DIY 3.5" JL Audio dash speaker upgrade - Wow!
Discussion in 'Audio & Video' started by 57HotrodVW, Oct 24, 2018.
  1. Jul 7, 2021 at 7:59 PM
    #211
    Did you ever change out your dash speakers @glwood54?
  2. Jul 7, 2021 at 10:35 PM
    #212
    Yes I did. Better audio is way down on my list of wants, however - I took the easy road and swapped in the Subaru Kicker tweeters. I didn't feel like fabbing up brackets or trimming the speaker cover. Something to be said for plug-n-play. I'm perfectly happy with the sound.
    Not the most popular mod judging from this thread, but it works for me.
    nimby[QUOTED] likes this.
  3. Jul 8, 2021 at 6:01 AM
    #213
    Thanks. I'm still interested in doing the Infinity Reference swap. Been thinking about tackling it recently.
    Anyone have a recommendation for a soldering iron/gun? There's about a billion on Amazon. Don't want to get something expensive, but I don't want it to be cheap crap either.
  4. Jul 8, 2021 at 10:03 AM
    #214
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    I bought this one from home depot. You'll also have to buy some butane, but this think worked great for getting the capacitors attached. The trickiest part for me was the shrink tubing.
    https://www.homedepot.com/p/Bernzom...e-Rosin-Core-Solder-and-Case-368600/304813553
  5. Jul 8, 2021 at 10:31 AM
    #215
    Cool! Thanks for the link! Never needed a soldering iron before but I use a bernzomatic hand torch at work all the time and it’s been good to me.
    I always have issues with shrink tubing as well. I decided to finally pull the trigger on a heat gun instead of using the lighter method. I think it should go smoother this time around.
    Any comments from anyone on an electrical soldering iron vs a butane one? I’m not planning on assembling circuit boards or anything…..just car audio stuff. Any advantages or disadvantages to either?
  6. Jul 8, 2021 at 11:18 AM
    #216
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    The best soldering iron I have for small jobs like this is from harbor freight. They also sell solder and spring tube so it’s a one stop shop.
    nimby likes this.
  7. Jul 9, 2021 at 6:39 PM
    #217
    Well, I got everything to give this a go. Hopefully I have time this weekend.
    2016 4Runner SR5 likes this.
  8. Jul 9, 2021 at 10:18 PM
    #218
    aroyalsfan
    Kansas City
    Good luck and all in all everything in this thread is fairly easy. The most PITA part of what I did was the sound deadening inside and outside the door. In fact after doing the rear hatch it put so much weight on the door I had to swap out the hydraulic lifters with the ones designed for people putting the ladders on their rear hatch. All in all I'm happy with the Infinity speakers.
    Now all I have left is the Alpine PSU-300FRN subwoofer/amplifier. I'm going to try to do that on Sunday if I can. Supposed to be a 2 hour install but I'm sure I can stretch it out to 8 like I did with the power folding side mirrors mod....which I also highly recommend.
  9. Jul 10, 2021 at 8:07 AM
    #219
    Thanks!
    I've never seen that Alpine set-up before. Sounds like a pretty cool solution. That sub box is tiny.
    Please let us know how the install goes. Really interested to hear your thoughts on how it turns out.
  10. Jul 10, 2021 at 11:05 AM
    #220
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Finally installed my Infinitys in the rear hatch. I followed @aroyalsfan bracket mod and it worked out perfect. Thanks to him for his help along the way also. I didn't go crazy with the killmat but still put some around each speaker. I added some foam too for a tighter fit against the panel. Zero rattles and the speakers sound awesome and clean! Next are the 4 doors..meh..not looking forward to that. Taking the panels off seem like it's going to be a pain.
    4R21, nimby and aroyalsfan like this.
  11. Jul 10, 2021 at 11:24 AM
    #221
    aroyalsfan
    Kansas City
    Glad it worked out. Looks great and I am sure sounds better.
    spyder918[QUOTED] likes this.
