djwantke 2016 White Trail build and travels
Discussion in '5th Gen Builds (2010-2024)' started by djwantke, Mar 27, 2023.
  1. Mar 2, 2025 at 8:29 PM
    #271
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Sunday night
    cleaned the days dirt ^
    cooking ^
    social media trucks of the day^
  2. Mar 3, 2025 at 11:36 AM
    #272
    That Sequoia looks nice. I would like to find a low mileage 2nd gen.
    djwantke[QUOTED][OP] likes this.
  3. Mar 3, 2025 at 12:01 PM
    #273
    Right!? Ya I could tell this dude is legit from the roof rack accessories
  4. Mar 3, 2025 at 12:07 PM
    #274
    Both Starlink and Weboost up there.
  5. Mar 5, 2025 at 7:30 AM
    #275
    Jalito
    Jalito New Member
    Justin
    2024 White TRD Pro
    Niceee
  6. Mar 6, 2025 at 7:53 PM
    #276
  7. Mar 8, 2025 at 5:16 PM
    #277
  8. Mar 8, 2025 at 7:10 PM
    #278
  9. Mar 9, 2025 at 3:02 PM
    #279
    lifted up the rake
    so much better, almost equal distance above wheel.
    before
    after:
  10. Mar 11, 2025 at 12:21 PM
    #280
    trucks I like this week.
  11. Mar 11, 2025 at 6:54 PM
    #281
    4Runner today: picked up my beautiful children from childcare
    Loaded up on meat together at the Butcher Shop.
    Raced a train on the way home. It was a tie.
  12. Mar 12, 2025 at 9:44 AM
    #282
    Got the paper work from the 4wd shop, they documented the pre/post ride height measurements for me.
    Pre-Measurement of Vehicle Ride Height Before Raising on the Hoist:
    Left Front: 37.25in
    Right Front:37.25in
    Left Rear:38.75in
    Right Rear:38.75in
    >Coilover Ride Height Adjustment
    Post-Measurement of Vehicle Ride Height After Repairs:
    Left Front: 38in
    Right Front:38in
    Left Rear:38.75in
    Right Rear:38.75in
  13. Mar 14, 2025 at 10:24 PM
    #283
    took a few rocks off the front end, and the windshield took a hit, passing a side by side on the fsr.
    he was flying’ by
  14. Mar 15, 2025 at 2:28 PM
    #284
    took a picture when the hail started
  15. Mar 15, 2025 at 3:41 PM
    #285
  16. Apr 2, 2025 at 6:24 PM
    #286
    filled up gas @ Chevron, price dipped a bit.
    drove family in 4r to the new zip line park, on the Alouette River.
  17. Apr 2, 2025 at 8:19 PM
    #287
    ahead of dry sunny weather in the forecast, contractor just finished re-crowning, grading, and rolling my go-to forest service road to the Stave mud flats. this is lovely.
    scottiezilla likes this.
