DIY 3.5" JL Audio dash speaker upgrade - Wow!
Discussion in 'Audio & Video' started by 57HotrodVW, Oct 24, 2018.
  1. Mar 17, 2019 at 6:42 PM
    57HotrodVW
    57HotrodVW [OP] New Member
    Eric
    '18 Cavalry Blue TRD Pro
    Just the addition of 3.5" dash speakers makes a huge difference. I purchased some RAAMmat (not installed yet), but I've heard that putting sound deadening material in the doors makes the factory speakers sound much better.
    You might start with those two mods, and then decide if you want to upgrade the door speakers too.
    Strandskov likes this.
  2. Mar 18, 2019 at 8:03 AM
    JWG
    JWG New Member
    2015 White 4Runner SR5 Preminum
    None
    Yea I saw another post about using the sound deadening mat. Any advice on the thickness of the mat?
  3. Mar 18, 2019 at 8:54 AM
    57HotrodVW
    Eric
    This is the stuff that I have (you can buy individual sheets too):
    http://www.raamaudio.com/raammat-bx...riod-please-click-to-see-product-description/
    "Perfect amount for a basic but very effective install in most vehicles, you can double the results by adding 3 yards of PS Ensolite!
    37.5 sq ft per box flat pack box, 20 sheets, 11x23", more coverage than our competitors "comparable" products.
    Butyl based formula specifically engineered to compete with the top notch expensive brands.
    Peal and stick for easy application, conforms well, stays put.
    60 mils thick (.060" and .52lbs per sq ft, check the weight/thickness/cost of the other products on the market. It is the correct balance to get the job done as needed.
    4 mil soft aluminum finish (softer aluminum to help prevent cuts while installing, hard aluminum like others use has been known to cause serious lacerations.)
    250 degree temp rating (any higher rating is a moot point, the vehicle would already be on fire so we shoot for realistic numbers and spend our resources on making the performance better instead."
  4. Mar 18, 2019 at 2:00 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    If you're going to deaden, do it right. If you just use little pieces here and there you're really just wasting your money. Been doing this for 20 years, take my word for it. It's a lot of work and takes a lot of time to do correctly but it is absolutely worth it. You want to do inner door skin and outer door skin. Basically seal the inner door skin that has a bunch of holes in it. I will post pictures of my doors later on today.
  5. Mar 18, 2019 at 4:31 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    And more to come.
    Lucky Jack and (deleted member) like this.
  6. Mar 18, 2019 at 5:42 PM
    JWG
    JWG New Member
    None
    I was originally thinking of just doing the outer door skins. Sealing both the inner and outer makes sense as long as you already have the door panels off. I would be interested in how much deadening material you use total. I was thinking of using the Raammat like Eric is using. Any thoughts on the different materials? Also what speakers are you using in your rear hatch?
  7. Mar 18, 2019 at 5:45 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    I don't personally have experience with that product so I can't say. I've used about 150 square feet so far. Rear hatch speakers are high end Hertz speakers. HCX 165 is the model number. If you go with these, you absolutely need an amp. The stock stereo is not even close to enough power to drive them.
  8. Mar 19, 2019 at 11:17 AM
    JWG
    JWG New Member
    None
    Thanks
  9. Mar 20, 2019 at 4:39 PM
    JWG
    JWG New Member
    None
    Chris, did you use the existing bracket on the right side and the fabricated one on the left with the JBLs or fabricated ones on both sides?
  10. Mar 20, 2019 at 6:12 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Fabricated a tab on each side. Just used back strap, the stuff every car audio shop has. Just basically flat metal with a bunch of holes in it which has many uses. One tab on the speaker lines right up, the other needed the bracket. Was able to reuse both original bolts and speed clips as well.
  11. Mar 23, 2019 at 4:33 PM
    JWG
    JWG New Member
    None
    Speaker installation complete. I made the brackets like Eric did and I used the Taco Tunes adapter harnesses as well. I wanted to keep the original speakers in case I needed to reinstall them. I used the JBL GTO 329 speakers, like Chris, and shaved 1/4" the lip off using a dremel tool and shaved off all of the lip on the plastic speaker grill. All in all it took patience and finesse to get the job done. Thanks for all the pictures and instructions.
    Next project is deadening using the Raammat like Eric.
    Lucky Jack and 2016 4Runner SR5 like this.
  12. Mar 23, 2019 at 5:36 PM
    akkording
    akkording New Member
    HTX
    2012 blizzard pearl sr5 4x4, 03 Tacoma sr5 dcsb v6
    Did the gto 329 come with bass blockers?
    My jbl club 3020 included 270 mhz capacitors but I didn't notice them taped tucked under the styrofoam packaging and I just solder on 14 uf capacitors which was recommended for 3.5" to 4" speakers.