  12. Jul 10, 2021 at 7:44 PM
    #222
    Got the capacitors on the wiring harness today.
    I learned that I really suck at soldering.
    That's all I did today as I ran out of time for anything else.
  13. Jul 10, 2021 at 7:49 PM
    #223
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Heat the wire not the solder. As the wire heats, melt the solder into the wire by touching the solder to the wire rather than trying to melt it with the soldering iron.
    SlvrSlug and nimby like this.
  14. Jul 10, 2021 at 8:20 PM
    #224
    Good tip! Thanks!
  15. Jul 11, 2021 at 4:04 PM
    #225
    Alright!
    Got the Infinity Reference 3.5's in and they sound great! Big improvement over stock. Easy install. Amateur tip......remove the bolts securing the speaker to the bracket before removing the screw attaching the bracket to the dash. It'll make things a lot easier on you.
    Cutting the speaker brackets was easy with the right tool. You won't need to use all the pieces you cut from the speaker bracket as one end of the speaker can fit into the existing dash mount hole. I used an orbital sander to bring down the lip on the dash speaker covers. Took about 2 minutes per side using 80 grit.
    Warning for anyone who decides to tackle this mod.....these speakers will make you wonder how much better your stereo will sound if you replaced all the speakers.
    spyder918 and aroyalsfan like this.
  16. Jul 11, 2021 at 7:45 PM
    #226
    aroyalsfan
    Kansas City
    I got the Alpine PSU-300FRN subwoofer/amplifier installed today. Took me about 4 1/2 hours..because well I milk things. I did not take any pictures or write up a tutorial because this involves removing the front seat and placing it in your lawn. So that's a little more detailed than I wanted to get involved. You have to remove everything from the stereo to the center console. You have to cut a hole in the extra rubber nipple in the firewall grommet on the passenger side to fish the power wire through.
    Also if you've done other mod's that involve removing all the kick plate panels and such...this past knowledge comes in handy.
    Cool thing about this set is that everything is plug and play. There is a wired bass level knob. It suggests you mount it outside the center console. I just drilled a hole and put it inside.
    As far as sound....holy cow this made things so much louder. So The max level from stock equals about level 30 on the amp. The max level with all infinity equals about level 40 on the amp. Absolutely no way will I ever take this thing back up to 60+ again. No need to. I am a rock fan so some Boston sounded good. Can't wait to blast some Tool. I turned it over to channel 43 on Sirius to listen to check out the bass level. I was impressed the sub with the 6x9s really kick some bass out. My girlfriend keeps her sunglasses in the passenger door and they were bouncing around.
    Only thing I am wondering is if I already blew the 6.5" infinity speakers before this install or if they don't pair well with this amp. The front 3.5" and 6x9" sound great with it. The back sound fine, but not perfect, a little tinny....if that makes sense. Maybe the speakers all just need a break in period again with this amp. All in all though I am happy with the sub/amp. Crutchfield sells is for $799. Amazon was selling for that price too...for some reason it popped up at $499 right before the 4th. I jumped on it and bought it. The next day it was back up to $799. Sometimes it's worth keeping things in your Amazon list.
    If anyone goes for this unit feel free to hit me up with any questions. I'll help the best I can...I'm no pro though.
    onaquest and nimby[QUOTED] like this.
  17. Sep 10, 2021 at 5:22 AM
    #227
    19TRDPRO4RUNNER
    19TRDPRO4RUNNER New Member
    MO
    19 TRD PRO 4 RUNNER
    I have a 2019 TRD PRO 4RUNNER WITH THE JBL STEREO, will this work or am I going to have a problem? My Tweeter blew out on the passenger side and I want to replace it using this I refuse to give the dealer 300$ for one factory JBL tweeter.
    Any help from anyone would be greatly appreciated.
    Thanks
    4R21 likes this.
  18. Sep 10, 2021 at 12:52 PM
    #228
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    It’ll work but I’m not sure if there’s a plug available. You may have to make something yourself.
