2024 at 2:37 PM
    #159
    Harringbr99
    Harringbr99 New Member
    Brian
    Kentucky
    2021 Barcelona Red Limited
    I really need to get this mod done. I like the look on the outside!
    Need to figure a good way to make it work with the access hole I have cut for my Winch though. Maybe ill cut a small flap using zip ties as hinges. and can use a small ABUS padlock to secure it.
    djwantke[QUOTED][OP] likes this.
  10. Sep 4, 2024 at 2:41 PM
    #160
    Harringbr99
    Brian
    Kentucky
    Every time I see the shots of BC I fall in love, I've got to make a trip up there one of these times!
  11. Sep 4, 2024 at 5:02 PM
    #161
    Yeah man f*ckin pricey but heck of beautiful place!
  12. Sep 4, 2024 at 5:03 PM
    #162
    Bend_4R
    Bend_4R New Member
    BC stands for "Bring Cash," right?
  13. Sep 4, 2024 at 5:12 PM
    #163
    :laugh: 100%
    Highest priced everything, we win
  14. Sep 4, 2024 at 5:17 PM
    #164
    Bend_4R
    Bend_4R New Member
    I spent quite a bit of time in Western BC and Whistler. After every trip, the credit card statement floored me!
  15. Sep 6, 2024 at 11:07 AM
    #165
    Chemical Guys tire conditioner lasting longer already than competitors
  16. Sep 8, 2024 at 9:41 AM
    #166
    Drove fam in 4R to brother-in-laws property for his birthday, and steaks. kids got to see grandpa in the digger
  17. Sep 8, 2024 at 9:48 AM
    #167
    Oops my old UCA grease gun is leaking :eek:
  18. Sep 8, 2024 at 10:56 AM
    #168
    ..put a diaper on it for now:laugh:
    captrussia253 likes this.
  19. Sep 13, 2024 at 8:19 AM
    #169
    Buying myself a Toyota stealership oil change for the first time since 2017, for my 36th birthday today.
    photo of my 4R for reference :laugh:
  20. Sep 25, 2024 at 5:20 PM
    #170
    forced tonight to park the runner on the street with all the less cool vehicles and smelly Walmart shopper people :laugh:
    My wife’s Jeep took the garage cuz the sunroof drains may be plugged or worse - it leaked out the front dome light in a storm :laughing:
  21. Sep 25, 2024 at 5:30 PM
    #171
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That poor 4Runner. Out there amongst the peasants. I hope it gets it's room back soon.
  22. Sep 26, 2024 at 9:00 AM
    #172
    :pout:
    Thacrow likes this.
  23. Sep 26, 2024 at 10:51 AM
    #173
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just imagine how she feels. Out there in the cold
  24. Sep 26, 2024 at 11:31 AM
    #174
    MisterFlabby
    MisterFlabby Certified Dumbass
    Matthew
    Ontario, Canada
    2024 Underground 4Runner SR5
    Father… Please… I crave mud…
    wildgoose likes this.
  25. Sep 26, 2024 at 11:52 AM
    #175
    HAH
    that’s funny
    Soon I risk angering the toyota gods, I can’t let my jeep be cursed.
  26. Sep 26, 2024 at 6:28 PM
    #176
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I'm sure mine feels the same way. Between working from home and always somehow busy on the weekends, mine spends a lot of time in the driveway.
    Worst part is, because I broke the bank getting her almost exactly as I want, she doesn't even get much mod attention anymore...
    Thacrow[QUOTED] likes this.
  27. Oct 4, 2024 at 6:19 PM
    #177
    POR15 on my necklace from a year ago
    (the letter E)
    POR15 on my frame from two years ago
    captrussia253 and SlvrSlug like this.
  28. Oct 25, 2024 at 9:38 PM
    #178
    look at them sliders in the moonlight
  29. Oct 27, 2024 at 4:13 PM
    #179
    picked up a couple essentials on sale w/ the 4R.
  30. Oct 27, 2024 at 8:19 PM
    #180
    I wish I had an old gen too. I envy the dudes with two Toyotas