  13. Mar 23, 2019 at 5:52 PM
    Charlievee
    Charlievee Not new member.
    Every weekend, i see this thread. Every weekend i put all the items in to carts and never purchase. Call me a cheap skate, but is it that big of a difference? When i first picked up my TuRD, the sound realy bothered me (way to much base). But after adjusting the settings and over time its not that bad. Granted im old and have been blown...up a few times, so my hearing is not as it once was.
  14. Mar 23, 2019 at 8:43 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    It's a significant difference and yes the GTO series comes with a 150UF cap
  15. Mar 24, 2019 at 12:49 PM
    JWG
    JWG New Member
    None
    As Chris said the GTOs come with 150uF caps they will be taped to the side of the styrofoam packaging. The speakers are much clearer or transparent for the vocals and instruments.
    2016 4Runner SR5 likes this.
  16. Mar 25, 2019 at 2:15 PM
    Charlievee
    Pulled the trigger. If this leads me to changing every speaker and getting one of those techno wizbang headunits with millions of useless features... I'm blaming you guys!
  17. Mar 25, 2019 at 3:07 PM
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Dash speaker upgrade makes a bigger difference than any other speaker upgrade in these trucks. The stock speakers aren't bad, there is just a HUGE gap in response between the doors and dash. The 3.5 coax solves that problem.
    Lucky Jack likes this.
  18. Apr 3, 2019 at 2:42 PM
    Charlievee
    So finally got the speakers in this afternoon. Took me longer to dig out the tools needed, than to do the install. About 30 minutes of bench work soldering the new connections and maybe 20 to pull the old, fab the mounting brackets using the stock ones. Thing is... I did not have to mod my speaker covers. They snapped right in place like the tupaware that they are. Sounds much better, still need to play with the equalizer options a bit.
  19. Apr 3, 2019 at 4:24 PM
    #49
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Would be wise to remove the cone on the bottom of the grills. If that plastic cone is touching the speaker cone, they won't last long.
  20. Apr 3, 2019 at 4:43 PM
    #50
    Charlievee
    I guess I'll cut them on the morrow. The more I do on this station wagon the more dissatisfied i get. So much plastic, like a snap together model. For the price, I think I could have done much better.
  21. Apr 3, 2019 at 5:01 PM
    #51
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Ever work on a Ferrari, Mercedes, any other high end car? I have, lots of plastic. You won't find anything new on the market today even close to this price range that isn't all plastic. Only cars I've ever worked on with real wood panels were old Mercedes and Rolls Royce. Of course old cars from the early 90s and back had some metal panels. You want to talk about fun to work on and figure out the puzzle lol.
  22. Apr 3, 2019 at 5:09 PM
    #52
    Charlievee
    I put the Dermal to it.
  23. Apr 3, 2019 at 5:15 PM
    #53
    Charlievee
    Well, I gave up my 96 Bronco for the TRuD. I'm thinking I should have stuck to build not buy method. To think what 30 grand (LOW ball for a TRD off road premium, plus finance) would do for a 6 grand rust free Cali truck. Oh well, check the box to another life choice i get to second guess for a decade or two.
  24. Apr 3, 2019 at 6:50 PM
    #54
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    If it wasn't for fords our tools would rust. You made the right choice. Although if you hate the 4R that much, sell it and buy another bronco.
  25. May 23, 2019 at 8:04 AM
    #55
    Jagamov
    Jagamov New Member
    2019 4Runner Limited Nightshade
    Big edit:
    Apparently (and this is on me too) the JBL system in the Limited is totally different. Different speaker and a completely different connector.
    So at this point I’ll be sticking with the stock speakers since I didn’t want to tear apart the stock connector and the JBL speaker in the car didn’t seem too bad.
    Kudos to Crutchfield for being so easy to work with.
  26. Jun 6, 2019 at 6:47 AM
    #56
    Jagamov
    Jagamov New Member
    BTW, if anyone wants the Taco Tunes adapters, I’ll ship em super cheap. They’ve been cut down to about 6 inches.
  27. Jul 8, 2019 at 3:47 PM
    #57
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    #57
  28. Jul 9, 2019 at 7:11 AM
    #58
    Andason74
    Andason74 New Member
    Ebay ad indicates tacoma, does this fit 4runner 2019?
    #58
  29. Jul 9, 2019 at 1:38 PM
    #59
    2016 4Runner SR5
    #Rensing Off-Road
    North Carolina
    Yep all the same. Just bought a 2019 Highlander and it's the same on that also. I have to say though, the OEM dash speakers in the Highlander are far superior to the 4Runner and Tacoma. It's a full range woofer, not just a tweeter.
    #59
    Andason74[QUOTED] likes this.
  30. Jul 9, 2019 at 1:47 PM
    #60
    What speaker would you recommend that will work with this plug?
