djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Aug 7, 2023 at 3:20 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    my front stoop
  2. Aug 26, 2023 at 4:57 PM
    My in-laws just finished building their new shop / house on 10 acres! Matches the Wantke Runner
    Dabigono, captrussia253 and 2Toys like this.
  3. Aug 26, 2023 at 6:29 PM
    Congratulations, Nice!
    djwantke[OP] likes this.
  4. Aug 26, 2023 at 6:31 PM
    Remington Rocks in the States!
    djwantke[QUOTED][OP] likes this.
  5. Sep 3, 2023 at 10:25 AM
    Rounded up the kiddos, hittin' the hwy to the PNE exhibit fair.
    Visual inspection, Cold tire pressure ✓, Balljoint grease top up
  6. Sep 3, 2023 at 12:04 PM
    headliner addition
    SlvrSlug and Dabigono like this.
  7. Sep 3, 2023 at 3:29 PM
    2Toys likes this.
  8. Sep 9, 2023 at 2:57 PM
    Meguiar's for you, beer for me
    captrussia253 likes this.
  9. Sep 9, 2023 at 3:16 PM
    Mickey's on Mickey's
  10. Sep 9, 2023 at 4:26 PM
    favourite hat
    Latrans and captrussia253 like this.
  11. Sep 17, 2023 at 3:15 PM
    Polished the rears, like the fronts
    New maintenance products to 4R garage shelves
    New garage metal signs
    Additional wood to the stack like a hoarder.
  12. Sep 23, 2023 at 10:51 AM
    Saturday morn KDSS flexing, found some flat ground to speed up straightening out a little parking lean
  13. Sep 23, 2023 at 11:37 AM
  14. Sep 23, 2023 at 2:14 PM
    por15 metalprep
  15. Oct 6, 2023 at 2:30 PM
    Hitch POR15 dried
    BantamEddy likes this.
  16. Oct 10, 2023 at 2:34 PM
    Rear End POR15 degreaser, step one
  17. Oct 10, 2023 at 2:53 PM
    EZ access
  18. Oct 10, 2023 at 3:18 PM
  19. Oct 13, 2023 at 8:29 AM
    #49
    Beautiful British Columbia, October fall
    2Toys and GtownRunner like this.
  20. Oct 13, 2023 at 11:07 AM
    #50
    I just stand and stare at my 4R, all the time.
  21. Oct 13, 2023 at 4:17 PM
    #51
    So what bumper are you getting here?
  22. Oct 13, 2023 at 6:11 PM
    #52
    So unfortunately I don't have $2000-$3000 specifically saved up yet for the steel rear bumper, but I will be purchasing one with tire carrier and more importantly to me - the style that has side round bars (that look like kettle bell handles).
    So for now after I've rust cured and painted the rear end (frame, sway bar/pan hard, and axle & diff), the stock bumper goes back on
  23. Oct 15, 2023 at 3:25 PM
    #53
  24. Oct 15, 2023 at 3:51 PM
    #54
    Dabigono likes this.
  25. Oct 16, 2023 at 11:52 PM
    #55
    bam
    Trail Runnah and Dabigono like this.
  26. Oct 17, 2023 at 3:45 AM
    #56
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Are you trying to advertise a "side hustle"? looks great man. You have a lot more patience than I.
  27. Oct 17, 2023 at 2:55 PM
    #57
    @dgrenier15 hah! You know I really should do 4Runner side jobs. Thanks dude. I've never had a garage till this house, so I'm happier than a pig in shit doing mods and maintenance combined with a little drink, maybe a little smoke
    Trail Runnah and dgrenier15 like this.
  28. Oct 18, 2023 at 3:08 PM
    #58
  29. Oct 18, 2023 at 3:30 PM
    #59
    I agree with my man @BgBmBoo
    Giving rearward cross a go, manual be damned it's fine bro
    2Toys likes this.
  30. Oct 18, 2023 at 3:51 PM
    #60
    helping dad with his trusty monkey wrench
    raimieb likes this.