  19. Sep 15, 2021 at 5:31 AM
    #229
    JaSC
    JaSC New Member
    Anderson, SC
    Black 2018 4Runner TRD Off Road Premium, crawl control and MTS
    ToyTec Lift, Dual Batt Redarc. Rear safe drawer, console safe, Aux 2004 JGC fuse box, Warn bumper, 12,000lb winch
    Great info on this thread for an old guy like me. Would a speaker upgrade help someone who basically listens to Talk Radio and audio books while driving? The last time I looked at or bought after market speakers was in the mid 1980s. I'm probably not interested in changing out the head unit itself (is that the right term now?), although down the road who knows. Last time I did this was installing a Pioneer Cassette. lol.
  20. Sep 15, 2021 at 5:47 AM
    #230
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Kinda pointless in your situation.
  21. Sep 15, 2021 at 11:25 AM
    #231
    aroyalsfan
    Kansas City
    What's your goal? Sound quality doesn't seem like it would matter with talk radio or audio books.
  22. Sep 15, 2021 at 3:41 PM
    #232
    JaSC
    JaSC New Member
    Anderson, SC
    Sound quality. Many on this thread have posted of improved sound for music listening so I was wondering if upgrades would make a difference. I probably don't need a sub-woofer or extreme loudness, just clarity, clearness, depth.
    To be fair, I do have a 1970-80s CD with different music I listen to sometimes. Old stuff..Judas Priest, Boston, Journey, old country ect.
  23. Sep 15, 2021 at 4:50 PM
    #233
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    You’ll gain sound quality for sure. Not sure how much on an audio book but definitely when it comes to music
  24. Sep 15, 2021 at 8:54 PM
    #234
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    Up grading the speakers makes a big difference, add a little sound deadening and even better.
  25. Sep 16, 2021 at 7:21 AM
    #235
    aroyalsfan
    Kansas City
    In your situation perhaps go with the Subaru tweeters referenced in the main speaker replacement thread already referenced above. They are plug and play. Then replace the 6x9s in the door with a plug and play option from Crutchfield (then search Amazon for lower price), or the Infinity Reference in the same thread. Then be done with it. Don't worry about your sound deadening or the back 4 speakers and sub and amp. You'll be happy with that setup with what you're trying to accomplish.
    JaSC[QUOTED] likes this.
  26. Nov 30, 2021 at 7:47 AM
    #236
    shanemlewis
    shanemlewis New Member
    Shane
    Sarasota, FL
    2016 White 4Runner Limited
    I have a 2016 4Runner Limited with JBL and in the same boat. Could really use some guidance on the how to swap the blown tweeters for something with better sound. So far I haven't found much on the JBL replacement path. I am considering just pulling the trigger on OEM replacements at this point which are $66 each.
  27. Nov 30, 2021 at 8:09 AM
    #237
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Pull the speaker out of the dash, check wiring, wire in a new 3.5” speaker of your choice. There’s nothing special about the factory JBL system.
  28. Mar 3, 2022 at 3:59 PM
    #238
    aroyalsfan
    Kansas City
    Update on the deleted update....Turns out a speaker wire jiggled itself loose. It caused both rear left speakers to stop working. Once reconnected everything was working again. Still worried that I have a couple blown speakers on the right rear side because they were over compensating the entire time. It's either that or something else in the rear tailgate door is vibrating when I am blasting Regulate by Warren G featuring Nate Dogg.
  29. Mar 6, 2022 at 11:13 AM
    #239
    aroyalsfan
    Kansas City
    Okay...so only started messing around with everything because I'll be headed out on a road trip at some point in the future. Now that I've got my speakers working properly again and everything sounding great, I have really notice how bad the stock head unit is...or at least XM radio audio is through the head unit.
    If you have XM radio try using the XM app through Bluetooth. It sounds 10 times better through the app.
  30. Apr 13, 2022 at 1:17 AM
    #240
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Do you think the 3.5 dash and quality coax front speaker is a better setup opposed to something like the discontinued focal is690toy or other comparable component setup?
